Many Thanx Eli and Frank!!!
2005-09-04 by Micke Nilsson
Hi Micke, > >What's not working with going to your audio hardware and drivers prefs >page and lowering the buffer setting to 128 or 64 (if possible)? Cause >that should do it. > > >-------- >Eli Krantzberg >http://www.nightshiftorchestra.com >Almat Productions >Another thing, maybe you can try it also (it worked for me, since I >couldn't get lower with the buffer setting than 128, to avoid pops >and clicks): >Try if you can set the process buffer lower, also in the audio >hardware and drivers prefs, >default is: "middle" i believe, try "small"! It helped me a lot to >increase the responsiveness of my System! No Problems, clicks or pops! >Regards, Frank Valet Many thanx, Eli and Frank!! That did the trick...I got my beautifully played/recorded piano. Cheers,Micke
