Re: Lowering the tone . . .
2003-01-21 by Ruben Feffer
On Tuesday, January 14, 2003, at 12:43  PM, Eli Krantzberg
<elik@...>
  wrote:
>    From: Eli Krantzberg <elik@...>
> mjmartin64@... wrote:
>> Main question:  can I speed a drum loop up slightly, even if I'm not
>> worried about a slight pitch change?  Is there a mechanism short of
>> editing the loop for doing that?  I've seen friends with hardware
>> samplers do it.
> The easiest, although least flexible way, would be to just use some
> pitch bend. Go in to the event list where you can easily fine tune the
> pitch bend amount in order to get more subtler tempo/pitch variations
> than you will with a joy stick or PB wheel.
> Once you find a new speed/transpose value you like, bounce it to disc
> as a new file, trim it, then use the adjust object length to loacators
> command inside Logic to determine the new tempo. If you wanted to, you
> could then even reload the new loop back into the EXS for more
> manipulation.
Hi Mjmartin and Eli and all
My usual method, if I don't mind some altering of the pitch (which
sometimes I might even _desire_) is:
1. either use above mentioned tip of recording pb info and editing via
event list
or
2. adjust tuning (coarse and fine) in EXS itself
>> And, as far as altering tempos of drum loops, is the real solution
>> just to buy Recycle (which I've never used)?
> This sort of thing is another approach. It offers more flexibility and
> since it is quicker to get results, one is inclined to try/experiment
> in more ways. An alternative to Recycle is pHATmatik Pro. This
> operates as a plugin inside of Logic. In many ways it is a lot more
> easy to use and more seamlessly integrated with Logic. Although that's
> a whole other topic. If you search the archives for this list you'll
> find plenty of insightful discussion as to the relative merits,
> features, and comparisons between Recycle, pHATmatik Pro, and Groove
> Conrol.
Now, when I really need to control my loops, I use one of two methods
(besides Recycle which mainly sits unused cause I find it too
cumbersome).
3. PhatMatik Pro inside of Logic, which has been told about already,
and I enforce it.
or
(and this is almost taboo, no one ever seems to talk about it)
4. Ableton's Live (either slaved thru rewire or as a separate app),
which can play with any audio's timing and pitch, no matter how long (a
problem with PMP which seems more oriented to smaller loops). And new
Live version 2 gives _amazing_ algorhythms to stretch and twist audio.
give it a try http://www.ableton.de
Ruben
