EXS multi-tracking
EXS multi-tracking
2007-08-01 by Michael Ruiz
Message posted by Michael Ruiz <mcruiz@...>:
Is it possible to break out the midi note numbers in the percussion tracks
to multi-tracks in Logic Pro?
What i want to do is process separately the individual drums and cymbals.
Re: [EXS] EXS multi-tracking
2007-08-01 by Michael Scheurer
> tracks
> cymbals.
In the arrange window; Region menu -> Demix -> Demix by Note Pitch
michael
Re: EXS multi-tracking
2007-08-01 by Matthew
Excuse me if I misinterpret your question...
If you open the editor of your drum sample (far right top of the
sampler) you will see it is broken into groops. The groups are on the
left.
Open a group and you will see channel outputs for them near the
bottom. I cannot recall if you can change the midi, sorry but I am
betting you can. To use this as multichannel you must load it into
your channel strip from the multi instrument drop down.
You can isolate samples or group them together, send them to different
mixing channels, sends, buses etc. I send them to aux channels and
then group them accordingly in the mixing environment for more control.
I hope that helps a little. I am pretty green  but I like to do this
with a jazz drum kit I have for the EXS.If there were a way to post my
autoload song I could just send you that to look at. I've got it all
set up for Kontakt and the EXS for multi channel output.
Good luck
2007-08-01 by Lenny Stearns
>> tracks
>> cymbals.
I'm not in front of my DAW to try this, but what about copying the MIDI to
mutiple tracks, assigning them to multiple instances of the EXS, and then
using some sort of filtering object in the Environment section to only
allow certain note values for each track?  I haven't checked the manual to
see if the last part is possible, but I'd be interested to know if anyone
could verify if such a capability exists.
Lenny
2007-08-13 by Sascha Franck
Sorry, but this didn't make it through due to Yahoo telling me my mails were
bouncing, so I'm posting it again.
>> tracks
> I think there's a slight misunderstanding of what exactly you want.
> However, here's the usual things one can do:
> - Demix by note pitch. This will create different parts for all the
> individual notes used. The downside being that it will create a new track
> for each and every part on your drumtrack as well. So, assuming you have
> like, say, 20 drumparts using 5 notes each, you'll end up with 100 (!) new
> tracks in your arrangement. I can't understand why, but this is so utterly
> stupid I could never even believe it. Yet, nobody has ever bothered about
> it. Anyways, when doing so, the best idea would be to glue all the
> drumparts together before splitting them.
> - With those splitted drumparts you could now route each of them to an EXS
> instance of its own.
> - Using a Mapped Instrument. You would just use that one in your
> arrangement, set up the required outputs in the Mapped Instrument and then
> cable them to EXS instances of their own. The advance beng that you could
> still only use one drumtrack in your arrangement while everything gets
> played by a separate EXS. Note for users of older Logic versions: This is
> only possible in realtime (for instance, while tracking) since Logic 7.
> - Edit your EXS patches so they can use multiple outputs. You'd open the
> EXS editor, route the zones of one instrument (say, your hihats) to a
> group (that you may have to create) and set that group to whatever output
> you like (note: You may need to activate "EXS Outputs" from the "View"
> menu).
> When done with that, you select the EXS as a multichannel instrument.
> After that, you would create aux objects in your environment and select
> the appropriate outs (that you assigned in your groups in the EXS editor)
> as inputs.
> With this method, you'd be able to play everything through one drumtrack
> and one single EXS instance, yet have individual instrument access for
> mixing purposes.
> The downside of this method being that all the adjustments you're doing on
> the EXS user interface would still be valid for all the instruments in the
> drumkit.
> As you may see, each method has its pros and cons, so you may probably
> want to go for a mixed approach.
> Regards
> Sascha
