JTAG commands are secret?
2005-11-04 by piotr.zbysinski@ep.com.pl
Few weeks ago I asked here (but not only here, in Philips Technical Support too) about JTAG commands used for Flash memory programming in LPC2K devices. In fact, nobody has given me complete answer. Similar problems I've had with STMicroelectronics Technical Support. Is there anybody who know why uCs producers are so secretive? Piotr
2005-11-04 by yodathgreat
Hi, No it's no secret, all JTAG write some codes into the SRAM... It write the code and "RUN".. best Regards --- In lpc2000@yahoogroups.com, <piotr.zbysinski@e...> wrote: > > Few weeks ago I asked here (but not only here, in Philips Technical Support > too) about JTAG commands used for Flash memory programming in LPC2K devices. > In fact, nobody has given me complete answer. Similar problems I've had with
> STMicroelectronics Technical Support. > Is there anybody who know why uCs producers are so secretive? > Piotr >
> Hi, > No it's no secret, all JTAG write some codes into the SRAM... > It write the code and "RUN".. 1. Sure, but JTAG is used (as standard) for testing only (with commands BYPASS, IDCODE, EXTEST etc.). 2. I asked about Flash memory programming - not using SRAM as a program memory. 3. If you want to load some code to SRAM memory you should use special commands (codes) for switching TAP into "SRAM load mode" (name of this mode is my own, it is not possible to find them in official docs ;-)). Piotr
2005-11-04 by Ake Hedman, eurosource
> Is there anybody who know why uCs producers are so secretive? Yes this is very sad as well as strange behavior and typical for European management. They are all in the thinking that they have to get payed for everything that are developed in house. They don't have the vision to see that they get a much bigger return by putting the information out in the open and let others improve it. The LPC family is the best I have seen for many years (I'm actually mainly a PIC user) but knowing that this type of old thinking still exists in Philips makes me hold back from using them on all major designs. I talked to a rather big Swedish company last week and they liked the LPC more then the competition but selected the AVR ARM instead because of the same reasons. And in that case we talk about a lot of pieces. I really hope that a company like Philips that so often show technical excelens could mature and show marketing excelens to... /Ake -- --- Ake Hedman (YAP - Yet Another Programmer) eurosource, Brattbergavägen 17, 820 50 LOS, Sweden Phone: (46) 657 413430 Cellular: (46) 73 84 84 102 Company home: http://www.eurosource.se Kryddor/Te/Kaffe: http://www.brattberg.com Personal homepage: http://www.eurosource.se/akhe Automated home: http://www.vscp.org
2005-11-04 by tsvetanusunov
> 1. Sure, but JTAG is used (as standard) for testing only (with commands > BYPASS, IDCODE, EXTEST etc.). > 2. I asked about Flash memory programming - not using SRAM as a program > memory. they can't tell you JTAG commands for Flash memory programming for the simple reason that they don't exist :) > 3. If you want to load some code to SRAM memory you should use special > commands (codes) for switching TAP into "SRAM load mode" (name of this mode > is my own, it is not possible to find them in official docs ;-)). you are wrong, there is no SRAM load mode, but the "secret" is that you can execute ALL ARM7 instructions through the JTAG interface by putting them into the pipeline, so you execute this way small code which do writes to your SRAM the information you want to write to the flash (learn ARM assembler first for the data store commands ;) then small code which calls Flash write IAP and you are set Best regards Tsvetan --- PCB prototypes for $26 at http://run.to/pcb (http://www.olimex.com/pcb) PCB any volume assembly (http://www.olimex.com/pcb/protoa.html) Development boards for ARM, AVR, PIC, MAXQ2000 and MSP430 (http://www.olimex.com/dev)
> Swedish company last week and they liked the LPC more then the > competition but selected the AVR ARM instead because of the same > reasons. And in that case we talk about a lot of pieces. I don't understand this, what are you telling us that Atmel opens their software specs? try to get from them the debug-write specs then! I don't belive if somebody picked chip X or Y the reason is for the open software programming specs. LPCs have their strong side - easy to learn, less features to confuse the beginner, smooth learning curve for peoples who move from 8-bits this in other hand is their weak side later on - too infantile peripherials, no DMA channels etc, SAM7S256(same price range as LPC2124) for instance have 11 DMA channels connected to every peripherial which relief the CPU from overhead waiting to read this or that peripheral, so I bet the Swedish company moved to Atmel due to other reasons than the programming specs. perhaphs the way Philips to go is to keep this high-runner entry series, but to introduce one more sophisticated serie which to keep to them the peoples who want some more power from the ARMs :) Best regards Tsvetan --- PCB prototypes for $26 at http://run.to/pcb (http://www.olimex.com/pcb) PCB any volume assembly (http://www.olimex.com/pcb/protoa.html) Development boards for ARM, AVR, PIC, MAXQ2000 and MSP430 (http://www.olimex.com/dev)
> they can't tell you JTAG commands for Flash memory programming for > the simple reason that they don't exist :) :) Really? If so, how can you load SRAM via JTAG if TAP in JTAG (as IEEE1149 standard says) recognizes _only_ 5 commands (used _only_ for testing)? In devices with JTAG used for other than testing purposes (like SRAM/Flash loading, debugging etc.) are special commands with codes different than 5 standard commands (like ISP_xxx in PLDs). There is no way to use JTAG in other way than standard 16 states without _special_ codes. > >> 3. If you want to load some code to SRAM memory you should use > special >> commands (codes) for switching TAP into "SRAM load mode" (name of > this mode >> is my own, it is not possible to find them in official docs ;-)). > > you are wrong, there is no SRAM load mode, but the "secret" is that > you can execute ALL ARM7 instructions through the JTAG interface by > putting them into the pipeline, Executing instruction is possible after loading. You say "through" - I agree, but my question is: how to say to JTAG "through"? > so you execute this way small code > which do writes to your SRAM the information you want to write to the > flash (learn ARM assembler first for the data store commands ;) then > small code which calls Flash write IAP and you are set Sure, all of this is possible _after_ loading. My question is: "how to load SRAM"? Thank you for "learn" suggestion ;-) Piotr
> I don't understand this, what are you telling us that Atmel opens > their software specs? try to get from them the debug-write specs then! > I don't belive if somebody picked chip X or Y the reason is for the > open software programming specs. It's easy: open software programming specs give chance for cheap and easy to buy programmers (like STK200 and similar). For beginners "start" price is real argument. In my opinion AVR are No. 1 in Poland _only_ because are easy to program and cheap. Piotr
Tsvetan, of course a decision like this depends on more then just the openness of a company (And Atmel may not be the best example either in that case). Still I would say that if its easy to get samples, get information, have many application notes available often will be one of the key factors on uP selection. No one can probably state that the PIC is superior in architecture. Most people choose it because of successfully company politics by Microchip. Openness being one important part. /Ake tsvetanusunov wrote: > > Swedish company last week and they liked the LPC more then the > > competition but selected the AVR ARM instead because of the same > > reasons. And in that case we talk about a lot of pieces. > > I don't understand this, what are you telling us that Atmel opens > their software specs? try to get from them the debug-write specs then! > I don't belive if somebody picked chip X or Y the reason is for the > open software programming specs. > LPCs have their strong side - easy to learn, less features to confuse > the beginner, smooth learning curve for peoples who move from 8-bits > this in other hand is their weak side later on - too infantile > peripherials, no DMA channels etc, SAM7S256(same price range as > LPC2124) for instance have 11 DMA channels connected to every > peripherial which relief the CPU from overhead waiting to read this > or that peripheral, so I bet the Swedish company moved to Atmel due > to other reasons than the programming specs. > perhaphs the way Philips to go is to keep this high-runner entry > series, but to introduce one more sophisticated serie which to keep > to them the peoples who want some more power from the ARMs :) > > > Best regards > Tsvetan > --- > PCB prototypes for $26 at http://run.to/pcb > (http://www.olimex.com/pcb) <http://www.olimex.com/pcb%29> > PCB any volume assembly (http://www.olimex.com/pcb/protoa.html) > <http://www.olimex.com/pcb/protoa.html%29> > Development boards for ARM, AVR, PIC, MAXQ2000 and MSP430 > (http://www.olimex.com/dev) <http://www.olimex.com/dev%29> > > > > > > > SPONSORED LINKS > Microprocessor > <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=YXTZih-RJw5W96ETRMZhDQ> > Microcontrollers > <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=bE-R787UQ86O4xFnkFUcUw> > Pic microcontrollers > <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=kb_XlXirZUmIq6ZO0okS1g> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "lpc2000 > <http://groups.yahoo.com/group/lpc2000>" on the web. > > * To unsubscribe from this group, send an email to: > lpc2000-unsubscribe@yahoogroups.com > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > -- --- Ake Hedman (YAP - Yet Another Programmer) eurosource, Brattbergavägen 17, 820 50 LOS, Sweden Phone: (46) 657 413430 Cellular: (46) 73 84 84 102 Company home: http://www.eurosource.se Kryddor/Te/Kaffe: http://www.brattberg.com Personal homepage: http://www.eurosource.se/akhe Automated home: http://www.vscp.org [Non-text portions of this message have been removed]
> > Swedish company last week and they liked the LPC more then the > > competition but selected the AVR ARM instead because of the same > > reasons. And in that case we talk about a lot of pieces. > > I don't understand this, what are you telling us that Atmel opens > their software specs? try to get from them the debug-write specs then! > I don't belive if somebody picked chip X or Y the reason is for the > open software programming specs. In Poland AVRs are No. 1/PICs No. 2 because informations about all "secret" things are easy to find and programmers are really cheap. "Start" price is the first argument for most users in my country. Piotr
2005-11-04 by Rob Jansen
Piotr, > 1. Sure, but JTAG is used (as standard) for testing only (with commands > BYPASS, IDCODE, EXTEST etc.). > 2. I asked about Flash memory programming - not using SRAM as a program > memory. > 3. If you want to load some code to SRAM memory you should use special > commands (codes) for switching TAP into "SRAM load mode" (name > of this mode > is my own, it is not possible to find them in official docs ;-)). It is al fairly well documented. You need the information from the IEEE in order to be able to use the TAP controller, I guess you do know a bit about this since you are mentioning the TAP commands. The ARM 7TDMI-S Technical Reference manual DDI0234 (see http://www.arm.com/pdfs/DDI0234A_7TDMIS_R4.pdf) contains a full section on the Embedded ICE macro cell, that is the block used to communicate with the ARM7 core - it not only describes the contents of the scan chains but also what to do with it (how to read/write registers, how to read/write memory, how to run/single step, how to place breakpoints) Furthermore the LPC user manuals (e.g. http://www.semiconductors.philips.com/acrobat/usermanuals/UM_LPC2106_2105_2104_1.pdf) contains a chapter on ISP and IAP, it even describes that IAP can be used for JTAG Flash programming. I already spent a few words on this in another post (http://groups.yahoo.com/group/lpc2000/message/9776). Philips chose for flash programming through their bootrom IAP code using all generic mechanisms that are there. This means that you are able to do this using any JTAG debugger that is able to do some scripting (load data, load registers and execute code). It is not secret, but since Philips uses IAP programming combined with the standard ARM7 Embedded ICE you need the documentation on that part also. Just select your ARM7 TDMI-S JTAG debugger probe of your choice and use their software interface (some of the probes come with a DLL to control the ARM code from your own software). Don't need to worry to much about JTAG stuff yourself in this way. Rob P.s: be aware that controlling the ARM core through the Embedded ICE yourself to load SRAM is not that simple.
2005-11-04 by Dominic Rath
On Friday 04 November 2005 10:10, piotr.zbysinski@... wrote: > > they can't tell you JTAG commands for Flash memory programming for > > the simple reason that they don't exist :) > > > :) Really? If so, how can you load SRAM via JTAG if TAP in JTAG (as > : IEEE1149 > > standard says) recognizes _only_ 5 commands (used _only_ for testing)? In > devices with JTAG used for other than testing purposes (like SRAM/Flash > loading, debugging etc.) are special commands with codes different than 5 > standard commands (like ISP_xxx in PLDs). There is no way to use JTAG in > other way than standard 16 states without _special_ codes. ARM debugging uses optional/private instructions in conjunction with the public INTEST instruction. These are documented in the ARM datasheets. > > Executing instruction is possible after loading. You say "through" - I > agree, but my question is: how to say to JTAG "through"? > Again, this is documented in the ARM datasheets. All ARM7 cores behave similar (there are differences, but you can work around those) as far as debugging is concerned. Using the scan chain select register (which is selected by the SCAN_N JTAG instruction) you read/write the Embedded-ICE scan chain and the Core scan chain. > > so you execute this way small code > > which do writes to your SRAM the information you want to write to the > > flash (learn ARM assembler first for the data store commands ;) then > > small code which calls Flash write IAP and you are set > > Sure, all of this is possible _after_ loading. My question is: "how to load > SRAM"? You scan the proper instruction to write core registers into the processor, followed by a "store multiple" instruction that is flagged to be executed at "system speed". Then you select the RESTART JTAG instruction, the core synchronises back to system speed (from debug mode), writes the memory, and reenters debug. Repeat those steps until all your data is in SRAM. > Thank you for "learn" suggestion ;-) > Piotr Regards, Dominic
>> :) Really? If so, how can you load SRAM via JTAG if TAP in JTAG (as >> : IEEE1149 >> standard says) recognizes _only_ 5 commands (used _only_ for testing)? In >> devices with JTAG used for other than testing purposes (like SRAM/Flash >> loading, debugging etc.) are special commands with codes different than 5 >> standard commands (like ISP_xxx in PLDs). There is no way to use JTAG in >> other way than standard 16 states without _special_ codes. > > ARM debugging uses optional/private instructions in conjunction with the > public INTEST instruction. These are documented in the ARM datasheets. > OK, thanks. I'll try to find them once more. As I remeber this information (command codes) is not there included, but maybe my memory is poor? >> >> Executing instruction is possible after loading. You say "through" - I >> agree, but my question is: how to say to JTAG "through"? >> > Again, this is documented in the ARM datasheets. All ARM7 cores behave > similar > (there are differences, but you can work around those) as far as debugging > is > concerned. Using the scan chain select register (which is selected by the > SCAN_N JTAG instruction) you read/write the Embedded-ICE scan chain and > the > Core scan chain. > >> > so you execute this way small code >> > which do writes to your SRAM the information you want to write to the >> > flash (learn ARM assembler first for the data store commands ;) then >> > small code which calls Flash write IAP and you are set >> >> Sure, all of this is possible _after_ loading. My question is: "how to >> load >> SRAM"? > > You scan the proper instruction to write core registers into the > processor, > followed by a "store multiple" instruction that is flagged to be executed > at > "system speed". Then you select the RESTART JTAG instruction, the core > synchronises back to system speed (from debug mode), writes the memory, > and > reenters debug. Repeat those steps until all your data is in SRAM. > >> Thank you for "learn" suggestion ;-) >> Piotr > > Regards, Dominic > Thanks a lot! Piotr
>> 1. Sure, but JTAG is used (as standard) for testing only (with commands >> BYPASS, IDCODE, EXTEST etc.). >> 2. I asked about Flash memory programming - not using SRAM as a program >> memory. >> 3. If you want to load some code to SRAM memory you should use special >> commands (codes) for switching TAP into "SRAM load mode" (name >> of this mode >> is my own, it is not possible to find them in official docs ;-)). > > It is al fairly well documented. > > You need the information from the IEEE in order to be able to use the TAP > controller, I guess you do know a bit about this since you are mentioning > the TAP commands. > The ARM 7TDMI-S Technical Reference manual DDI0234 (see > http://www.arm.com/pdfs/DDI0234A_7TDMIS_R4.pdf) contains a full section on > the Embedded ICE macro cell, that is the block used to communicate with > the ARM7 core - it not only describes the contents of the scan chains but > also what to do with it (how to read/write registers, how to read/write > memory, how to run/single step, how to place breakpoints) > Furthermore the LPC user manuals (e.g. > http://www.semiconductors.philips.com/acrobat/usermanuals/UM_LPC2106_2105_2104_1.pdf) > contains a chapter on ISP and IAP, it even describes that IAP can be used > for JTAG Flash programming. I already spent a few words on this in another > post (http://groups.yahoo.com/group/lpc2000/message/9776). > > Philips chose for flash programming through their bootrom IAP code using > all generic mechanisms that are there. This means that you are able to do > this using any JTAG debugger that is able to do some scripting (load data, > load registers and execute code). > It is not secret, but since Philips uses IAP programming combined with the > standard ARM7 Embedded ICE you need the documentation on that part also. > > Just select your ARM7 TDMI-S JTAG debugger probe of your choice and use > their software interface (some of the probes come with a DLL to control > the ARM code from your own software). > Don't need to worry to much about JTAG stuff yourself in this way. OK, I'll read all these docs once more. Thanks! Piotr
2005-11-04 by Stephen Pelc
Piotr wrote: > Few weeks ago I asked here (but not only here, in Philips > Technical Support too) about JTAG commands used for Flash > memory programming in LPC2K devices. In fact, nobody has > given me complete answer. Similar problems I've had with > STMicroelectronics Technical Support. Is there anybody who > know why uCs producers are so secretive? They aren't being secretive! It's just that the JTAG and Debug module interface come from ARM. You need (at least) the following documents from the ARM Tech Ref CD: DAI0028, DAI0038B and DDI0029G. The manufacturers may well protect their Flash algorithms, and they may also not document all the JTAG scan chains, but at least for the LPC2xxx, once the JTAG unit has control, it can run the IAP routines. For a different approach to JTAG for ARMs, see: www.mpeforth.com/jtagwidget.htm Stephen -- Stephen Pelc, stephen@... MicroProcessor Engineering Ltd - More Real, Less Time 133 Hill Lane, Southampton SO15 5AF, England tel: +44 23 80 631441, fax: +44 23 80 339691 web: http://www.mpeforth.com - free VFX Forth downloads
2005-11-04 by Joel Winarske
> OK, I'll read all these docs once more. Thanks! > Piotr This might also be of some use: TI - JTAG Scan Educator: http://tinyurl.com/bclk9
2005-11-04 by lpc2100_fan
--- In lpc2000@yahoogroups.com, <piotr.zbysinski@e...> wrote: > > > > Swedish company last week and they liked the LPC more then the > > > competition but selected the AVR ARM instead because of the same > > > reasons. And in that case we talk about a lot of pieces. > > > > I don't understand this, what are you telling us that Atmel opens > > their software specs? try to get from them the debug-write specs then! > > I don't belive if somebody picked chip X or Y the reason is for the > > open software programming specs. > > In Poland AVRs are No. 1/PICs No. 2 because informations about all "secret" > things are easy to find and programmers are really cheap. > "Start" price is the first argument for most users in my country. > Piotr > Piotr, they are 1 and 2 because they have been around for many years, because they provide low cost tools, had early flash memory and are (at least the AVR) good to program. The ARM will be coming up more and more because it is a standard supported by many companies with much higerh performance than PIC or AVR and similar pricing (for similar memory). Go and find all the "secrets" (e.g. check the ARM website may be you will find a JTAG spec), then publish them and may be then even in Poland ARM can become #1 No offense please, Bob
2005-11-04 by Piotr Zbysinski - EP(H)
> Piotr, > > they are 1 and 2 because they have been around for many years, because > they provide low cost tools, had early flash memory and are (at least > the AVR) good to program. > '51, HC08/12, MSP430, TMS370, COP8 and similar are longer on market and most of them (excluded TMS370) have Flash/ISP/IAP/ICSP memory. Which one is more popular than AVR/PIC? Look that many manufacturers changed politics and now we have lot of free (limited) C compilers, free programmers etc. > The ARM will be coming up more and more because it is a standard > supported by many companies with much higerh performance than PIC or > AVR and similar pricing (for similar memory). > Sure, but if tools will be expensive, speed of rising will be small - in most "small" applications, not in industry. I don't see any reason for paying 100$ or more for simple program for Flash programming via JTAG. This is necessary for programming uCs like STR family, OKI ARM family and older Atmel AT91. > Go and find all the "secrets" (e.g. check the ARM website may be you > will find a JTAG spec), Complete JTAG spec (with IEEE1532 included) I have (can send if someone needs) and know very well. The "secret" is not here, unfortunately. > then publish them and may be then even in > Poland ARM can become #1 Hmmm, popularity of ARM is a problem of manufacturers not mine. I'd like to develop simple JTAG Flash programmer only. > > No offense please, Bob > Offense? ;-)) Piotr
2005-11-04 by David Tal
Hi Piotr, I would love to have the Complete JTAG spec (with IEEE1532 included). Thanks a lot, Regards, David --- "Piotr Zbysinski - EP(H)" <piotr.zbysinski@...> wrote: > > Piotr, > > > > they are 1 and 2 because they have been around for > many years, because > > they provide low cost tools, had early flash > memory and are (at least > > the AVR) good to program. > > > > '51, HC08/12, MSP430, TMS370, COP8 and similar are > longer on market and > most of them (excluded TMS370) have > Flash/ISP/IAP/ICSP memory. Which one is > more popular than AVR/PIC? Look that many > manufacturers changed politics and > now we have lot of free (limited) C compilers, free > programmers etc. > > > The ARM will be coming up more and more because it > is a standard > > supported by many companies with much higerh > performance than PIC or > > AVR and similar pricing (for similar memory). > > > > Sure, but if tools will be expensive, speed of > rising will be small - in > most "small" applications, not in industry. I don't > see any reason for > paying 100$ or more for simple program for Flash > programming via JTAG. This > is necessary for programming uCs like STR family, > OKI ARM family and older > Atmel AT91. > > > Go and find all the "secrets" (e.g. check the ARM > website may be you > > will find a JTAG spec), > > Complete JTAG spec (with IEEE1532 included) I have > (can send if someone > needs) and know very well. The "secret" is not here, > unfortunately. > > > then publish them and may be then even in > > Poland ARM can become #1 > > Hmmm, popularity of ARM is a problem of > manufacturers not mine. I'd like to > develop simple JTAG Flash programmer only. > > > > > No offense please, Bob > > > > Offense? ;-)) > Piotr > > > __________________________________ Yahoo! Mail - PC Magazine Editors' Choice 2005 http://mail.yahoo.com
2005-11-04 by Eric Engler
--- In lpc2000@yahoogroups.com, <piotr.zbysinski@e...> wrote: > > Few weeks ago I asked here (but not only here, in Philips Technical Support > too) about JTAG commands used for Flash memory programming in LPC2K devices. > In fact, nobody has given me complete answer. To program flash you first need to write some code that you download to RAM, and then you execute your program from RAM and that will program the flash. Several years ago many people used the Angel monitor for this function. This is a bootloader that also has debug commands (Angel Debug Protocol) that make it easy to interface to gdb and other debuggers. Angel was only a serial monitor, which limited its ability to fully control the embedded chip. You can still find Angel source code on the web if you look for it. I found it at the Atmel site. You can learn a lot about the ARM Embedded ICE module by studying that source code. Speaking of Embedded ICE, this is the internal module in all ARM7TDMI chips that provides low-level debugger support. This is the module that interacts with the JTAG port. Angel used to be the common way to get at the internals, but today the world has moved to JTAG debugging instead. JTAG is a faster interface and it doesn't have the limitations of a serial interface. Embedded ICE used to be called ICE Breaker. Sometimes you'll see references to ICE Breaker on the web - this is the same thing. Since the JTAG is a hardware interface, it can be difficult to work with from the PC side. So, the Remote Debug Interface (RDI) was developed to provide a standard interface for software running under Windows. The best known implementation of RDI is Segger's J-link DLL. Sadly, this is not an open standard. The j-link Server is a free program (free, but not open source) that provides a convenient TCP/IP interface that allows a Windows program to execute RDI commands. gdb uses this j-link server. JTAG is the best debugging interface, but its not a good option for production-ready circuit boards because companies don't want to have a 20 pin port on production boards. So most companies provide a form of In System Programming (ISP) that is implemented by a small bootloader program. This bootloader program checks the state of some pins every time the ARM chip boots, and if it finds the levels its looking for, it takes control and watches a serial port for commands. This is similar in concept to Angel, but it does not implement debugging commands - it only provides flash programming functionality. I think all the major ARM7TDMI makers have this kind of bootloader, but this is always implemented differently so its hard to have one program that can program the flash of any ARM chip. Instead, you normally need a different program for each chip maker. Most of the chip makers will provide the details of their serial bootloader if you contact their tech support people. The Philips bootloader is well understood and the open source lpc21isp program supports this bootloader. Atmels new SAM-BA bootloader is pretty new and I don't know of any open source programs yet, but Atmel has provided the source code for it so its only a matter of time until open source programs appear for it. The nice thing about SAM-BA is that it works with both serial ports and USB ports! Eric
2005-11-05 by Eric Engler
--- In lpc2000@yahoogroups.com, "Piotr Zbysinski - EP\(H\)" <piotr.zbysinski@e...> wrote: > I'd like to > develop simple JTAG Flash programmer only. Did you look at the open source jtager project at SourceForge? http://jtager.sourceforge.net/
2005-11-05 by Landrum Haddix
Hi, I found a really hard to track down hardware problem today that was forcing the JTAG port to not work. I am using an LCP2138 and JTAG quit working after a board rev. We had pulled P0.31 down because it was the enable for a 485 transciever and needed to be low during reset. Turns out there is an 'undocumented feature' on some of the LPC parts including the 2138 that will disable JTAG if P0.31 is low during reset. We all know about RTCLK needing to be high during reset for JTAG because it's documented, but P0.31 functions exactly the same way. I think it all has to do with a obscure thing called the secondary JTAG port. I think for some of the series P0.31 functions like RTCLK on the 2138 and must be low at reset to enable the JTAG port. Apperently it's still in the silicon even on the 2138 even though it's not documented. Anyhow it was very obscure and if it weren't for a single message buried deeply on the Keil site I would not have found until I removed every change on the new rev. Landrum Haddix lhaddix@... http://web.qx.net/lhaddix
2005-11-05 by Dan Beadle
This is documented in the 2148 User manual I don't know about the '38, but seems like it would be the same thing. Unfortunately, they don't talk about it on the data sheet for the '48 Dan _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf Of Landrum Haddix Sent: Friday, November 04, 2005 6:24 PM To: lpc2000@yahoogroups.com Subject: [lpc2000] Another JTAG issue. Heads up Hi, I found a really hard to track down hardware problem today that was forcing the JTAG port to not work. I am using an LCP2138 and JTAG quit working after a board rev. We had pulled P0.31 down because it was the enable for a 485 transciever and needed to be low during reset. Turns out there is an 'undocumented feature' on some of the LPC parts including the 2138 that will disable JTAG if P0.31 is low during reset. We all know about RTCLK needing to be high during reset for JTAG because it's documented, but P0.31 functions exactly the same way. I think it all has to do with a obscure thing called the secondary JTAG port. I think for some of the series P0.31 functions like RTCLK on the 2138 and must be low at reset to enable the JTAG port. Apperently it's still in the silicon even on the 2138 even though it's not documented. Anyhow it was very obscure and if it weren't for a single message buried deeply on the Keil site I would not have found until I removed every change on the new rev. Landrum Haddix lhaddix@... http://web.qx.net/lhaddix SPONSORED LINKS Microprocessor <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2 =Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=YXTZih-RJw5W96ET RMZhDQ> Microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor& w2=Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=bE-R787UQ86O4x FnkFUcUw> Pic microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microproces sor&w2=Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=kb_XlXirZU mIq6ZO0okS1g> _____ YAHOO! GROUPS LINKS * Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web. * To unsubscribe from this group, send an email to: lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . _____ [Non-text portions of this message have been removed]
OK, it's in the LPC213x users manual at June 2005, but wasn't in the Nov 2004 version. My bad. Landrum Haddix lhaddix@... http://web.qx.net/lhaddix
2005-11-05 by Richard
As a commercial vendor, I am less interested in Open Source tools but I can wholeheartedly agree about low cost tools. One "weakness" of our $199 ARM compiler is that there was no corresponding low cost flash programmer tools. I went around pitching to different vendors for licensing their technology. I told them that I don't need fancy stuff, just a simple way to burn as many different types of flash as possible. It's amazing the kind of deafening silence I get (I guess I am not much of a salesman). In the end, we did find someone and we are now shipping a PAR JTAG w/ Windows flash downloader for $175. More than I would like but still cheaper than other solutions. I am negotiating with another very famous JTAG maker to see if I can convince them for a lower cost (~$400-$500 *ouch I know* but it will be USB) solution. At 12:53 PM 11/4/2005, Piotr Zbysinski - EP\(H\) wrote: >... >Sure, but if tools will be expensive, speed of rising will be small - in >most "small" applications, not in industry. I don't see any reason for >paying 100$ or more for simple program for Flash programming via JTAG. This >is necessary for programming uCs like STR family, OKI ARM family and older >Atmel AT91. > > > Go and find all the "secrets" (e.g. check the ARM website may be you > > will find a JTAG spec), > >Complete JTAG spec (with IEEE1532 included) I have (can send if someone >needs) and know very well. The "secret" is not here, unfortunately. > > > then publish them and may be then even in > > Poland ARM can become #1 > >Hmmm, popularity of ARM is a problem of manufacturers not mine. I'd like to >develop simple JTAG Flash programmer only. > // richard (This email is for mailing lists. To reach me directly, please use richard at imagecraft.com)
2005-11-06 by dragon fire
Piotr, this may explain some confusion: (this is a direct quote from the J-link documentation from www.segger.com) Quote: 6.4.1 How does flash programming via J-Link work ? This requires extra code. This extra code typically downloads a program into the RAM of the target system, which is able to erase and program the flash. This program is called Ram code and "knows" how to program the flash; it contains an implementation of the flash programming algorithm for the particular flash. Different flash chips have different programming algorithms; the programming algorithm also depends on other things such as endianess of the target system and organization of the flash memory (e.g. 1*8 bits, 1 * 16 bits, 2*16 bits or 32 bits) The Ram code requires data to be programmed into the flash memory. There are 2 ways of supplying this data: Data download to RAM or data download via DCC. 6.4.2 Data download to RAM The data (or part of it) is downloaded to an other part of the RAM of the target system. The Instruction pointer (R15) of the CPU is then set to the start address of the Ram code, the CPU is started, executing the RAM code. The RAM code, which contains the programming algorithm for the flash chip, copies the data into the flash chip. The CPU is stopped after this. This process may have to be repeated until the entire data is programmed into the flash. 6.4.3 Data download via DCC In this case, the RAM code is started as described above before downloading any data. The RAM code then communicates with the PC (via DCC, JTAG and J-Link), transferring data to the target. The RAM code then programs the data into flash and waits for new data from the host. The WriteMemory functions of J-Link are used to transfer the RAM code only, but not to transfer the data. The CPU is started and stopped only once. Using DCC for communication is typically faster than using Write- Memory for RAM download since the overhead is lower. 6.4.4 Available options for flash programming There are different solutions available to program internal or external flashes connected to ARM cores using J-Link. The different solutions have different fields of application, but of course also some overlap. End Quote.
>From: "Ake Hedman, eurosource" <akhe@...> >Reply-To: lpc2000@yahoogroups.com >To: lpc2000@yahoogroups.com >Subject: Re: [lpc2000] JTAG commands are secret? >Date: Fri, 04 Nov 2005 09:11:53 +0100 > > > Is there anybody who know why uCs producers are so secretive? >Yes this is very sad as well as strange behavior and typical for >European management. They are all in the thinking that they have to get >payed for everything that are developed in house. They don't have the >vision to see that they get a much bigger return by putting the >information out in the open and let others improve it. The LPC family is >the best I have seen for many years (I'm actually mainly a PIC user) but >knowing that this type of old thinking still exists in Philips makes me >hold back from using them on all major designs. I talked to a rather big >Swedish company last week and they liked the LPC more then the >competition but selected the AVR ARM instead because of the same >reasons. And in that case we talk about a lot of pieces. > >I really hope that a company like Philips that so often show technical >excelens could mature and show marketing excelens to... > >/Ake > >-- > --- >Ake Hedman (YAP - Yet Another Programmer) >eurosource, Brattbergav�gen 17, 820 50 LOS, Sweden >Phone: (46) 657 413430 Cellular: (46) 73 84 84 102 >Company home: http://www.eurosource.se >Kryddor/Te/Kaffe: http://www.brattberg.com >Personal homepage: http://www.eurosource.se/akhe >Automated home: http://www.vscp.org > > >
2005-11-06 by Tom Walsh
Landrum Haddix wrote: >Hi, > >I found a really hard to track down hardware problem today >that was forcing the JTAG port to not work. > >I am using an LCP2138 and JTAG quit working after a board rev. > > > You probably are looking at an early release of the LPC213x manual? The "Rev 01 - 24 June 2005" issue of "LPC213x User Manual" clearly documents that P0.31 must not be pulled low during reset... I do know that the manual prior to that revision date was rather terse (missing data). TomW >We had pulled P0.31 down because it was the enable for a 485 >transciever and needed to be low during reset. > >Turns out there is an 'undocumented feature' on some of the LPC >parts including the 2138 that will disable JTAG if P0.31 is low during >reset. We all know about RTCLK needing to be high during reset >for JTAG because it's documented, but P0.31 functions exactly the >same way. > >I think it all has to do with a obscure thing called the secondary JTAG >port. I think for some of the series P0.31 functions like RTCLK on the >2138 and must be low at reset to enable the JTAG port. >Apperently it's still in the silicon even on the 2138 even though it's >not documented. > >Anyhow it was very obscure and if it weren't for a single message >buried deeply on the Keil site I would not have found until I removed >every change on the new rev. > > >Landrum Haddix >lhaddix@... >http://web.qx.net/lhaddix > > > > > >Yahoo! Groups Links > > > > > > > > -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
2005-11-07 by Doug Sutherland
I would greatly appreciate a copy of the JTAG spec also. Could you please send to doug@... TIA, Doug Piotr wrote: > Complete JTAG spec (with IEEE1532 included) I have > (can send if someone needs)
2005-11-07 by Ake Hedman, eurosource
Same here. akhe@... Cheers /Ake Doug Sutherland wrote: > I would greatly appreciate a copy of the JTAG spec also. > Could you please send to doug@... > > TIA, > Doug > > > Piotr wrote: > > Complete JTAG spec (with IEEE1532 included) I have > > (can send if someone needs) > > > SPONSORED LINKS > Microprocessor > <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=YXTZih-RJw5W96ETRMZhDQ> > Microcontrollers > <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=bE-R787UQ86O4xFnkFUcUw> > Pic microcontrollers > <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&c=3&s=68&.sig=kb_XlXirZUmIq6ZO0okS1g> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "lpc2000 > <http://groups.yahoo.com/group/lpc2000>" on the web. > > * To unsubscribe from this group, send an email to: > lpc2000-unsubscribe@yahoogroups.com > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > -- --- Ake Hedman (YAP - Yet Another Programmer) eurosource, Brattbergavägen 17, 820 50 LOS, Sweden Phone: (46) 657 413430 Cellular: (46) 73 84 84 102 Company home: http://www.eurosource.se Kryddor/Te/Kaffe: http://www.brattberg.com Personal homepage: http://www.eurosource.se/akhe Automated home: http://www.vscp.org [Non-text portions of this message have been removed]
2005-11-07 by FabioDB
Piotr Zbysinski - EP(H) ha scritto: > Complete JTAG spec (with IEEE1532 included) I have (can send if someone > needs) and know very well. The "secret" is not here, unfortunately. Can you send me at fabiodib@.... Thanks!
2006-05-30 by Tom Walsh
Landrum Haddix wrote: >Hi, > >I found a really hard to track down hardware problem today >that was forcing the JTAG port to not work. > >I am using an LCP2138 and JTAG quit working after a board rev. > >We had pulled P0.31 down because it was the enable for a 485 >transciever and needed to be low during reset. > > > Just a note, I got nailed by this one. Even though I "knew better", fortunately it only took a few minutes to realize the mistake on the prototype wiring. Another hour for microscopic surgery though. :-( TomW -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
