giga conversion workaround
2003-04-18 by longys_wot_not_worx
Thanks to all who tried to help. The solution is:
IF YOU TRY TO CONVERT A GIGA FORMAT FILE THAT HAS A LONG NAME, THE
EXS WILL NOT RECOGNISE IT. YOU SIMPLY SHORTEN THE NAME OF THE FILE
AND IT WILL WORK.
THANKS TO MIKE AUTY FROM CANADA ON NORTHERN SOUNDS SAMPLE LIBRARY
DISCUSSION GROUP - I CAN NOW SLEEP EASY
Re: giga conversion workaround
2003-04-18 by Nick Batzdorf
>Longys,
>Please don't use capitals. Maybe you're not aware that in cyberspace, using
>capitals is the equivalent of screaming.
>  > IF YOU TRY TO CONVERT...
I agree that all caps isn't aesthetically pleasing and that it means
you don't have anywhere to go when you want to shout (which I
actually think is what longys was trying to do), but I also don't
understand why people get so upset! Excessive quoting is many times
more annoying, and nobody complains about that.
I know, I know, I shouldn't be discussing the list on a list...
Nick Batzdorf
818/905-9101, cell 590-9101, fax 905-5434
