The Logic Off Topic list
Re: OT: remote PC power switch
2002-02-25 by Martin, Jeremy
[redirected from LUG to Logic-OT:]
From: Richmond, James (James) ** CTR ** [richmondj@...]
Date: Mon 02/25/2002 9:10 AM
Subject: RE: [LUG]  OT: remote PC power switch
hiya,
> Anyone have a clever solution for how to switch on a PC that's
> isolated in a closet or other enclosure. I was thinking of just
> extending the wire on the power/reset switch so I could take it out
> the closet and up to my desk but that seems inelegant.
most modern pc's will respond via a bios switch to a mouse click or
space bar press.
this is how i start up my pc (double click mouse)
> Pls reply off-list if you have an idea.
for the benefit of anyone else who doesnt know I have responded on list
jr
> rijstafel
Date: Mon 02/25/2002 3:21 PM
Control the power at the outlet, rather than at the PC. Radio Shack, for
example, makes remote outlet control devices that allow you to turn current
on and off at the outlet, under either radio or remote-outlet control.
S
> From: rijstafel [mailto:rijstafel@...]
> Sent: Monday, February 25, 2002 9:36 AM
> To: logic-users@yahoogroups.com
> Subject: [LUG] OT: remote PC power switch
> rijstafel
2002-02-26 by Joeri Vankeirsbilck
Date: Tue Feb 26, 2002 2:36am
Subject: Re: [LUG] OT: remote PC power switch
Thanks for the suggestion, but I'm not sure how good an idea that is
for the PC power supply. When a PC is plugged in (but turned off) it
still draws "standby" current --- this way when you turn it on, it
doesn't transition from a totally `cold' state (ie high-resistance)
This is why lightbulbs that are left on will last for years and
years, but ones that are flipped on & off will burn out -- and
usually, they burn out right when you flip the switch, because of the
sudden change in electrical load.
So, controlling your PC power at the outlet will create unnecessary
electrical wear & tear.
rijstafel
Date: Tue Feb 26, 2002 7:54am
 > If you have set up network, you can remotely turn your computer on/off
 > with
 > WON (wake-on-lan) using the MAC address.
 > If you have just one machine and want to turn it on/off from another
 > room,
 > your solution with an extended wire sounds quite plausible to me.
There are dedicated remote switches, that go between the computer
and the power line. They are typically used in server rooms,
where things are stowed away in racks and access from the front
panel is required. If you call up some place that specializes in
networking/server gear, they probably have some.
The much cheaper alternative is to simply use a power strip with
a switch, and leave the computer turned "on", and simply switch
the power at the far end of the supply line.
Then again, with today's power management features, there may be
little point in even turning off the computer. In sleep mode,
they comsume almost no power. Given that power spikes from switching
devices on and off are amongst the worst enemies to long life of
electronic components, that may be also the most environmentally
wise choice, if the total life-cycle is taken into account.
Ronald
"The reasonable man adapts himself to the world; the unreasonable one
persists
in trying to adapt the world to himself. Therefore all progress depends
on the
unreasonable man."  G.B. Shaw  |  rcfa @ cubiculum . com  |  NeXT-mail
welcome
