Re: [EXS] Microtonal tuning of EXS samples etc.
2005-03-15 by sc@rowatworks.com
Hi, Charles wrote: > From what you say in your posting it appears that you are not aware of >the microtuning capability of Logic Pro 7. True. I'm using Pro 6.4.1, and hadn't heard of that capability in Pro 7. >There are some JI tunings in the default tunings supplied with the >application. Good to know. Are any of the JI tunings based on whole number ratios of the key frequencies, a la Harry Partch? (ie. , if the frequency of the key note is 1/1, then the frequencies of the note placements in the octave above that are of the form 9/8, 5/4, 6/5, 4/3, 4/3, etc.). This is the basis of the scale I've been using for a couple of decades, and I like it. >All it seems that you need to do is to pick your tuning poison (JI, >LucyTuning etc.) and adjust the portamento rate. >It will them work for any sample that you should choose to load into >EXS. Will this portamento rate adjustment modify the pitch bend data on a slide-generated note? Or does it apply to keyboard entry, to dictate the change between discretely entered notes? (Or both? Or something else?) steven rowat - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - web site: <http://www.rowatworks.com> mailto:sc@...
