The Logic Off Topic list
Thoughts on Focusright Liquidmix
2006-09-20 by Peter Ostry
Does anyone of you use the Focusrie Liquidmix?
I spent about $1.500 during the last months for several compressor
and EQ plugins. Now I found out that the Liquidmix is way cheaper.
Does that device really deliver different sounds or can it be seen as
one plugin suite with a Liquidmix sound?
___
Peter Ostry
Re: Thoughts on Focusright Liquidmix
2006-09-21 by fuzoid
Message posted by fuzoid <fuzoid@...>:
i saw screenshots and a review in Computer Music, it looks ecxellent! its mainly for EQ and compressors, though. it has heaps of analog-modelled compressors and some of their own too. id say its worth investigating....
Re: [L-OT] Re: Thoughts on Focusright Liquidmix
2006-09-21 by Brian Mikiten
I have one - it isn't as wonderful as my Liquid channel preamps and I
can convince myself that the models there sound a tiny bit better but
it is a good product and they do a great job supporting users. Keep
in mind that at 88.1khz, you are limited to 8 channels of liqud mix
and that the expansion cards won't be out until late this year.
Brian
2006-09-21 by Peter Ostry
Thanks, Brian,
out of curiousity:
Did Focusrite emulate the devices and adapt the parameters for each
model or did they emulate the sound and made it compatible to their
parameter concept? In other words, can you setup one compressor or EQ
and switch to other models to look what sounds best or do you have to
concentrate on favorite models which you know and handle them as if
they where individual boxes?
____
Peter Ostry
> out of curiousity:
They use an emulation package that I won't attempt to explain here
but it is well documented on line. In very basic terms, they do an
impulse response test on amps, compressors, etc and model that
response. Pretty cool stuff and amazingly accurate. You could (and I
did) take 3 Neve preamps and not be able to tell the difference
between their emulation and the preamps. In fact, the emulation
sounded better than one of the preamps! I've not done the same with
the EQs but I suspect it is similar. I REALLY like the EQ modeling
and the fact that you can design your own EQ. The hardware connection
is much simpler to use than screen interfaces although in most cases,
both are provided.
Loading and switching in between models is easy but not as simple as
a rack of compressors or EQs only due to switching times. I don't
find it to be a problem.
Brian
Re: [L-OT] Re: Thoughts on Focusrite Liquidmix
Yes, that is certainly no problem. I guess even if you want to change
the model right in the track you can have a second instance, probably
create a second track for that part.
Thanks for your informative description. Although I am no longer sure
if the investment in a handful of plugins was the best idea I've had
this year ;-)
___
Peter Ostry
