Re: [EXS] Transfer
2003-07-26 by Hector
From: nstyngga <nstyngga@...> > Hey is there anyway to transfer setting such as reverb and > compression from one exs instrument channel to another or even > another song If you open the audio configuration window from the audio menu you can use the hand tool to drag fx from slot to slot. Holding control down should copy the fx. There are some problems: If an insert fx is automated you have to drag to the same numbered slot e.g.. slot 3 to slot 3 or you will lose the automation data (track automation) or control the wrong slot fx (object based midi automation.) Also, you cannot drag fx AND scroll the page at the same time. The destination slot is rarely ever in view. So you drag as far as you can in the visible window to an empty slot, then scroll the window up or down to reveal the destination slot and then drag the fx again. You may have to scroll more than once. An alternative is to save the fx settings as logic fx presets using the triangle drop-down menu and then open new instances at the destination channel and select those presets again. This can be quicker depending on how much scrolling you would have to do in the audio config window. People have been asking for the hand tool in the track mixer for a while now. Saving all the fx in a channel or multiple channels (fader scenes) as a setting has also been requested. I would also like to request that Logic transfers track automation with fx that get moved between different slot numbers. I see this as a bug so would like to see it fixed in the Windows versions as well. Hector.
