Re: [LUG] [OT] live room wiring for remote recording
2004-07-24 by Brian Pylant
> I also want to be able to remotely control recording (start/stop at > least) from within the live-room for when I am working on sessions > by myself and need to record a live part. What do I need to achieve > this ? what else needs to be built in (..midi cables?) What is > common practice? Any other considerations I should bear in mind? > Suggestions? This is certainly not the only method, but for the way I work and the size of my setup I use MIDI remote to control Logic from the other room (specifically I use an old drum machine with each pad mapped to a particular function - play, record, stop, etc.), and I can't think that it would hurt to have a few hardwired MIDI connections out to the live room anyway - I know many keyboardists end up setting up their rigs in the control room but I'm sure many would love to set up with the rest of the band if there were an easy way to connect to Logic from there, and having at least a few MIDI connections would make that much easier. Brian :::::::::::::::::::::::::::::::::::: Logic Audio Pro 6.4.2 PowerMac G4 933MHz OS X 10.3.4 1 GB RAM MOTU 828mkII - driver v1.09 - CueMix v1.4
