firewire 800
firewire 800
2005-01-05 by Julie Larson
Hi everyone,
Can anyone tell me what are the best firewire 800 drives to use with
Logic?
thanks a bunch,
julie
www.julielarson.net
Re: [EXS] firewire 800
2005-01-05 by Charles Lucy
I have been using Western Digital External Hard Drive 1394 iLink 500Gig
for the past couple of months. It seems to work fast, and reliably, and
it has fast Firewire or regular connections, + dual voltage.
Price in London was £285 (about $550 US), so you should be able to find
it in US for about $400.
http://www.westerndigital.com
Phone in US 800.275.4932
On 5 Jan 2005, at 02:09, Julie Larson wrote:
Charles Lucy - lucy@...
------------  Promoting global harmony through LucyTuning  -------
for information on LucyTuning go to:  http://www.lucytune.com
for LucyTuned Lullabies go to http://www.lullabies.co.uk
Question
2005-01-05 by markus enochson
Hi guys
I¹m now thinking of transferring my akai sample library which is on MO
disks. I run int from an akai s 5000 any hint tips or tricks for how to
acces these mo disks on the mac and then use whatever transformation program
to use wihtin the esx. Its about 30 mo disks so its kind of a lot.
The mo drive is external scsi. I do have scsi on one of the macs.
Best
Markus enochson
RE: [EXS] firewire 800
2005-01-05 by Ron West
>Logic?
LaCie d2 Extreme w/ triple interface.
Ron
I hear there's rumors on the internets...
The B12 Collective:
http://ronwestb12.com
aim: ronwestb12
Re: [EXS] Question
2005-01-05 by Gramophone
Hi
If you still got a computer with a scsi port, I got a solution for you.
You will need a cr-rom writer and a copy of a cd-rom burning software
(usualy comes with it)
Usually, your computer would reject the drive (unreadable format...bla bla
bla... eject or format ?)
BUT, if you got you re burning soft open, it will not prompt you to eject or
format. Then got get the drive info with a scsi scan (or whatever they call
it) and make a CD-copy (might be called CD image or scsi copy as well); this
makes a blind copy, wich means it will not verify the content while it
writes. Needless to say you don t have to make the verify disk at the
end....
Once this is done, you got a cd-rom back-up that any computer can read (if
you did choose the right format when you burned :)  )
Good luck
Louis
> Hi guys
> Best
> Markus enochson
RE: [EXS] Question
_____
Sent: den 5 januari 2005 15:15
To: exs-users@yahoogroups.com
Subject: Re: [EXS] Question
Hi
>end....
>Good luck
Good call there.
One further question though.
What if there is more info on the mo drive than the cd rom. Would it work as
well with dvd rom? Or does it make the image over a few cds?
Best
Markus
Re: [EXS] Question
Will work with dvd if you got a dvd on that computer. A scsi copy cannot be
sub divided, it s  simply not reading (aka blind copy)
I m a bit surprise an old scsi drive got more than 700 meg of data. If ever
your drive is bigger than 700 meg, but the info is 700 or less, make sure
the drive as been optimise, otherwise you might have some data scarce
around, outside the 700 meg mark; the cd will only take the first 700,
anything after will not be recorded, ending up in missing data and
unreadable files (not all files, just the ones with data outside 700)
Louis
> Good call there.
> Best
> Markus
Re: [EXS] Question
2005-01-05 by Hollow Sun
> I¹m now thinking of transferring my akai sample library which is on MO....
What format?
If these are all S5000 format (i.e. .WAVs and .AKPs) on an S5000 formatted
disk, the Mac should just read it if you hook the drive up to the Mac - you
can just drag the stuff across.
If they are older Akai formats (S1/3000) on an old Akai formatted disk, the
disk(s) will be rejected by the Mac (but see below)
I don't suppose you have ak.Sys do you (you'll need the USB board
installed)? If so, just load from the MO into the S5000 first and then drag
from the 5000's memory to the desktop (or use the "SAVE TO MAC" function). A
bit tedious but.....
Best regards,
Steve
http://www.hollowsun.com
RE: [EXS] Question
2005-01-05 by Garth Hjelte
>disks. I run it from an Akai S5000 any hint tips or tricks for how to
>program to use wihtin the esx. Its about 30 mo disks so its kind of a lot.
Are the MO disks formatted for the S-5000, or for the S-1000/3000? That's
critical. See below.
> >end....
This is useful info if the MO drives are S-1000 or S-3000 formats, which
are not readable by the Mac. if they are S-5000 format, they are DOS format
and the Mac can read it itself, so the above is not necessary.
If they are S-1000 or S-3000 they are only 510mb used anyway. If they are
S-5000, you don't need the above solution anyway - just move the files over
manually.
And again, if the sounds are S-1000 or S-3000, the above is helpful, since
the onboard Akai convertor reads only CD's. However, if they are S-5000
.akp files, the EXS won't for free convert them - you'd need to purchase a
3rd party conversion program.
Garth Hjelte
Sampler User
