[LAM] uploading (FTP) and downloading Logic Mac files
2003-07-06 by Pete Thomas
I need to place some Logic (mac) files on a site for various people
to download.
I have found that if these are downloaded on PC the extension .txt
is added.
If downloaded on a mac the files can no longer be opened in Logic,
but they need to be imported.
I presume this is a problem with the server and I then tried
stuffing files using Aladdin Dropstuff and uploading a .sit file.
This works except that when unstuffed there are two Logic song files
(eg file and file.1)
can anybody shed some light on what is causing this?
Thanks
Pete Thomas
www.petethomas.co.uk
Re: [EXS] [LAM] uploading (FTP) and downloading Logic Mac files
2003-07-06 by George Leger III
	You might be double clicking on the sit file. I have a programmable
Logitech mouse, and even if I click once on my right button (set to
double click) I get this exact behavior.
George
________________________________________________________
My Home : www.utopiaparkwaymusic.com
EXS/Logic FAQ: http://logicfaq.omega-art.com/
"Reet to tee to tee to tee to teeeeeeee"
Frank Zappa
" All our dreams can come true, if we have the courage to pursue them"
Walt Disney
2003-07-07 by Hendrik Jan Veenstra
>to download.
>is added.
This is not a server problem.  MacOS is the only OS that attaches a
so-called Type & Creator to files, so the OS knows which file belongs
to which application. This info is stored in the resource fork of the
file, which is a Mac-only construct.  So as soon as you put a Mac
file on a non-Mac system, you lose the Type/Creator info, and thus,
when getting the file back on a Mac, it shows up as a generic file
and not e.g. a Logic song -- hence the need to Import instead of Open
the file.
This is what happens when Stuffit extracts a file with the same name
as a file that's already present.  I.e. if the archive contains
'file', and the directory containing the archive also contains a
'file', then unpacking the archive will create 'file.1' in order to
avoid a naming conflict.
If what you upload are Logic songs and you want them to be available
to PC users as well, you should do 2 things:
1. Have all filenames end in .lso (so PC users can double-click the
file to launch Logic)
2a. Pack the files as .zip archives instead of .sit (Stuffit Expander
can unpack zip as well), or
2b. Make 2 archives available, zip and sit, for the 2 platforms (.zip
files lose the Type & Creator since it's not a native Mac packing
format, so for Mac users a .sit file is more convenient)
Hendrik Jan Veenstra   h @ k n o w a r e . n l
Omega Art: http://www.omega-art.com/
