Message posted by futz <syncop8r@...>:
Eli Krantzberg <elik@...> wrote:
> Here's what I bet is happening:
> * You have a key command set for next/previous plugin setting
> * You have some midi remote command assigned to it
> * And you have midi remote enabled
I am brand-new to this forum, so if I'm posting in the wrong place, please let me know and accept my sincere apology.
I have Midi Remote disabled, and still when I hit A#1 the patch on the EXSP24 increments, and when I hit A#0 it decrements. I have checked Key Commands and nothing is set to change patches in plugins. Being new to Logic Express a few weeks ago, I poked around looking for a convenient way to increment and decrement when I was first auditioning sounds in the EXSP24 - sadly, I found one, but I don't remember what it was. I now want that feature turned off, so I can use those keys in my playing without changing patches when I hit either of those two keys.
I'm embarrassed to need help in this regard - after all, I created the problem for myself, but I can't remember how I did so. That being the case, if anyone knows how to disable this feature, other than disabling Midi Remote, which I have done, or turning off the feature using Key Commands, which is not set to increment and decrement patches, I would be most appreciative.
With my thanks in advance,
-futz
