Lpc2000
Timer/counter interrupt
2006-05-29 by Mukund Deshmukh
I have come across strange problem of time interrupt. My timer interrupt
routine is very simple.
void __attribute__ ((interrupt("IRQ"))) tc0_cmp(void);
/* Timer0 Compare-Match Interrupt Handler (ISR) */
void tc0_cmp(void)
T0FLG=1;
main1000++;
// haul1000++;
T0IR = TxIR_MR0_FLAG; // Clear interrupt flag by writing 1 to Bit 0
VICVectAddr = 0; // Acknowledge Interrupt (rough?)
The interrupt works ok. The moment I uncomment  haul1000++, the first
interrupt works and there after stops.
In short if  I increment one variable it works, if I  increment more than
one variable it stops.
The processor is LPC2138 and this is the only interrupt I am using.
Best Regards,
Mukund Deshmukh.
Beta Computronics Pvt Ltd
10/1, IT Park, Parsodi,
Nagpur-440022
Cell - 9422113746
Re: Timer/counter interrupt
2006-05-29 by Karl Olsen
--- In lpc2000@yahoogroups.com, Mukund Deshmukh <betacomp_ngp@...>
wrote:
> Hi,
> interrupt routine is very simple.
> void tc0_cmp(void)
> T0FLG=1;
> main1000++;
> // haul1000++;
> first interrupt works and there after stops.
> more than one variable it stops.
What version of GCC are you using?  Version 3.3 and older had bugs in
the interrupt entry/exit code that could show up like this.
Karl Olsen
Re: [lpc2000] Re: Timer/counter interrupt
2006-05-30 by Mukund Deshmukh
> > void tc0_cmp(void)
> > T0FLG=1;
> > main1000++;
> > // haul1000++;
No its winarm with gcc 4.0.
Best Regards,
Mukund Deshmukh.
Nagpur-440022
Cell - 9422113746
2006-05-30 by brendanmurphy37
Mukund,
Personally, I'd avoid the use of "interrupt" extensions to the
language. Not for the first time, I'd highly recommend the following:
http://www.ovro.caltech.edu/~dwh/ucos/project_AR1803.pdf
This has an excellent explanation of how to set up interrupts on the
LPC2xxx.
Brendan
> > > void tc0_cmp(void)
> > > T0FLG=1;
> > > main1000++;
> > > // haul1000++;
Bit 0
using.
bugs in
> Best Regards,
> Mukund Deshmukh.
> Nagpur-440022
> Cell - 9422113746
