problems with instruments from AKAI Samples
2002-02-17 by Thomas Peitzmann
Hi all,
I have like so many others downloaded some of the AKAI Samples from
their server and the EXS files from James (thanks a lot!). I still
think that these Samples are o.k. to use, because they had posted
them freely themselves, but may be someone can find out more.(?)
I have a different question related to them. Haven't done so much
sampling myself, it's nice to have some examples to look at to learn
to do it right. I find quite some instruments from these samples that
have some quirks, and I was wondering whether that's related to the
original AKAI files, or whether it's a problem with CDXtract (in view
of the fact that I consider the purchase), or even a PC/Mac problem
(I'm on a Mac).
Here are examples of what I find:
1) Looking at the acoustic guitar which uses the samples "XX MARTIN
CS.WAV" I find that the lowest notes don't have the right tune. The
sample used for that is called "E0 MARTIN CS.WAV" and the keynote in
the EXS, which is also written in the file, is G1 (43). The next zone
is "A0 MARTIN CS.WAV", which uses C2(48) as keynote, and so on. Most
zones are detuned, so that they sound about right. However, "E0
MARTIN CS.WAV" does not contain an E0 but an A0 (55Hz).
2) The HIFI-CORNET is of very high pitch. The samples all have a
keynote which is an octave low relative to the file name, like G1 for
"CORNET_G2.WAV", and contain a tone which is again an octave higher
(G3). In addition to the gross tuning they also seem to be slightly
out of tune.
There are a lot of instruments which sound fine, but some with
obvious problems like the two above. Do others find the same? Does
CDXtract screw this up? Has somebody tried these sounds on an
original AKAI Sampler?
Is there a reason why one would want to set the keynote incorrectly
and then change the tuning to compensate?
Thanks for any information.
Best regards, Thomas
Re: problems with instruments from AKAI Samples
2002-02-17 by gordonmurrison
incorrectly
I havn't got a S5000 to try the progreams in but there are certainly
a lot of problems loading them into the EXS - I bought CDXtract to
do the conversions.  It gets it mostly right and I have emailed them
about the problems I have found.
So now I'm spending quite a bit of time checking and correcting ALL
the instruments.  I think the time and effort required will be time
well spent because it's a damn fine sample library to have 'on call'
(and I've got to do _SOMETHING_ while waiting for 5.0!)
Gordon
2002-02-17 by monsdrum
for
> out of tune.
Some of this is quite easily explained: the S5000 is for some reaon
or another an octave off in comparison to for instance logic (and
pretty much anything else I know of). Ie, a C4 in logic is called a
C3 on the S5000. This is probably the reason you experience this
confusion with samples programmed to be used on the S5000.
regards
monsdrum
Re: [exs] problems with instruments from AKAI Samples
2002-02-18 by Rubber Chicken Software Co.
>(I'm on a Mac).
>out of tune.
Akai's have many, many tuning parameters to deal with, and I do know that
my company's product, Translator, deals with them very precisely. We just
got done with another round of about 75 or so CD's and not a flaw in the
process. Of course that's S-1000 and s-3000, but we use the same code
dealing with the S-5000 as well, so it would apply there as well.
I would challenge anyone at this point to use Translator and see if they
ever would have a tuning problem at all.
Garth Hjelte
Sampler User
2002-02-18 by dt2080
if they
 Garth Hjelte
 Sampler User
I would gladly do this, if Translator was available for my Mac, but
not yet.....
david tobin
>>if they ever would have a tuning problem at all.
>not yet.....
Go to your library and try it out. Translator has been approved by most
public library systems.
Just kidding, of course. =)
Garth Hjelte
Sampler User
