Triggering a sample to loop, by just tapping the key once
2007-01-05 by Kynan Cooksey
Message posted by Kynan Cooksey <getsomebiotch@...>:
How do you get a sample to loop by striking the key only once?  I know you
can loop a wav by holding down a key, or hearing it once by highlighting
"one shot".  How do you toggle the loop on and off by tapping a key once for
loop on, then once for loop off?
Thanks in advance.
Re: [EXS] Triggering a sample to loop, by just tapping the key once
2007-01-05 by Eli Krantzberg
> know you
> highlighting
> once for
Touch tracks - in the environment.
Eli Krantzberg
http://www.nightshiftorchestra.com
Almat Productions
Re: Triggering a sample to loop, by just tapping the key once
No, I'm trying to trigger samples from drum pads.  I want to hit the drum pad and have the sample loop continuously, then hit the pad to stop the loop.
Any ideas on how the EXS24 should be set?
Re: [EXS] Re: Triggering a sample to loop, by just tapping the key once
> stop the loop.
You should still be able to do this with touch tracks. Instead of a
midi note from a keyboard being the trigger note, it will be
generated from a midi drum pad. Same principle applies. The touch
track will need to be your track instrument. Set it up inside the
touch tracks object so the loop you want to control corresponds to
the note number the pad generates.
Eli Krantzberg
Almat Productions
I think I see the light my friend.  Create new instrument in the environment, under touch tracks.  Place sample there...I believe.  Going to try it now.  Thanks a bunch.  I'll post when it works..haha
On Jan ,5, 2007, at 5:05 PM, Kynan Cooksey wrote:
> Triggering an audio loop though, not a sequence. It works great for
> sequences, but for audio loops to just loop, how would you do that?
Set up an EXS instrument with your loop loaded in and trigger that
through the touch tracks.
Eli Krantzberg
Almat Productions
2007-01-11 by Pete Thomas
> Triggering an audio loop though, not a sequence.  It works great for sequences, but for audio loops to just loop, how would you do that?
In the EXS editor, each zone can be set to loop. There is a tickbox.
Pete Thomas
www.petethomas.co.uk
Logic Tutorials, Hints, Tips, free Icons, Environments
Sample Aid (EXS Instruments for charity)
2007-01-23 by Kynan Cooksey
Yes.  Each sample has a loop toggle on it.  I am trying to just touch the key to trigger a looped sample though.  Hit the key once for on, once for off.  By having the loop box checked, it allows you loop, but the key needs to be held down.  This topic has escaped everyone so far.  Anyone know?
2007-01-24 by mandcmiller
You can assign MIDI control number 64 (sustain) to note on events. I believe note velocities
from 64-127 will turn sustain on, while velocities from 1-63 will turn sustain off. You might
also try creating a dummy Zone (with no sample assigned) and assign that, along w/ your
loop, to a Group that is allocated only one voice. This way you can use the dummy Zone for
muting the loop.
Matt Miller
http://www.millertone.com
--- In exs-users@yahoogroups.com, "mandcmiller" <mandcmiller@...> wrote:
> --- In exs-users@yahoogroups.com, "Kynan Cooksey" <forums@> wrote:
> > Message posted by Kynan Cooksey <getsomebiotch@>:
a
velocities from 64-127 will turn sustain on, while velocities from 1-63 will turn sustain
off. You might also try creating a dummy Zone (with no sample assigned) and assign that,
along w/ your loop, to a Group that is allocated only one voice. This way you can use the
dummy Zone for muting the loop.
> Matt Miller
A correction to my previous post: You need to load a sample into the dummy zone in
order for it to be used as a mute control. Also, velocity doesn't seem to have an effect on
the sustain (hold) control. It seems that you can only turn sustain on, but not off using
note values. However, the system I laid out does allow you to toggle a loop.
-Matt
