wav vs aif vs SDII
2005-03-11 by alecwhiting
I have up till now never thought of a reason why I should have a preference between wav or aif. I tend to have all three in my samples used with esx. However recently I had a problem where a song was open with two exs's, one had wav one had aif. The aif one however couldn't see its files, although I verified there presence where they should have been. It just refused to see them. So I went back to the prosamples cd and replaced the aifs with wavs and then everything worked fine. Also does anyone know, when you convert a 24bit file to 16 using logic save file, with lower than current bit depth, does this mean that logic is dealing with dithering for you when it converts. I am worried I will one day find noise in the esx samples I have created. The logic manual I have is poor on this subject. Best Regards Alec
