> On Mac,shortcut means Alias.
> When you install Logic & EXS,all the "sampler instruments" as well as
> the samples are, by default, installed in the Logic folder,in the
> applications folder,but,as your samples library will certainly extand
> to some Gigas,it's better to:
> -Move the "EXSamples" folder (as well as the "sampler instruments"
> folder) to a big and fast HD dedicated only to the audio work.
> -Create an alias of each of these folders and put them back in the
> Logic folder,they will act as pointers to the real folders.
> -You can even put your samples in different places,as long as you
> create and set up aliases.
> -The first time you'll open Logic and EXS after that the prog will scan
> your HDs to find the new direction to the samples.After that,it will
> find the samples automaticaly.
> Cheers,
> Alain
Thanks Alain and everyone for the help. As a programmer, I was embarrassed that I
couldn't figure it out so I finally asked the group for help. It worked and I'm enjoying over
250 gigs of samples now.
One important note I can add is that on my laptop and main G5, after Logic was installed it
write protected the Library folder. Repairing permissions was not adequate to fix the
problem. I had to go to the terminal and release the folder. If anyone else has had any
issues with this I'll be happy to post the fix. Let me know and thanks again to all.
Stumpster
