Creating exs24 Sample Instruments
2004-07-11 by Paul Millard
Is there a step-by-step description somewhere to help with creating Sample Instruments from aiff/wav files? Trying to use the online exs24 help wasn't really that helpful (I'm just starting to edit etc in exs24) Many thanks, Paul.
2004-07-11 by Paul Astles
hi paul, just wanted to say i'm having similar difficulties and finding it difficult to find a way to spread a single sample chromatically over the entire keyboard paul
> From: Paul Millard <pmillard@...> > Reply-To: exs-users@yahoogroups.com > Date: Sun, 11 Jul 2004 19:52:37 +0800 > To: exs-users@yahoogroups.com > Subject: [EXS] Creating exs24 Sample Instruments > > Is there a step-by-step description somewhere to help with creating > Sample Instruments from aiff/wav files? Trying to use the online exs24 > help wasn't really that helpful (I'm just starting to edit etc in exs24) > > Many thanks, > > Paul. > > > > > > > > ____________________________________________________________________ > EXS* Users Group > - To UNSUBSCRIBE: email exs-users-unsubscribe@yahoogroups.com > - EXS/Logic FAQ: http://logicfaq.omega-art.com/ > - Free legal samples: http://groups.yahoo.com/group/exs-users/links/ > - To contact list admins, email exs-users-owner@yahoogroups.com > Yahoo! Groups Links > > > > >
2004-07-11 by Eli Krantzberg
On Jul 11, 2004, at 9:53 AM, Paul Astles wrote: > hi paul, just wanted to say i'm having similar difficulties and > finding it > difficult to find a way to spread a single sample chromatically over > the > entire keyboard * Open EXS editor * Create a new instrument * Create a new zone * Load your sample into the zone, it will default to the entire range of the instrument * Save this newly created instrument * Call it up in the main EXS plugin window * Optional: Add additional zones to taste * Optional: Add additional groups to taste -------- Eli Krantzberg http://www.nightshiftorchestra.com Almat Productions [Non-text portions of this message have been removed]
2004-07-11 by Sascha Franck
In addition to what Eli allready said, there's a few things that make constructing new patches a LOT easier IMO. 1) Use the "read keynote from" function (to be found in the EXS editor > Edit > Preferences) You'll be getting four options there. "Filename" will read out the keynote for the zone from the loaded sample's name. This is true for both notnames (such as, say "C1) and MIDI note numbers (which actually makes the thing rather confusing at times). So, in case you load a sample named "Piano_F#1", the EXS will automatically set the key note accordingly. I highly reccomend making use of this in case you're sampling your own things. Simply name your samples properly when saving them. I sometimes even rename samples because this feature is so convenient. Note: Make sure to use sharps (#'s that is) instead of flats, these won't make it. "File" will read out root note info embedded in your audio file. Most often this function is close to useless as even some professionally sampled things don't contain embedded root note information. Personally I find adding such information to a sample more of an effort than simply renaming the sample (but maybe i'm just not using the right tool). "File/Filename" and "Filename/File" will read out both informations, with the one listed first as a preference. I usually have my preferences set to "Filename/File". The automatical readout will do miracles when loading multiple samples at once (zone menu > load multiple samples). Let's say you just have some samples, sampled in tritones, named "sound_C0", "sound_F#0", "sound_C1" and so on. You could then just use the "load multiple samples" function, select "automap" when being done with the sample selection and voil\ufffd - there's you're keymapping! Logic will fill the gaps between the individual notes/zones automatically. 2) Use temporary instruments for velocity layers Maybe not that important for drums, but in all other cases I find it highly useful to create temporary instruments for certain velocity layers, especially when using a lot of keymappings as well. The EXS editor as is doesn't give a great overview of sample mapping, that's why I usually prefer to construct instruments holding just the mappings of one velocity layer. Example: You have a bunch of samples, sampled in tritones and two velocities (again, of course your filenames should contain proper note names, according to "chapter" 1). So they might look like "sound_f_C0" (f for forte), "sound_p_C0" (p for piano), "sound_f_F#1" and so on. Now you would just use the "load multiple samples" function and create one mapping for the "f" samples. The automap function will create a group for those automatically. Name this group accordingly, for better convenience. Then create a second instrument (that you don't even need to save) and do the same for the "p" samples. Name the group accordingly again. After that you can just do a CTRL+A, CTRL+C, open the first instrument (the "f" one that is) and do a CTRL+V. The group from the "p" instrument will be copied along with the zones as well. Finally, set up velocity ranges in the groups to your liking. 3) Use samples with embedded loop information Apart from dealing with simple samples (such as a sine wave or so), I find it rather tough using the EXS sample editor to find proper loop points for samples. That's why I'm using WaveLab for such tasks (not sure about anything equivalent for Macs, for Windows there's also seamless looper and such, but WaveLab IMO beats them all big time). When importing samples to zones, the EXS will read out the loop points automatically. Well, actually there's a bug as the EXS will allways set the right loop point one sample too early, but most likely you will only notice that when dealing with rather small samples that are mapped over a broad range (so the EXS has to do the transposing job). I allways correct the right loop point manually anyways. 4) Set up a keycommand for "Shift selected zones(s) left/right (inc. root key" (to be found in the EXS section). This is a great time saviour in case you need to, say, change octave settings in a patch. You just select them all (or the ones you would like to shift) and use the KC. I have mine set to shift and the left/right arrows. Also great if you have, say, a multisampled snare and want to place it on another key. So much for now, Sascha
thanks sascha and eli.i've been struggling with this for some time. (i'm using exs24 mk 1) and i've never found any real help in the manual and i've read it lots of times but this is the first clear description i've had. paul
