Lpc2000
Problem with entering ISR
2006-05-29 by federr65
I'm just starting with LPC ( I have a LPC-H2138 board from Olicom) and
at the beginning I'm unable to solve the following problem:
I have an Timer0 set to generate interrupts. Timer works just fine,
but I can't force the ISR to execute.
Below is my code:
#include <targets/LPC213x.h>
#define LED 0xF0000000;
static int timer0Count, timer1Count;
int marker=1;
static void PLL_Init(void)
  PLLCON=0x00000003; //Kwarc razy 4
  PLLCFG = 0x23;
  PLLFEED = 0xAA;
  PLLFEED = 0x55;
void inititate (void)
//PLL_Init();
//MAMCR = 2;
IO0PIN=0x0;
IO1PIN=0x0;
IO0DIR = 0xFFFFFFFF;
IO1DIR = 0xFFFFFFFF;
static void timer0ISR(void) __attribute__ ((interrupt ("IRQ")));
if (IO0PIN=0)
  IO0SET=LED;
  else
  IO0CLR=0;
  /* Clear the timer 0 interrupt */
  T0IR = 0xFF;
  /* Update VIC priorities */
 VICVectAddr = 0;
  marker++;
int main(void)
inititate();
 // Timer 0 interrupt is an IRQ interrupt, none is FIQ */
  VICIntSelect =0x0;
  /* Clear all IRQ and Enable timer 0 interrupt */
  VICIntEnClr = 0xFFFFFFFF;
  VICIntEnable = 0x10;
  /* Use slot 0 for timer 0 interrupt and enable it (bit5)*/
  VICVectCntl0 = 0x24;
  /* Set the address of ISR for slot 0 */
  VICVectAddr0 = (unsigned int)timer0ISR;
  /* Match 0 reset - mo¿e nie byæ konieczne do dzia³ania*/
  T0IR = 0x1;
  /* Reset and stop timer 0 */
  T0TCR = 0x2;
  /* Set the timer 0 prescale counter */
  T0PR = 0x0;
  /* Set timer 0 match register */
  T0MR0 = 0xffff;
  /* Generate interrupt and reset counter on match */
  T0MCR = 0x3;
  /* Start timer 0 */
 T0TCR = 1;
   /* Enable Interrupts */
// __ARMLIB_enableIRQ();
while(1);
Re: Problem with entering ISR
2006-05-29 by willem_zx6r
try enabling the interrupt by removing the two slashes at calling the
function __ARMLIB_enableIRQ()...
> Below is my code:
> int marker=1;
>   PLLCFG = 0x23;
>   PLLFEED = 0xAA;
>   PLLFEED = 0x55;
> //PLL_Init();
> //MAMCR = 2;
> IO0PIN=0x0;
> IO1PIN=0x0;
> if (IO0PIN=0)
>   IO0SET=LED;
>   else
>   IO0CLR=0;
>   T0IR = 0xFF;
>  VICVectAddr = 0;
>   marker++;
> int main(void)
> inititate();
>   VICIntSelect =0x0;
>   T0IR = 0x1;
>   T0TCR = 0x2;
>   T0PR = 0x0;
>   T0MR0 = 0xffff;
>   T0MCR = 0x3;
>   /* Start timer 0 */
>  T0TCR = 1;
> while(1);
Re: [lpc2000] Re: Problem with entering ISR
2006-05-29 by Piotr Fedorowicz
> From: willem_zx6r
> To: lpc2000@yahoogroups.com
> Sent: Monday, May 29, 2006 2:55 PM
> Subject: [lpc2000] Re: Problem with entering ISR
> Hi,
Tried that already. Doesn't work :/
2006-05-29 by bobtransformer
> if (IO0PIN=0)
>   IO0SET=LED;
>   else
Also, did you mean to have the single equals sign in the if
statement instead of == ?   ...  if (IO0PIN=0)
boB
--- In lpc2000@yahoogroups.com, "willem_zx6r" <willem@...> wrote:
> Hi,
Olicom) and
fine,
> > Below is my code:
> > int marker=1;
> >   PLLCFG = 0x23;
> >   PLLFEED = 0xAA;
> >   PLLFEED = 0x55;
> > //PLL_Init();
> > //MAMCR = 2;
> > IO0PIN=0x0;
> > IO1PIN=0x0;
> > if (IO0PIN=0)
> >   IO0SET=LED;
> >   else
> >   IO0CLR=0;
> >   T0IR = 0xFF;
> >  VICVectAddr = 0;
> >   marker++;
> > int main(void)
> > inititate();
> >   VICIntSelect =0x0;
> >   T0IR = 0x1;
> >   T0TCR = 0x2;
> >   T0PR = 0x0;
> >   T0MR0 = 0xffff;
> >   T0MCR = 0x3;
> >   /* Start timer 0 */
> >  T0TCR = 1;
> > while(1);
> > if (IO0PIN=0)
> >   IO0SET=LED;
> >   else
I deleted the "=" mark accidentally while formatting the text for posting.
Some more info that I didn't included in my first post:
1. I'm using Crossworks 1.5
2. After Timer match registers are in following states:
VICIrqStatus: 0x00000010
VICRawIntr: 0x00002018
It looks like VICVectorAddr0 is not pointing to the ISR. I tried
adding #define VECTORED_IRQ_INTERRUPTS ; and replacing code in startup.s:
#ifdef VECTORED_IRQ_INTERRUPTS
  .word 0xB9205F84                              /* boot loader checksum */
  ldr pc, [pc, #-0xFF0]                         /* irq handler */
#else
  .word 0xB8A06F60                              /* boot loader checksum */
  ldr pc, [pc, #irq_handler_address - . - 8]    /* irq handler */
to:
#else
But it didn't work either.
Thanks for your attention.
Re: [lpc2000] Problem with entering ISR
2006-05-30 by 3gpabko
> if (IO0PIN=0)
>   IO0SET=LED;
>   else
>   IO0CLR=0;
Is this some typing error ???
Should be:
IO0CLR = LED;
Also try adding a default ISR or write this:
VICDefVectAddr = (unsigned long)timer0ISR;
And see what happens.
Zdravko
\u0417\u043d\u0430\u043d\u0438\u0435\u0442\u043e \u0435 \u043b\u0438\u0447\u043d\u043e \u043f\u0440\u0435\u0436\u0438\u0432\u044f\u043d\u0430 \u0438\u0441\u0442\u0438\u043d\u0430.
Do You Yahoo!?
http://mail.yahoo.com
2006-05-30 by federr65
> Should be:
> IO0CLR = LED;
Yes, it is.
I added this line, I also tried adding:
VICVectAddr = (unsigned long)timer0ISR;
But it didn't work also.
Best Regards
Peter
