Rate of change cc?
Rate of change cc?
2003-01-10 by Nick Batzdorf
You know, advanced as this has all become, the thing that still makes
working with sample libraries something of a compromise is that you
have to call up different programs for different variations of  the
same sound. Marcato and legato strings, for example. Things like
keyswitching and extreme controller mapping help*, but it's still not
quite there as far as I'm concerned.
The Yamaha VL1, in many ways the benchmark for an electronic
instrument, has a parameter called...I forget what it's called, but
it measures the rate at which the breath controller values change,
not just the static value. So if you blow in quickly, you get the
sound of a faster attack; blow gradually and you get a totally
different sound.
I know that the main reason the awesome Yamaha VL1 didn't sell was
that you had to learn how to use a breath controller - which is
(excuse me) way overblown, because it's so freaking easy - but isn't
that really what we want samplers to do? It sure seems like a much
less kludgey way to play a part. (I play the VL1 with an EWI, which
is awesome combination.)
* Am I right that the EXS only reads keyswitching that's been
programmed into a Giga sound, that you can't program it yourself? I
looked in v.2 and didn't find it.
Nick Batzdorf
818/905-9101, fax -5434, cell 818/601-4874
Re: [exs] Rate of change cc?
2003-01-10 by Edmund Eagan
> instrument,
Totally agree. It's the only synth I have that has survived the
soft-synth onslaught.
Edmund Eagan
www.twelfthroot.com
2003-01-10 by HELP@MusicBootCamp.com
Hey, that's what key-switching is for. Seemed to work pretty effectively.
But I'm not arguing the point. I'd much rather be an accomplished guitarist
than try to have to mimic a guitarist on a keyboard. But I know I can do
some cool stuff and some of it can't be replicated on a guitar. In my work
in industrial-dance music, that can be a bonus for designing new moods and
textures. -Jer
I've worked with breath control. You're right. They are incredibly agile in
controlling data. You have reminded me how much I would like to get a really
good one. Can you imagine, when I take my industrial music on the road,
playing vicious leads from the EXS or ES2 though something that looks as
innocent as a flute? Sounds good to me... Jer
2003-01-11 by john plumridge
I use breath control wx5 and a vl70-m. It is expressive. The vl70-m
only allows one voice, built as a lead instrument. sometimes I want a
polyphonic module...but how many expressive vioces do you want to
programme or orchestra, I ask myself?...and you?
Incidentally there is the SYXG100 XG & VL PHYSICAL MODELING SOFTWARE
SYNTh but only for windows.
jp
Tel: 01248 490 831
Re: Rate of change cc?
2003-01-11 by Nick Batzdorf
>keyswitching and extreme controller mapping help, but it's still not
It works very effectively, but what I'm suggesting (a "rate of
controller change" controller) could do more - not that you couldn't
use both, of course. If nothing else, you wouldn't have to use one
hand to switch programs, so that hand becomes available to move other
controllers or play other notes.
The main thing to me, though, is that you're thinking about playing
rather than about switching programs. And it's all done with the
breath controller - one controller. When it moves quickly from
nothing to 127, you automatically get a fast attack sample. When you
gradually release the pressure, you get less amplitude and crossfade
to a quieter sample. When the pressure goes to zero, you get a
release sample. You can map a little breath pressure to pitch, too,
for a breath-controlled vibrato. And open and control a filter, or
control the send to an exciter. It goes on and on.
Sure, I'd rather be a virtuoso on one instrument than good on some
and bad on others (I play about six instruments, depending on how you
count them, and not all of them well)!
>But I know I can do
>textures. -Jer
There's that. I'm mainly thinking about orchestral simulations,
though. Lots of people are working hard on the problem, and this is
my suggestion.
EXS 2 now has the controller implementation to make this work - if we
map it properly.
Nick Batzdorf
Re: [exs] Re: Rate of change cc?
2003-01-11 by HELP@MusicBootCamp.com
That would be very cool indeed. -Jer
Are you saying it currently supports the rate measurement? I forget from
your other posts whether you mentioned it. -Jer
> map it properly.
