COMMENTS ON KEYMAP
COMMENTS ON KEYMAP
2008-08-04 by Tom McLaughlin
Message posted by Tom McLaughlin <tommclaughlin75@...>:
KEYMAP COMMENTS AND SUGGESTIONS
Tom McLaughlin
Keymap is an important software suite. It is based around creating sample
sets (instruments) for Logic\ufffds EXS24 sampler. There are many algorithms and
concepts within Keymap that are unique to the world of sample editing and
Redmatica are to be applauded for its creativity, thoughtfulness and
innovation.
What follows are some of my observations and comments after having Keymap
for several months and editing and looping thousands of samples with it,
simple and complex. Some of the problems I\ufffdve encountered may be a result of
\ufffduser error\ufffd or not being able to extract proper usage information from the
manual.
Keymap is an excellent piece of software and anyone serious about sample and
sound design should consider buying it no matter what sampler they use.
____________________________________________________
When typing values into a numeric field I expect to be able to hit the ENTER
key and have that data entered. I recently found, through much trial and
error, that typing the \ufffdENTER\ufffd and then the \ufffdESCAPE\ufffd key enters typed data.
In my experience with computers typing \ufffdENTER\ufffd is the norm. A friend of mine
who is a Logic instructor for Apple said he has never heard of such a thing.
Is there a reason for this variance from the norm?
When editing samples I expect a sample to play from the beginning to the end
of a selected (highlighted) area. When I select ALL I expect the sample to
play from the beginning until the end (or loop) when I hit the space bar.
The Slider on the Sample Editor page is innovative and visually attractive
and works well with individual samples, but it is difficult to use with
multisample recordings as, with so much information to cram into the time
line, the resolution for individual notes / samples is small.
SAMPLE PLAY FROM START button on SAMPLE EDITOR page is at the very bottom of
the page, far away from the loop screen. This requires much going
back-and-forth with the mouse when editing loops and auditioning . Likewise,
HARMONIC RESYNTHESIS parameters on the SAMPLE EDIT page are at the bottom of
the field. Could these be raised to the upper most portion of the fields? My
mouse is getting tired.
EDITING OUT PORTIONS OF SAMPLES  When selecting an unwanted portion of
audio, other editors allow being able to choose a cross-fade length and
curve, select CUT or DELETE and have that data removed leaving a smooth
crossfade through the join point. This sample editing feature is important
when looping samples to get rid of out-of-tune portions, clicks, pops,
unwanted noises and performance artifacts. It is also important when merging
the attack portion to a looped portion of a sample, cutting out all but the
attack and the loop to save storage space or get \ufffdstraight to the point\ufffd of
the sound being designed if the loop is the focal point. (Sometimes you have
to crossfade through a lot of material to get the loop you want.) An
\ufffdOPTIMIZE SLICE CROSSFADE\ufffd option would be very helpful in this respect to
keep the data phase-coherent. And \ufffdSNAP TO ZERO CROSSING\ufffd would help too. I
am getting used to doing this on the SLICES page, but simply selecting and
highlighting an area displayed audio to be deleted and crossfaded through
the remainder is more intuitive through past experience with other sample
editors and looping software. Is it possible for SLICE VOLUME to be able to
increase volume in addition to reducing volume as it does now? And maybe
even NORMALIZE SLICE? The Slice XFade In and Out Length could be longer ...
as much as the data within a \ufffdsub-sample\ufffd of a multisample recording will
permit without encroaching upon a loop. I know many people will use the
SLICES page for rhythm and performance loops (which is not my forte\ufffd, but I
do look into exploring this) but for creating sustain loops in pitched
samples all this would really be of help.
dB markers at start and end of sample BLOCK THE VIEW OF SAMPLE DATA. I find
it hard to believe that sample editing software would block important attack
transients from view.
Loops with crossfades through very end of sample render with audible click.
Can samples be rendered and saved individually without having to create an
EXS instrument.
Rendering samples SEQUENTIALLY seems to number samples randomly with no
relation to their placement on the virtual keyboard. This has happened so
many times that I\ufffdve ruled out \ufffduser error\ufffd. I expect samples in a
multi-sample to be numbered sequentially, from low to high as mapped out on
the virtual keyboard. Also, sequentially numbered samples are always in
1,000\ufffds. Software should analyze the number of samples to be rendered and
then use the lowest number of digits needed to execute that sequence of
samples ... to save on characters. Also, a series of samples I rendered (97
samples C1 - C8) to be numbered sequentially AND with note names rendered
all samples with the prefix 0001. This required me to manually rename each
rendered sample with its proper number, a process that took considerable
time. When undoing a \ufffdslice remove\ufffd, it would be convenient to have the
sample zoom out automatically to the original magnification.
Selecting Render at -6db does not seem to increase sample level by +6db
after rendering. Sample sets I have rendered at -6db remain at -6db.
Loop View Display shows a bad loop join ... until loop join is examined
under a higher magnification. Not that the loop join is actually bad, it
just looks that way in the display.
Hitting green dot on Instrument Page should center page on computer vdu
screen as it does with other pages.
When playing sample while looping on instrument page and going to move loop
point or crossfade point, if you aren\ufffdt careful to direct the mouse EXACTLY
onto cursor points the sample is triggered to open in looping page!
Ordinarily this requires a double-click. To my experience, cursor \ufffdnodes\ufffd
could be a little bigger.
I rendered a chromatic set of velocity switching samples - soft, medium,
loud. 255 samples. The soft set came out with a suffix of \ufffd1\ufffd, medium \ufffd0\ufffd,
and loud \ufffd2\ufffd !!?? What happened? It would have been more convenient to have
them numbered 1, 2, 3 or 3, 2, 1. Is this possible? Actually ... it would be
most convenient to have each velocity set delivered to its own Folder. Is
this possible? This would make porting velocity switching samples to other
samplers, like Reason, easier.
Is there a way to have the data after a loop discarded when rendering loops?
MANUAL
New users want to be able to use software as quickly as possible without
reading any more of a manual than necessary. Not just Keymap, any piece of
software. I found it very frustrating that I had to sit down and thoroughly
read the manual (and sometime re-read sections a number of times) before I
could make use of the software. I have had Keymap for months now and am just
getting to grips with using it somewhat effectively.
In the current version of the manual it is often necessary to read through a
lengthy explanation of the benefits of a process or parameter, often
mentioned more than once, before the reader finds information on how to
actually use it. There are several facilities in Keymap that to date I
cannot locate in the manual how to use, and I\ufffdve had to find out how to use
others by trial and error. FIX: briefly mention the process or parameter,
explain HOW to use it, point out keyboard shortcuts, then go into a more
thorough explanation of the benefits and applications. A good model is the
Logic manual.
The index really does want to be expanded to include specifics rather than
only page numbers on which a topic appears.
I estimate that about 1/5 - 1/4 of the manual could be edited out for
clarity. An American or British Editor could help make the language used in
the Manual easier to read in English.
Having done audio engineering and sound design professionally, I found Logic
instantly useable. With Keymap I feel like I\ufffdve had to learn another
language.
wish list:
Loop Crossfade continuously variable between linear and equal power.
Individual notch filters for cutting out annoying harmonics that are
reinforced in group samples such as strings and choirs. Better yet, a
HARMONIC COMPRESSOR or LIMITER to level out these annoying harmonics. This
would be a combination of a tight band equalizer and a compressor / limiter.
Make the High Pass Filter sharper - as it is it sounds like a 6db or 12db
per octave filter.
A filter for removing 50/60 Hz mains hum with their respective harmonics
would be nice.
LOOP BLEND - similar to the facility in the old INFINITY looping software,
which put the data contained in a loop through the equivalent of a blender
(liquidizer in UK) thus homogenizing it and crossfading the result through
the attack portion of the sample by a specified amount.
CROSSFADE LOOP THROUGH ATTACK PORTION OF SOUND.
CROSSFADE LOOP THROUGH RELEASE PORTION OF SOUND for samplers that can deal
with \ufffdRelease Loops\ufffd.
Non-destructive editing is fine ... up to a point. Creating multisample
recordings with adequate space between adjacent samples so as not to have
the reverb tail from the previous note spill over to the following note eats
up disk space. (Using a noise gate is not an answer. Reverb tails can often
be useful data to crossfade through.) An algorithm to delete the blank space
between notes and re-save the data as a new file would be helpful. I have
quite a number of sample sets in progress and they are eating up my hard
drive space.
Peak Level Meter
Auto-Phase All or Selected Samples
Loudness Arc Superimpose over Keyboard Position
Copy Loudness Curve and Superimpose over Sample
Copy Pitch Curve and Superimpose over Sample
Tighten up several harmonic resynthesis algorithms for better accuracy ...
namely Polyphonate and HR Pitch correction adjust. I am disappointed with
Polyphonate, a tool I had hoped would be of more use. Its transposition
range is much narrower than I had expected and it produces glitches at the
upper extreme of its narrow range.
HIGH PASS FILTER FREQUENCY ROOT NOTE TRACK - For eliminating low frequency
garbage, for creative sound design.  As there is a root note analysis
algorithm present in the system it should be relatively simple to
incorporate an algorithm to set the High Pass Filter Frequency to track the
frequency of the root note of pitched samples.
Could \ufffdSave\ufffd be transparent, like Logic? Now hitting the \ufffdsave\ufffd key stops
the \ufffdplay\ufffd function, which then resumes once save has been completed.
Disable play on instrument page when changing to loop edit page - or -
transfer play from previous page until stopped by user. Now when a sample is
played by hitting the \ufffdspace bar\ufffd on the Instrument page and that sample is
opened in the Loop Edit page, the sample remains playing from the Instrument
page and if space bar is hit again BOTH the sample on the Instrument page
AND the sample on the Loop Edit page will play simultaneously. Now it
requires closing the Loop Edit page, returning to the Instrument page and
stopping \ufffdplay\ufffd before being able to return to editing on the Loop Edit
page.
Harmonic Resynthesis ought to calculate max amplitude of sample to be
rendered if over 100% and recalculate rendering to 0db or db set by user
(say -0.1db) to prevent clipping.
View ENTIRE WAVEFORM - an area where the entire waveform of a multisample
can be viewed would be of help.
____________________________________________________________________
The Zone Audio FX page contains some of my favorite facilities. They are
simple, but very useful in sound design. The Saturator 1 and 2, Stereo
Width, Low Pass Filter and High Pass Filter are a welcome set of tools. Used
in moderation the Saturators can add focus to samples, a bit more adds grit
to polite samples, and pushed harder offer a range of distortion colors any
metalhead would find useful. In practice, I rarely push Saturator 1 higher
than 0.04 and Saturator 2 higher than 0.5. I\ufffdve used Stereo Width to narrow
the stereo spread of a number of sample sets that, after auditioning by
mapping and playing from a keyboard through Keymap, were a bit too wide to
my taste. Although I\ufffdve used the High Pass Filter to get rid of low
frequency \ufffdgrunge\ufffd and reverb \ufffdboom\ufffd, I find it most useful in minimizing
the fundamental of synth sounds where it is too prominent - something that I
only find out when playing sample sets on Keymap with a music track. As
mentioned above, having a facility for this filter to automatically track
the fundamental harmonic of notes in a multisample would be a great help ...
I\ufffdve had to look up the fundamental frequency of each note on the handy
chart provided at the end of the Manual and type that into the numeric field
of the filter ... this can take a LOT of time with multisamples containing
dozens of samples.
I use the Zone HR Amp/Dynamics page all the time. Especially the HR
Normalization Amount - it helps even out levels of samples that, for one
reason or another, ended up lower than the rest of a set. And the HR Freeze
Decay is invaluable in helping to find loops in the decay portion of
percussive samples such as pianos and bells.
Keymap\ufffds pitch detection is great. It has problems from time to time with
octaves but it is far better than Reason\ufffds pitch detection, which
consistently calculates pitches sharper the higher the note ... C-6
invariably comes out 35-36 cents sharp with Reason.
LOOPS: The main reason I bought Keymap was for its looping facilities. Its
mapping and layering facilities are an added bonus for me and a genuine
help. Like Dino, I\ufffdve been using samplers since the 8 bit days, long before
the advent of the visual display of audio data - when looping samples was
accomplished solely by ear and much trial and error. There was a time when
in the time it took a sampler to calculate a loop crossfade you could go off
and make a cup of tea or coffee. We\ufffdve come a long way since then and Keymap
elevates sample editing and looping to a whole new level.
Although Keymap can automate locating loop points in a variety of ways,
rarely have I used loops as calculated. Many of these loops would be OK for
many users and could be fine when used in a track. But I\ufffdm a bit particular
when it comes to sample loops.
What Keymap does provide me with, and it is invaluable in this respect, are
excellent starting points for manually looping sounds aided by some
excellent looping tools. More often than not, High or Low Res Autoloop finds
a loop that is too short to my taste and the Double Loop Length, Shift Loop
Left / Right and Optimize Loop Crossfade are great helps in finding the best
loop length and position. When all else fails in creating a loop that is
pleasing to my ears, I turn to Add Optimized Crossfades To Loops - in the
Loop sub-menu in the Zones main menu.
All of this said, Keymap has some wonderful attributes and facilities. It
still crashes from time to time, but I work it very hard. Keymap\ufffds scope is
truly awesome and there are some facilities I haven\ufffdt gotten into yet. I
wasn\ufffdt a great fan of Logic\ufffds EXS-24 sampler, but thanks to Keymap I\ufffdm
warming up to it.
I feel Keymap is far too important a sample editor, looper and mapper to
limit itself to just the EXS24. Maybe introducing an additional \ufffdUNIVERSAL
MODE\ufffd could be the answer.
Many loops rendered using Keymap exhibit a \ufffdsymphony of harmonics\ufffd,
something I\ufffdve never encountered with any other software before. And you may
quote me on that. This is something you must hear to experience.
I thank Redmatica for it\ufffds forward vision and, undoubtedly, countless hours
of calculating and programming. Be assured that Keymap may just change the
way the world makes samples.
copyright Tom McLaughlin July 2008
Re: [EXS] COMMENTS ON KEYMAP
2008-08-06 by Andrea at Redmatica
On Aug 4, 2008, at 7:04 PM, tom mclaughlin wrote:
Hi Tom,
great post here. Let's see if I can add some useful comment:
> the ENTER key and have that data entered. I recently found, through
> much trial and error, that typing the �ENTER� and then the �ESCAPE�
> key enters typed data. In my experience with computers typing
> �ENTER� is the norm. A friend of mine who is a Logic instructor for
> Apple said he has never heard of such a thing. Is there a reason for
The data *is* entered after your press Enter. However, the focus
remains on the fields and you can keep editing/typing. This is not a
variation respect to the standard: open the Safari preferences, go to
General>Homepage and type something there, then press enter. You will
see how the focus is still there and you can keep typing.
Having it work this way lets you edit the same value multiple times
(and listen to results) without having to click the field with the
mouse again and again after each edit
The Esc key simply aborts editing and also removes the focus from the
field.
> the end of a selected (highlighted) area. When I select ALL I expect
> the sample to play from the beginning until the end (or loop) when I
> hit the space bar.
The default keycommand assigned to the space bar is "Start from
cursor". If you want to start from beginning, then you can use shift
+Space bar. Again, you can customize key commands as you prefer.
In Keymap, the playback cursor is never tied to selection, but only to
to cursors. This is as designed, and allows you to performs edits
independently from playback.
> attractive and works well with individual samples, but it is
> difficult to use with multisample recordings as, with so much
> information to cram into the time line, the resolution for
If you have a very large screen, the overview resolution might become
small because there are only so many pixels on the screen, but I would
say that this is still better than not having any kind of overview.
BTW, if you are using a Mighty Mouse the scroll ball gives you control
about scrolling and zooming, and this will greatly improve your
"scrolling/zooming" experience: a single quick spin down of the ball
will show you the complete file. Select a section, and give a single
quick spin up and you are there.
> bottom of the page, far away from the loop screen. This requires
> much going back-and-forth with the mouse when editing loops and
> auditioning .
> Likewise, HARMONIC RESYNTHESIS parameters on the SAMPLE EDIT page
> are at the bottom of the field. Could these be raised to the upper
> most portion of the fields? My mouse is getting tired.
Good suggestions.
> of audio, other editors allow being able to choose a cross-fade
> length and curve, select CUT or DELETE and have that data removed
> leaving a smooth crossfade through the join point. This sample
> editing feature is important when looping samples to get rid of out-
> of-tune portions, clicks, pops, unwanted noises and performance
> artifacts. It is also important when merging the attack portion to a
> looped portion of a sample, cutting out all but the attack and the
> loop to save storage space or get �straight to the point� of the
> have to crossfade through a lot of material to get the loop you
> want.)An �OPTIMIZE SLICE CROSSFADE� option would be very helpful in
> this respect to keep the data phase-coherent. And �SNAP TO ZERO
> CROSSING� would help too. I am getting used to doing this on the
> SLICES page, but simply selecting and highlighting an area displayed
> audio to be deleted and crossfaded through the remainder is more
> intuitive through past experience with other sample editors and
> looping software.
Every time you edit (cut) a portion of a sample, Keymap automatically
adds a non-destructive, realtime crossfade to the remaining parts. The
default crossfade values (length and shape) are set in the preferences
(slice crossfade in "Default Values"). You can at any time change the
crossfade length/shape using the Blend mouse action in the sample
editor (you can check the Keymap V1.5 addendum, page 57 for more about
this).
> Is it possible for SLICE VOLUME to be able to increase volume in
> addition to reducing volume as it does now? And maybe even NORMALIZE
> SLICE?
Not at the moment. Good suggestions.
> The Slice XFade In and Out Length could be longer ... as much as the
> data within a �sub-sample� of a multisample recording will permit
> forte�, but I do look into exploring this) but for creating sustain
> loops in pitched samples all this would really be of help.
Good suggestions.
> I find it hard to believe that sample editing software would block
> important attack transients from view.
We definitely tried to place these values in places that should not be
critical for the waveform visualization (so, it's not exactly at the
waveform end, etc...), but of course they consume some area anyway.
We'll probably add the option to disable those readings in the future.
> click.
We are not aware of such a problem. Can you please send us a very
simple KMP project (one sample file) demonstrating this problem when
you export, so we can check it here?
> create an EXS instrument.
Yes, by alt-cmd-drag and drop to a folder/finder, but not as a "Save
as" menu function.
> no relation to their placement on the virtual keyboard. This has
> happened so many times that I�ve ruled out �user error�. I expect
> samples in a multi-sample to be numbered sequentially, from low to
> high as mapped out on the virtual keyboard.
Well, this is your way of looking at that, but other users might have
a different opinion. (They have! This is not the first time we hear
this comment and everyone seems to have a different idea). What
happens when you have more than one sample for a note, over
velocities? Should the sequential number go from low velocity to high
velocity or from high to low? What happens if you have multiple layers
for the same notes, should the number start from the low layer to the
highest layer or from high to low, etc?
That's why we let you create own way to define the new sample names
starting from arbitrary combinations of layer names, notes and
velocities (both as numbers or note names), and many other parameters.
> Also, sequentially numbered samples are always in 1,000�s. Software
> should analyze the number of samples to be rendered and then use the
The reason is that we like consistency.  If you want to fine tune the
names, you can always use the Keymap rename functionality to strip
extra zeros.
> Also, a series of samples I rendered (97 samples C1 - C8) to be
> numbered sequentially AND with note names rendered all samples with
> the prefix 0001.
> This required me to manually rename each rendered sample with its
> proper number, a process that took considerable time.
Most probably this happened because you enabled the "Independent
sequential numbers" option. It's explained at page 51 of the Keymap
1.5 Addendum. Basically, if you enable this, there will be a separate
sequential numeration for each different name (as defined by the other
tokens), instead of a single number going up for each sample. In your
case, as you also added a note to the sample name, each sample name is
different than the others, and so gets its own separate sequential
numeration starting at 1.
Example: let's say you have 3 samples at C3, C4 and C5 in your
project, you are rendering these to new sample files and the model for
the newly created sample names is "MySample-$RN-$SEQ", ($RN stands for
root note and %SEQ for sequential number) then you will get those two
different results:
With "Independent sequential numbers" OFF :
MySample-C3-0001.wav
MySample-C4-0002.wav
MySample-C5-0003.wav
With "Independent sequential numbers" ON :
MySample-C4-0001.wav
MySample-C5-0001.wav
The ON setting is useful if you want to have different sequential
sample numeration for layers/groups: let's say that the sample name
model is "MySample-$LAY-$SEQ", and you have two samples in each layer,
then you would get:
with "Independent sequential numbers" OFF :
MySample-OneLayer-0001.wav
MySample-OneLayer-0002.wav
MySample-AnotherLayer-0003.wav
MySample-AnotherLayer-0004.wav
with "Independent sequential numbers" ON :
MySample-AnotherLayer-0001.wav
MySample-AnotherLayer-0002.wav
> When undoing a �slice remove�, it would be convenient to have the
The zoom settings are not handled by undo, and generally this is a
good thing to do, even if occasionally it might be inconvenient.
> +6db after rendering. Sample sets I have rendered at -6db remain at
> -6db.
The level is increased by +6dB in the zone volume parameters in the
EXS instrument saved to disk.
> examined under a higher magnification. Not that the loop join is
> actually bad, it just looks that way in the display.
This is a side effect of looking at the waveform when you have more
than one sample for each pixel. You can see the difference in
precision, because the waveforms are (on purpose) drawn with jaggies
when they are not sample accurate. If I might add, the loop view
reason of existence is that you keep it zoomed at high magnification
to check the join section..... there's simply no way you can check it
if you do not zoom-in enough....
> vdu screen as it does with other pages.
The green dot is disabled because the instrument editor window is not
resizable. This is standard OSX behavior.
> move loop point or crossfade point, if you aren�t careful to direct
> the mouse EXACTLY onto cursor points the sample is triggered to open
> in looping page! Ordinarily this requires a double-click.
Opening the sample editor always requires a double click, not a single
click.
The cursors are edited in the usual click and drag way. If you are not
clicking over the cursors.... well,  of course the software interprets
it as something else.
> To my experience, cursor �nodes� could be a little bigger.
Message received.
> medium, loud. 255 samples. The soft set came out with a suffix of
> �1�, medium �0�, and loud �2� !!?? What happened? It would have been
> more convenient to have them numbered 1, 2, 3 or 3, 2, 1. Is this
> possible? Actually ... it would be most convenient to have each
> velocity set delivered to its own Folder. Is this possible? This
> would make porting velocity switching samples to other samplers,
Well, how samples are named depends completely on how you set the name
and folder models for your samples in the  "SaveAs" panel. You can
certainly have samples automatically saved to different subfolders
depending on velocity, layers, note, groups, etc. You can check the
Keymap manual, page 281for more about this, and you can email support@redmatica.com
  if you have more detailed questions/examples.
> rendering loops?
Select all zones and perform a "Zones>Loop>Set end to loop end" menu
command before saving.
> MANUAL
> without reading any more of a manual than necessary. Not just
> Keymap, any piece of software. I found it very frustrating that I
> had to sit down and thoroughly read the manual (and sometime re-read
> sections a number of times) before I could make use of the software.
> I have had Keymap for months now and am just getting to grips with
> through a lengthy explanation of the benefits of a process or
> parameter, often mentioned more than once, before the reader finds
> information on how to actually use it. There are several facilities
> in Keymap that to date I cannot locate in the manual how to use, and
> I�ve had to find out how to use others by trial and error. FIX:
> briefly mention the process or parameter, explain HOW to use it,
> point out keyboard shortcuts, then go into a more thorough
> Logic manual.
> rather than only page numbers on which a topic appears.
> for clarity. An American or British Editor could help make the
> language used in the Manual easier to read in English.
We had a very skilled native english technical writer working on this,
and in all honesty I think he did a good damn job. You have to
consider that while you are certainly a very experienced user and some
sections might look boring, the manual needs to address also the less
experienced users.  That said, we always welcome comments, and we'll
certainly try to make good use of yours.
> found Logic instantly useable. With Keymap I feel like I�ve had to
> learn another language.
I understand what you mean, but.... it IS a different application :-)
> wish list:
I'm skipping the wish list section, as we do not comment about future
things.....
....but "we hear you" :-)
> facilities. It still crashes from time to time, but I work it very
> hard.
When/if this happens again, please send us the crash log!
> I thank Redmatica for it�s forward vision and, undoubtedly,
> countless hours of calculating and programming. Be assured that
> Keymap may just change the way the world makes samples
... and we thank you for using our apps, and even more for taking the
time to write this very long, very detailed, very interesting email.
Best Regards
Andrea Gozzi | Redmatica Srl
www.redmatica.com | Piazzale R. Finzi 2 | 42015 Correggio (RE) ITALY
