RE: [EXS] EXS - RAM - output questions
2004-08-19 by LEE MINTRAM
>I created an EXS drum kit. Now I would like to have several outputs for the
>kit, so that I may be able to EQ and add reverb independently... I could not
>figure out how to do this. I called one friend, and he said that when it was
>time to mix, he literally loaded the same drum kit on several audio
>instruments - and each had their own EQ and reverb -  and also each was
>assigned just some of the MIDI information ... For example - the hi hat part
>track went to instrument 1 - and the kick drum went to instrument 2 etc...
>Q:  what is the best way to have multiple independent outs for mixing a drum
>set?
>Q:  if you load the same drum set and 5 times - does it use five times the
>amount of RAM - or is the EXS intelligent enough to use the samples loaded
>1x) on 5 separate instruments
I think it does take up more ram
you need to use a multi instrument exs 24, then send each sound to a
diffrent output which is then selected as a AUX channel, select a aux
channel and hold down like you are selecting a instrument and select a input
form the exs 24.
if your using a g5 2gz dual you may get clicking, there is a way round it
tho if it happens
lee
2004-08-20 by The Doghouse NYC
> the
> loaded
Actually, my understanding was that it does not. At least not a few versions
ago and I can't imagine they would have changed it.  But yes, the multi
output suggestion is also a good one although I never use it because it is
just so much easier to open another instrument then go through the routing
song and dance.
best, Nathan
___
Nathan Rosenberg
Music Production                    www.doghouseNYC.com
The Doghouse NYC                    www.pianoVOX.com
