Re: old lady
Re: old lady
2004-12-26 by Huud@aol.com
Hey everyone- Happy holidays!
I just installed the Old LAdy and I   HAVE to be missing something.   It
sounds filtered.   I mean really filtered.   It sounds rather lifeless as well.
I put it up against IVORY and there is No comparison.   Ivory sounds great.
Now does anyone have a setting for the exs24 that works well with the old
lady?   My settings HAVE to be off but I zeroed my Exs and it still dont help
much. :(
-T
Re: [EXS] Re: old lady
2004-12-27 by Fernstudio
Hi Terry,
> It
> lifeless as well.
> great.
> old
> dont help
>  much. :(
You have probably done this but have you switched off the filter in
exs-24?  Have you disabled any of the modulation routings in exs-24?
Have you opened up the exs-24 editor and selected the sample in one of
the zones?  You can go directly to the sample and play it back in the
finder window that pops up.  I use that sometimes to see if the sample
is okay but there is something wrong with my exs-24 patch.  I remember
reading about some people requiring to use Exs Manager from Redmatica
in order to fix some problems in the Old Lady for exs-24.  If I'm not
mistaken there is a free limited version that will allow you to fix a
problem with white noise playing back (I might be wrong).  If what I
suggested does not work, you should contact PMI directly (Michiel Post)
for some help.  I have the Old Lady (in Kontakt format) and it is truly
wonderful with lots of character.  It will probably sound quite
different from Ivory but it should still sound great.
HTH,
Fernstudio
2004-12-27 by Andris Sice
I'd be very interested to hear a comparison.
Anyone who owns both prepared to give an opinion?
Andris
Re: old lady
2004-12-28 by Michael McKenzie
> It
> as well.
> great.
> old
> dont help
> much. :(
> -T
Mine sounds OK, rather good...I might have a tin ear though.
It is very soft. I needed to insert a gainer plug to reach acceptable
output level.
Is that true for others?
M
Michael McKenzie Music Services
http://homepage.mac.com/michaelmckenzie/Menu3.html
2004-12-28 by Andris Sice
>  output level.
Michael,
I've found the Old Lady to be considerably softer than other samples
and audio instruments. I thought it might be due to some error I made
in setting it up but I can't imagine what, then I'm relatively new to
the EXS.
Anyone have suggestions?
Andris
2004-12-28 by Peter Ostry
>>  output level.
To get the full dynamic range they took the loudest sound a player can
produce as an upper limit for recording. You need a really good master
keyboard to utilize that huge headroom. If you hammer on a cheap,
unweighted synth- or controller keyboard to produce a velocity of 127
with 10 fingers you might destroy the instrument :)
You can test the available range: go to the score editor, write two
chords of 10 notes each and let them loop. Raise the velocity of all
notes to 127. The level meter goes up just below 0 dB depending on the
notes. Now add a sustain pedal and you are slightly over: they gave us
the maximum they could.
Of course, for daily use the Old Lady is too soft and if you are not a
trained pianist on a premium keyboard it will always be too soft for
you. Just add the gainer and/or try the expression function of a
transformer to get a velocity curve you like.
Peter Ostry
