Lpc2000
LPC214x crystal frequencies
2005-11-17 by Karl Olsen
Hello all,
To get the 48 MHz necessary for the LPC214x USB, you must use a crystal
of 12.0 MHz, 16.0 MHz, or 24.0 MHz.  None of these frequencies are
mentioned in the manual table 291 that lists the possible ISP baud
rates with various crystal frequencies.  Can you use serial ISP with
12/16/24 MHz, and with which baud rates?
Karl Olsen
RE: [lpc2000] LPC214x crystal frequencies
2005-11-17 by Joel Winarske
At 12MHz the highest the Phillips Flash utility will connect is 38.4k baud.
I cannot connect running a higher baud.
Joel
RE: LPC214x crystal frequencies
2005-11-17 by Steve Franks
> Message: 25
>    Date: Thu, 17 Nov 2005 09:37:47 -0800
>    From: "Joel Winarske" <joelw@...>
> Subject: RE: LPC214x crystal frequencies
> use a crystal
> is 38.4k baud.
> Joel
I've been doing serial stuff from some time and this matches my experience.
With an integer-MHz rate, the divisors are such that most all uart chipsets
will work fine up to 38.4k, after that the round-off error is too much for
the chipset to synch up with, which is why you see alot of 7.3828MHz,
14.xxx, and 3.8xx crystals on demo boards.  I do alot of analog->digital
stuff and off-freq's tend to make that nasty (more divisor round-off), so I
just put up with running my uarts a bit slower.  I've noticed alot of
off-shelf devices with serial ports running at 38.4k lately, and I suspect
the same argument applies.  If you grab any of the Atmel AVR datasheets
(i.e. AtMega128) they've done the math for you in the "UART" section to give
exact numbers for %error given a crystal freq and a baudrate/divisor combo.
They state that %err's above 10% are not healthy, but in practice, I've seen
cheap serial ports on Wintel boxes give me garbage with errors as low as 3%.
If you are into that sort of thing, Silicon Lab's CP2102 UART<->USB bridge
will do integer baud rates (i.e. 128.0k instead of 115.2k, up to 1.0M, I
recall) and that can get you up to higher rates if you need to, and give you
usb in a 7mm sq. package.  I think I'm going to go direct to implementing
the usb driver thread that's been going the last few days for new designs
myself...
Steve
Steve Franks, KE7BTE
Electrical & Firmware Engineer
Tucson Embedded Systems
(520) 575-7283 x171
(Opinions expressed are sole-ly that of Mr. Franks, and not Tucson Embedded
System)
I've always thought the American eagle needed a left wing and a right wing.
The right wing would see to it that economic interests had their legitimate
concerns addressed. The left wing would see to it that ordinary people were
included in the bargain. Both would keep the great bird on course. But with
two right wings or two left wings, it's no longer an eagle and it's going to
crash.
    -Bill Moyers
Re: [lpc2000] LPC214x crystal frequencies
2005-11-17 by Ake Hedman, eurosource
Same here.
/Ake
> baud.
> Joel
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavägen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 84 84 102
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
Re: LPC214x crystal frequencies // ISP max baudrate 38.4 kBaud using 12 MHz
2005-11-17 by philips_apps
All,
based on the algorithm the bootloader uses to determine the
baudrate, as Joel already found out, it is correct that the max
baudrate for 12 MHz is 38400 Baud.
Will do some additional tests to determine the baudrates for 16 MHz
and 24 MHz but we assume that 12 MHz will be the most used crystal
as it provides functionality for USB and enables the 60 MHz max. CPU
speed as well.
Sorry for not providing the appropriate values in the table for the
ISP, will update with the next reloease of the Users Manual but that
might still take a little while.
Robert
crystal
are
baud
with
38.4k baud.
> Joel
Re: [lpc2000] Re: LPC214x crystal frequencies // ISP max baudrate 38.4 kBaud using 12 MHz
Robert,
I must say I like the responsiveness of Philips (through you) *a lot*
on this list. This is exactly what many of us embedded consultants
really need. Philips has been very low on my "design in" list before.
Mostly because of the low interest for us who design solutions for
others but never buy a lot of components ourselves.But I think this is
about to change.  I hope Philips will be as good as Microchip and others
on samples and app. notes in he future. You are definitely on the way...
Keep up the good work!!!
/Ake
philips_apps wrote:
> All,
> speed as well.
> Robert
> crystal
> are
> baud
> with
> 38.4k baud.
> > Joel
> YAHOO! GROUPS LINKS
2005-11-17 by Robert Wood
on samples and app. notes in he future. You are definitely on the way... <<
Yep, things are very different these days. Nearly everything is built in
the far east, but the designs are still often done in Europe. The
manufacturers simply have to support small design houses or they
wouldn't sell silicon!
2005-11-17 by seangra
Based on my calculations, 16MHz can only get to 19,200 (7% error at
38,400) and 24MHz can get 38,400.  If you went up to 48MHz crystal
you could get 57,600.
-- Sean
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...>
wrote:
> All,
MHz
CPU
> speed as well.
that
> Robert
a
> crystal
> are
> baud
ISP
> with
> 38.4k baud.
> > Joel
Confirmed
12 MHz  ->  max baudrate 38400
16 MHz  ->  max baudrate 19200
24 MHz  ->  max baudrate 38400
Robert
at
> -- Sean
> wrote:
> > All,
> MHz
crystal
> CPU
> > speed as well.
> the
> that
> > Robert
use
> a
> > crystal
frequencies
> > are
ISP
> > baud
> ISP
> > with
is
> > 38.4k baud.
> > > Joel
2005-11-18 by Martin Maurer
Hi Robert,
is there any plan to use the fractional baudrate generation in the booter,
so you can boot e.g. even at 921 kbit/s with a 12 MHz oscillator ?
Theoretically it should be possible, hardware is supporting it...
         Martin
To: <lpc2000@yahoogroups.com>
Sent: Friday, November 18, 2005 12:12 AM
Subject: [lpc2000] Re: LPC214x crystal frequencies // ISP max baudrate 38.4
kBaud using 12 MHz
> Confirmed
> Robert
> at
>> -- Sean
>> wrote:
>> > All,
>> MHz
> crystal
>> CPU
>> > speed as well.
>> the
>> that
>> > Robert
> use
>> a
>> > crystal
> frequencies
>> > are
> ISP
>> > baud
>> ISP
>> > with
> is
>> > 38.4k baud.
>> > > Joel
2005-11-18 by philips_apps
Hi Martin,
there are no immediate plans to use the fractional baudrate
generator because we try to keep the number of different bootloaders
limited. Also it is very difficult to use the fractional BR
generator if the frequency of the oscillator is not known.
Last but not least it is not possible to go 921 kbaud with 12 MHz
because the max serial frequency with or without fractional baudrate
generator is CPU clock divided by 16 and the bootloader does not
change the PLL settings.
Regards, Robert
--- In lpc2000@yahoogroups.com, "Martin Maurer" <mailingliste@c...>
wrote:
> Hi Robert,
booter,
> Regards,
>          Martin
> From: "philips_apps" <philips_apps@y...>
baudrate 38.4
> kBaud using 12 MHz
> > Confirmed
> > Robert
> > at
crystal
> >> -- Sean
<philips_apps@y...>
> >> wrote:
> >> > All,
max
16
> >> MHz
> > crystal
max.
> >> CPU
> >> > speed as well.
for
> >> the
but
> >> that
> >> > Robert
> > use
> >> a
> >> > crystal
> > frequencies
> >> > are
> > ISP
> >> > baud
serial
> >> ISP
> >> > with
> > is
> >> > 38.4k baud.
> >> > > Joel
> > Yahoo! Groups Links
2005-11-18 by seangra
Considering how we're dealing with flash sizes up to 512KB now, and
loading that much data at 38.4kbps is significantly slower than
230kbps, are there any plans to fix this problem?
Or better yet, consdering the speed, are there any plans to create a
USB-based bootloader?  Doesn't the SAM7S have this already?
Additionally since there are some chips (FTDI comes to mind) that
allow a WIDE range of baud rates, is it possible to use the current
bootloader with a nonstandard baud rate?  I.e. 12MHz can generate
187.5kbps with the same settings that 14.5796MHz uses to generate
230kbps.  I know the FTDI chip can handle 187.5kbps.
-- Sean
wrote:
> Hi Martin,
bootloaders
baudrate
> Regards, Robert
<mailingliste@c...>
> wrote:
> > Hi Robert,
> booter,
oscillator ?
> > Regards,
> >          Martin
> baudrate 38.4
> > kBaud using 12 MHz
> > > Confirmed
> > > Robert
error
> > > at
> crystal
> > >> -- Sean
> <philips_apps@y...>
> > >> wrote:
> > >> > All,
> max
for
> 16
> > >> MHz
> > > crystal
> max.
> > >> CPU
> > >> > speed as well.
> for
> > >> the
> but
> > >> that
> > >> > Robert
must
> > > use
> > >> a
> > >> > crystal
> > > frequencies
> > >> > are
possible
> > > ISP
> > >> > baud
> serial
> > >> ISP
> > >> > with
connect
> > > is
> > >> > 38.4k baud.
> > >> > > Joel
> > > Yahoo! Groups Links
Power consumption LPC214x
2005-11-18 by Marko Pavlin (home)
Hello!
Datasheet
http://www.semiconductors.philips.com/acrobat_download/datasheets/LPC2141_42_44_46_48_1.pdf
has <TBD> tag for active mode supply current. Has anyone measured this
on LPC214x device?
Are there any very low power ARM7 microcontrollers available (other than
philips), or are those two words a paradox (low-power and ARM7)?
Mare
Re: Power consumption LPC214x
2005-11-18 by slawcus
--- In lpc2000@yahoogroups.com, "Marko Pavlin (home)" <mp@h...> wrote:
> Hello!
> Datasheet
> on LPC214x device?
than
> Mare
Define very low power.
I just measured RTC consumption.  It's same as LPC2138s.
I don't like just two power saving modes, no additional cclk division,
 sub MHz PLL, etc. These are things that can help to reduce
consumption in some applications.
Re: [lpc2000] Re: Power consumption LPC214x
"Ultralowpower" would be something in MSP430 range (not ARM core), or
close to 1mA in active mode / sub-100uA in kinda active mode with fast
wakeup (via some software /internal periphery interrupt).
"Verylowpower" is, let's say 10 times higher than above.
Mare
