Re: [exs] Groove Library production
2002-07-29 by PersingEP@aol.com
Hi All,
Excellent discussion of the various techniques about producing groove sample
libraries. As you can easily tell, there is no way to do every type of
production technique on every library.
Here's the choices we face everytime we produce a groove library:
• Single Loops vs Multi section loops?
If you include lots of section variations like verse, chorus, bridge, intros,
endings, fills, etc., it makes the library very flexible in a linear song
context. However, this dramatically cuts down the amount of actual ideas you
can offer. Some libraries provide you with an unedited live track, that has
the complete performance...which obviously takes much more space too. Our
opinion is that pattern/section variations are important with a Live Drum
library, but less important on a "loop" oriented product. Variety vs.
Variations.
• Mix Variations?
Even a simple request like providing Wet and Dry variations of live drum
grooves doubles the size of a library, and halves the musical options
presented in the collection. Multitrack collections take up even more space.
It's really useful to be able to control the tracks seperately, but it takes
a lot of space, which cuts down the ideas you can offer. It's also extremely
difficult to properly present both mix and section variations simutaneously,
because of the numbers of tracks/channels/parts necessary to play a complete
song. Then you have the question of variations of a mix and remixes (fuller
mix, smaller mix, no kick, no snare, compressed, uncompressed, etc)....tons
of choices here as well. Also, you can't always present the final mix sound
you want in a multitrack form, because of the buss processing that you used
in the final mix.
• Groove Control versions?
Loops are the easy part, the Groove Control process is the tricky stuff for
us...takes a long time to make each loop work properly and musically. It also
takes almost double the size of the original loop to present it in the
library. However, since GC allows you at least 10 times the musical
usefulness of a normal loop....it's completely worth including....but it does
take up more disc space.
• Multisamples?
Ideally, it would be great to have multi-velocity hits and kits of every
sound in the library, so that you can play your own patterns with total
dynamics and have it exactly match the grooves. Takes more memory
though.....and oh...you want the hits with the mix variations too?
Multitracked hits???
So if a library were to have every possible variation (Loops, Groove Control
versions, linear sections, fills, mix variations, multitracks and
multisamples) it would have about THREE loops in it!!
So obviously, the most important thing is to present as many musical ideas
and variety as possible, otherwise it isn't worth the price of the library.
Perhaps it will be possible to include every possible approach if DVD-ROMs
ever become more standardized, but that is taking a very long time. A DVD-ROM
is far more cost effective to produce than large multi-CD set, but there
isn't enough people who have DVD drives yet to do it. Also, the DVD drives
are notoriously flakey and less reliable than CD drives....so it is a tricky
thing for us producers that do big collections. Then again, that would only
solve the delivery issue...the problems of how to present it and the time to
produce a collection this way are staggering.
So currently, each Groove Control library has a different approach and
philosophy, so the customer can decide what aspect is most important to them.
For reference, here's the layout approach of each Groove Control Product.
Retro Funk: Section variations
Big Bad Beats: Mix Variations
Backbeat: Section variations
Liquid Grooves: Multitrack, Remix variations
Ethno Techno: Multitrack, Remix variations, Section variations
NoizBox: Multitrack, Mix variations
Metamorphosis: Variety/Quantity, Mix variations
Stylus: Variety/Quantity, Mix variations
Stark Raving Beats: Extreme Multitrack (every mic)
A good example of the difference is Metamorphosis, which has a huge variety
vs. Backbeat, which is very flexible for creating a complete drum
performance, but has less grooves, vs Stark Raving Beats, which has
ultra-flexible mixing, but no section variations.
Our solution, each one complements the other!
Of course each library covers a totally different musical genre too, but
that's a little easier to figure out from the info and demos.
Hope that explains a little of the thought process behind these products.
-Eric Persing
2002-07-29 by Gary Pozner
Dear Eric,
wanted to email you my site.  You could almost use it as an ad as 90% of the
pieces were made with one of your sample libraries.
gary pozner
www.whirledmusic.com
Beautiful site Gary...thanks and keep up the good work!
-EP
In a message dated 7/29/02 11:42:31 AM, garypozner@... writes:
>the
>gary pozner
Re: [exs] Groove Library production.....Phatmatik Pro.
2002-07-30 by Phil Buckle
Hi Eric, Thanks for the detailed post regarding the production of loop
libraries. I feel a big change is coming in the way this material is
marketed. I don't think we'll ever see the likes of yours and Skippy's work
released on CD again. Certainly not of that high standard. I know you are
going the virtual instrument route but just when you think the way is clear
along comes Phatmatik Pro and something tells me the path could take another
turn. Have you checked it out yet? The possibilities are mind blowing. The
things I've already done with Burning Grooves inside that plug......phew!!
BTW for all you insatiable loopaholics, Phatmatik Pro makes it possible to
access the whole Acid Library world from within Logic. Those discs are
reasonably priced......plus you can access your existing loop library and
slice it up, pan the slices, add delay, modulate, comb filter, distort and
then save it with your song, did I mention it locks to the host
tempo?........and it's only $100. I sound like a Yahoo advertisement.
Phil Buckle.
2002-07-30 by Sascha Franck
Phil Buckle wrote:
[lots of great things about pHATmatik Pro]
I agree, PPro is fantastic!
Since I got it ReCycle is collecting dust over here.
And I want to mention one further function which made my jaws drop all the
way down when I checked it out for the first time: You can drag'n'drop
slices straight from PPro to *any* sampler or drumsampler supporting d'n'd!
So, in practice: You slice a loop in PPro, select all the slices, drag them
onto, say, Battery or DR-008, then drag the PPro MIDI file onto your
drumsampler's track and there you go, wow! After that you can use your
drumsamplers "preview in context" function to partially replace the
individual slices with others!
Seriously, for anybody into loopmangling, PPro is a must have. And no, I am
not working for bitshift audio.
Sascha
2002-07-30 by yael
........: You slice a loop in PPro, select all the slices, drag them
Sascha
Hi Sascha,
because you own PPro can you tell me if you can drag 'n' drop a slice  from
the VST open on to the Arrange Window of Logic ?? :o) to extract a wav....
thx
Igor
2002-07-30 by Patrick Hall
What's the difference between PhatMatic Pro and PhatMatic Free?
(Other than the $99)
I was at the web site, but couldn't really get to a comparative feature list.
You know, save disabled, times out, test tones, whatever...
Just trying to decide if I'm ready to pop for the $99!
Anybody?
Thanks
> Regards,
> Sascha
> Hi Sascha,
> thx
> Igor
"You blow in this end of the trombone,
and sound comes out the other end and
disrupts the cosmos."
Roswell Rudd
Check out the Pat Hall @ http://www.mp3.com/pathall/
Do You Yahoo!?
Yahoo! Health - Feel better, live better
http://health.yahoo.com
2002-07-30 by Natalia Rakowski
PhatFree won't let you actually slice loops.  It will
only let you open their "PhatLoops," some of which you
can get with Computer Music magazine and I believe
they are releasing a library of loops for you to
purchase.
The Pro version lets you slice a loop or open an
Acidized loop with the slices already made.
Also, the Pro version is 4-part multitimbral I
believe.
That's all I can remember.  I've played with the Demo
of the Pro version and it's very cool...
-- N
> PhatMatic Free?
> whatever...
> $99!
> Anybody?
> Thanks
> slices, drag them
> MIDI file onto your
> > Regards,
> > Sascha
> > Hi Sascha,
> > thx
> > Igor
> Roswell Rudd
> Do You Yahoo!?
Do You Yahoo!?
from
Hi Igor,
Yes, you can drag slices straight to the arrange too.
Actually, you can drag them anywhere if the target supports it
(Explorer/Finder, other samplers, the arrange, whatever).
Sascha
LAMP Phatmatik Pro. dragNdrop
2002-07-31 by uswitalski@yahoo.de
>> from
how do you do it?
shouldnt this be working with the demo as well?
i dont manage to dragNdrop a slice.
enlighten me, this would be already worth the money.
cheers,
u.
__________________________________________________________________
Gesendet von Yahoo! Mail - http://mail.yahoo.de
Yahoo! pr\ufffdsentiert als offizieller Sponsor das Fu\ufffdball-Highlight des
Jahres: - http://www.FIFAworldcup.com
Re: [exs] LAMP Phatmatik Pro. dragNdrop
2002-07-31 by Matt Jones
On the mac version hold down the "option" key as you drag 'n' drop the
slice. Don't know whether it is supported in demo version.
Matt
>>> from
> how do you do it?
> cheers,
> u.
RE: [exs] LAMP Phatmatik Pro. dragNdrop
2002-07-31 by Neil Goldstein
excuse me for jumping on your thread, but will Phatmatic be OSX ready soon?
    _/      _/  _/_/_/  _/  _/
   _/_/    _/  _/      _/  _/
  _/  _/  _/  _/_/    _/  _/
 _/    _/_/  _/      _/  _/
_/      _/  _/_/_/  _/  _/_/_/
> From: Matt Jones [mailto:simmphonic@...]
> Sent: Wednesday, July 31, 2002 9:04 AM
> To: exs-users@yahoogroups.com
> Subject: Re: [exs] LAMP Phatmatik Pro. dragNdrop
> Matt
> >>> from
> extract a wav....
> > how do you do it?
> > cheers,
> > u.
> To unsubscribe from this group, send a blank email to:
>    exs-users-unsubscribe@egroups.com
> For a list of places to get free samples please see:
>    http://groups.yahoo.com/group/exs-users/links/
