Re: [EXS] EXS and sample rates
2004-09-02 by Sascha Franck
Andy M. wrote: > If my soundcard is set to 48k, will the EXS play back 44k samples at > the correct pitch..? Yes, it will. The only downside is that when previewing files they will playback at the samplerate you set in Logic, so they might seem out of pitch - but once you load them into the EXS, everything will be fine. > Or should I convert the 44k samples to 48k..? I wouldn't do so, but that might be a matter of personal preference - and a matter of filesize perhaps too. In case the EXS is set to stream samples (via VSM) it'll have to do the conversions on the fly, no idea whether that'll slow things down in a noticeable way, personally I've never been running into troubles. After all, 44.1 is by far the most common samplerate used by any sampler patches. That's also why it will take a long time until I bother to work at anything but 44.1 as my Logic/soundcard samplerate. Regards, Sascha
