Re: where am I supposed to put all this stuff?
2001-06-15 by Teddy Kumpel
yes I am on 4.7. I had to open the sampler instruments on the CD from
withinn the exs and "copy audio files" to my hard drive to get it to work,
even though there were already copies there.
thanks for your concern,
Teddy Kumpel
> You are on 4.7?
> I don't get presented with an option to search, but it is doing it
> automatically. It just doesn't find them even though they are there. weird
> teddy also powerbook
>> Don't you get the option to "Search" automatically? This is supposed to come
>> up in order to chase down the samples of the location has changed. I have
>> moved samples on my system (across partitions) without a problem.
>> PowerBook Macintosh User -Jer
>>> David Eager <oink@...> very eloquently wrote:
>>>> The Sampler Instruments folder goes in the same directory as Logic app,
>>>> the actual samples can go anywhere.
>>>> Dave Eager
>>> thanks Dave,
>>> ok, that's easy and done already. I can see the instruments in the pull down
>>> menu in the EXS, but when it searches for it's samples it says "Exs
>>> Instrument [name] audio file [name] was not found" , something like that.
>>> And this is with the stuff from the CD. I see the samples with the right
>>> name on my drive, definitely.
>>> Do I need to choose that place for the EXS samples folder when i'm
>>> installing and NEVER EVER move it, or what? When I installed I put my EXS
>>> samples folder with all my other samples and a folder called "samples" but
>>> then later I moved it to the Logic folder. what gives peoples?
Re: [exs] Re: where am I supposed to put all this stuff?
2001-06-15 by HELP@MusicProTools.com
Weird. Maybe it's a fluky software build. I imagine different people have
different evolutions of the installer cd. Sounds like it's working for you
now. Good to hear.
> From: Teddy Kumpel <kumpkin@...>
> Reply-To: exs-users@yahoogroups.com
> Date: Fri, 15 Jun 2001 14:07:39 -0400
> To: <exs-users@yahoogroups.com>
> Subject: [exs] Re: where am I supposed to put all this stuff?
> Teddy Kumpel
>> You are on 4.7?
>>>>> Dave Eager
>>>> thanks Dave,
>>>> down
> To unsubscribe from this group, send an email to:
> exs-users-unsubscribe@egroups.com
2001-06-15 by yael
Sent: Friday, June 15, 2001 8:33 PM
Subject: Re: [exs] Re: where am I supposed to put all this stuff?
now. Good to hear.
Sometimes the "Path" is not memorized by the Mac....
it happens to me with the "Mellotron Gforce" !! impossible to have the
sounds !! all the samples where in ythe right place, but nothing....
I've just copied again those samples and all was Ok.....(?)
Strange isn't it :o)
Igor
Thanks Igor. That will come in handy in the future, I'm sure. Until there's
a fix...
> From: "yael" <yael@...>
> Date: Fri, 15 Jun 2001 21:13:24 +0200
> From: HELP@...
> now. Good to hear.
> Igor
