Lpc2000
Problems with olimex (wiggler) jtag and olimex lpc2129 proto board
2005-11-22 by compuguru64
Newb - I can't seem to get my wiggler compatible to talk to my olimex
proto board.  I've tried it on 2 laptops, 800 mhz and 2.8 ghz machines,
various parallel port speed settings.  I'm using OCD Commander and
always get an Internal Error 43 message, then "Error Response from
INITIALIZE: 0x03 initialize_target : cable disconnected  (10 : 03)"
I'm using OCD Commander 2.4.1 that comes with IAR jumpstart compiler.
I've followed posts warning about system speed, about making sure pins
8 and 15 are shorted on the wiggler, about making sure the debug jumper
is installed, about making sure the parallel port is not set to ECP -
all verified yet nothing seems to work.  Shouldn't I at least be able
to start OCD Commander with no warning messages and use it to reset the
board even if the default flash-based program it was shipped with is
still on it?  The default program appears to work just fine when the
JTAG cable is disconnected.
RE: [lpc2000] Problems with olimex (wiggler) jtag and olimex lpc2129 proto board
2005-11-22 by Joel Winarske
Are you debugging out of RAM or from Flash?
If RAM, under options/debugger do you have a macro file defined?
You might also try:
Enable Hardware reset under Macraigor, define time to 0.
Joel
2005-11-22 by Karim Virani
I understand that the wiggler will only let you debug in RAM, and in IAR
linker options I do have the RAM xcl file selected.  In debugger options
I don't have any startup macro file defined - I'm not sure what I should
be using.  I did enable hardware reset like you recommended, but that
didn't work either.
Since I'm new to the IAR environment too, I thought I would simplify by
just using OCD Commander directly.  I'd like to know of something that
should always work in OCD Commander regardless of what is in RAM or in
Flash on the board - so I can eliminate the olimex jtag as the problem.
I had assumed that performing a RESET from OCD Commander should always
work - but that's just a guess.
Karim
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of Joel Winarske
Sent: Monday, November 21, 2005 11:05 PM
To: lpc2000@yahoogroups.com
Subject: RE: [lpc2000] Problems with olimex (wiggler) jtag and olimex
lpc2129 proto board
You might also try:
Joel
machines,
jumper
Yahoo! Groups Links
Re: [lpc2000] Problems with olimex (wiggler) jtag and olimex lpc2129 proto board
2005-11-22 by haare_in_der_dusche
There is reasonable doubt that OCD commander works at all on more
sophisticated Windows versions.
The wiggler hardware itself works perfectly when used with Rowley
Crossworks, but OCD commander just doesn't work.
And that happens also with an original "Wiggler" made by Macraigor.
Apparentyl you'll have either to
- replace OCD commander by something better (Rowley Crossworks)
- use a braindead Windows version like Windows 95 or one of it's
re-brews (98 & Me).
___________________________________________________________
Gesendet von Yahoo! Mail - Jetzt mit 1GB Speicher kostenlos - Hier anmelden: http://mail.yahoo.de
Oh man!  I swear I saw references to OCD Commander working on Win2K and XP, maybe in Jim Lynch's eclipse tutorial?  I thought it was just a system speed issue.  I wanted to follow the Olimex recommendation for Rowley, but this is a hobby for me and Rowley isn't wife-friendly expense-wise.  I'll see if I can dig up a really old system from somewhere.  I hope Olimex comes up with the rumored affordable usb-jtag soon.
Karim
Of haare_in_der_dusche
Sent: Tuesday, November 22, 2005 10:09 AM
Subject: Re: [lpc2000] Problems with olimex (wiggler) jtag and olimex
lpc2129 proto board
re-brews (98 & Me).
Yahoo! Groups Links
2005-11-22 by FreeRTOS Info
For what its worth - I use wiggler/olimex/OCDLibRemote on Win2k no problem.
Never tried Commander though.
Richard.
http://www.FreeRTOS.org
Re: Problems with olimex (wiggler) jtag and olimex lpc2129 proto board
2005-11-22 by rtstofer
Eclipse -> Insight -> OCDRemote with the ARM-JTAG device from
Sparkfun does work on Windows XP, more or less.  The less part is
that it only connects after pounding on it (figuratively) for a
dozen or more times.  Pretty much what is explained in the tutorial.
However...  What if the LPC didn't have JTAG?  What would you do for
debugging?  Well, just do that.  I don't have enough pins to leave
spares for JTAG, the debugger doesn't work often enough to tolerate
so I just don't bother.  I start by writing basic character IO
functions, add a string output function and an itoa() function and
I'm on my way.
It is certainly possible to bring up large embedded systems without
JTAG.  It is probably easier with it but, sometimes, that't the way
it goes.
I am using the bootloader at 115.2K baud so programming goes pretty
quick.
Richard
Win2K and
a system
Rowley, but
wise.  I'll
Olimex comes
problem.
> Regards,
> Richard.
> didn't work either.
Your IAR debug macro file must have the following in order to debug from
RAM:
execUserPreload()
    __writeMemory32(0x00000002, 0xE01FC040, "Memory"); // MEMMAP = 2;
Joel
Re: [lpc2000] Re: Problems with olimex (wiggler) jtag and olimex lpc2129 proto board
2005-11-22 by Bill Knight
Something that has helped me connect to the LPC with OCDRemote is to
put the LPC into Boot Loader mode first.
-Bill Knight
R O SoftWare &
http://www.theARMPatch.com
>I'm on my way.
>it goes.
>quick.
>Richard
>Win2K and
>a system
>Rowley, but
>wise.  I'll
>Olimex comes
>problem.
>> Regards,
>> Richard.
>Yahoo! Groups Links
2005-11-22 by Viron Papadopoulos
What is neeeded (hardware & software) to debug in
FLASH?
Viron.
> In debugger options
> didn't work either.
> I would simplify by
> of something that
> Karim
> Of Joel Winarske
> lpc2129 proto board
> file defined?
> You might also try:
> to 0.
> Joel
> and 2.8 ghz
> machines,
> OCD Commander and
> jumpstart compiler.
> sure the debug
> jumper
> is not set to ECP -
> I at least be able
> and use it to reset
> the
> was shipped with is
> just fine when the
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
2005-11-22 by Dominic Rath
If this is a hobby for you and you're willing to spend some time, instead of
money (not really wife-friendly either...) mail me off-list. I'm looking for
testers/users for my open-source (GPL) ARM7/ARM9 debugger. Currently, this is
linux-only software, and I don't plan to port it to windows (could be ported
quite easly, but I see no reason). It supports wiggler (parport) compatible
devices and FT2232c (usb 1.1) based interfaces.
Dominic
> Karim
> FLASH?
Which compiler?  I'll presume IAR as that's what the thread started was
enquiring about:
General Options, Debugger, Download tab:
If ....(default) is not in pane, select edit, new, ok, ok.
This will Flash your part upon entering debug.
Keep in mind the core only supports two hardware breakpoints.  Depending on
your debug settings one may be used by Clib stdio.
Joel
2005-11-24 by Karim Virani
Since Crossworks is supposed to be bulletproof with wigglers, so I
downloaded a trial copy. It won't connect to the target - I get the
message "Cannot identify target. Check JTAG Connections and that the
target is powered" Same message as when there's nothing connected to the
parallel port.
Is it more likely that my olimex-jtag is DOA or it's the jtag port on
the 2129 board? If the olimex-jtag adapter is fried, can it endanger the
board - I have a 2nd board I can try, but don't want to risk frying it.
Karim
Of Joel Winarske
Sent: Tuesday, November 22, 2005 11:50 AM
lpc2129 proto board
IAR
options
should
> didn't work either.
RAM:
execUserPreload()
Joel
Yahoo! Groups Links
2005-11-24 by Dan Beadle
Are you sure that the jumpers are installed to enable JTAG?
The JTAG port is pretty rugged - so unlikely that you fried it.
The ports are pull up to the 3.3V on the jtag port - so not likely that
you would do any damage.  I would try the other board, check the jumpers
first (there is a jumper that tells the chip to use JTAG, otherwise it
is ignored)
Dan
  _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of Karim Virani
Sent: Wednesday, November 23, 2005 5:21 PM
lpc2129 proto board
parallel port.
Karim
Of Joel Winarske
lpc2129 proto board
IAR
options
should
> didn't work either.
RAM:
execUserPreload()
Joel
Yahoo! Groups Links
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
Yes - I have the debug jumper installed, the bsl and jrst jumpers are
open.  I tried the other board - same response.  I think I got a bum
wiggler.
Karim
Of Dan Beadle
Sent: Wednesday, November 23, 2005 7:24 PM
lpc2129 proto board
is ignored)
Dan
  _____
Of Karim Virani
lpc2129 proto board
parallel port.
Karim
Of Joel Winarske
lpc2129 proto board
IAR
options
should
> didn't work either.
RAM:
execUserPreload()
Joel
Yahoo! Groups Links
  _____
YAHOO! GROUPS LINKS
  _____
Yahoo! Groups Links
2005-11-24 by Michael Johnson
Hi Karim,
Do you have another computer you can try? It could be that your PC
parallel port isn't working.
Michael
>parallel port.
>Karim
>-----Original Message-----
>Of Joel Winarske
>lpc2129 proto board
>IAR
>options
>should
>>didn't work either.
>RAM:
>execUserPreload()
>Joel
>Yahoo! Groups Links
>Yahoo! Groups Links
2005-11-24 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Thursday, November 24, 2005 6:58 AM
lpc2129 proto board
> Hi Karim,
Make sure the port is set for EPC mode.
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Yes - I went back to the original modern laptop and it works with Rowley!  Must've had something off on the parallel port on the older system (though I can use it for other bidirectional, non ecp applications).  Still can't use the newer system with IAR or OCDCommander - it doesn't even recognize the wiggler.  At least I know the jtag hardware works.
So Rowley works like a dream - I can connect via the wiggler, I can download and I can set hardware breakpoints and debug from flash in it.  Goes back to the old price problem for hobbyists.  Maybe they'll sell me an academic licence.  The other problem is that there are many fewer examples.  There's no complete set of header files and examples for the olimex 2129 proto board like there are in IAR.
And is most of the example and free code out there implemented for the gnuarm chain?  I'm entirely new to microconrollers.  Perhaps I should go with Jim Lynch's environment and not worry about flash debugging for now.  I'm under the impression that OCDLibRemote in cygwin doesn't have the same problems that OCDCommander running natively in Windows has.  Is that right?
Karim
Of Michael Johnson
Sent: Thursday, November 24, 2005 12:59 AM
lpc2129 proto board
Hi Karim,
Michael
>parallel port.
>Karim
>Of Joel Winarske
>lpc2129 proto board
>IAR
>options
>should
>>didn't work either.
>RAM:
>execUserPreload()
>Joel
>Yahoo! Groups Links
>Yahoo! Groups Links
Yahoo! Groups Links
2005-11-24 by Paul Curtis
We have considered a low-cost Hobbyist license, but this opens us up to
abuse of our licensing terms.  I also have the very real concern that
this would be perceived as a "Well, they must be in trouble, trying to
squeeze the hobbyist market to make ends meet..."  Introl introduced
hobbyist licenses just before they went south for winter and stayed
there.  I would really need to be persuaded that a hobbyist license is a
viable product.
Pardon?  We support a wider range of boards than IAR do with examples
for each one of them.  In the v1.6 release it will be even wider.
> There's
What specific example does IAR provide in the EW package for the
E2124/9?  We supply header files for the LPC2129.  The LPC-E2124/9 has a
port of uIP that I did on our website.
Paul Curtis, Rowley Associates Ltd  http://www.rowley.co.uk
CrossWorks for MSP430, ARM, AVR and now MAXQ processors
2005-11-24 by Simon Bosworth
Paul,
could you do a 'reduced speed' version at a lower price? Just a thought.
Simon
  Sent: Thursday, November 24, 2005 2:34 PM
  Subject: RE: [lpc2000] Problems with olimex (wiggler) jtag and olimex lpc2129 proto board
  viable product.
  > There's
  SPONSORED LINKS Microprocessor  Microcontrollers  Pic microcontrollers
        8051 microprocessor
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-11-24 by Joel Winarske
Hi Paul,
LPC2K support in IAR EW-ARM v4.30A Kickstart
Headers:
06/20/2005  08:24 PM            34,751 iolpc210x.h
06/20/2005  08:24 PM            40,067 iolpc210x_old.h
06/20/2005  08:24 PM            38,446 iolpc2114.h
06/20/2005  08:24 PM            49,970 iolpc2119.h
06/20/2005  08:24 PM            38,447 iolpc2124.h
08/29/2005  09:46 AM            49,788 iolpc2129.h
06/20/2005  08:24 PM            44,208 iolpc2130.h
06/20/2005  08:24 PM            37,931 iolpc2131.h
06/20/2005  08:24 PM            41,067 iolpc2132.h
06/20/2005  08:24 PM            41,067 iolpc2134.h
06/20/2005  08:24 PM            41,067 iolpc2136.h
06/20/2005  08:24 PM            41,108 iolpc2138.h
06/20/2005  07:50 AM               475 iolpc2142.h
11/08/2005  03:45 PM            50,903 iolpc2148.h
06/20/2005  08:24 PM            53,066 iolpc2194.h
06/20/2005  08:24 PM            42,699 iolpc2212.h
06/20/2005  08:24 PM            42,699 iolpc2214.h
06/20/2005  08:24 PM            53,497 iolpc2292.h
06/20/2005  08:24 PM            56,598 iolpc2294.h
Examples:
08/14/2005  12:58 PM    <DIR>          LPC210x
10/16/2005  11:57 AM    <DIR>          LPC212x
08/14/2005  12:58 PM    <DIR>          LPC213x
08/14/2005  12:58 PM    <DIR>          LPC214x
08/14/2005  12:58 PM    <DIR>          LPC22xx
Joel
Hi Joel,
That isn't an *example*, that's just a set of header files.
> From: Joel Winarske [mailto:joelw@...]
> Sent: 24 November 2005 21:10
> Hi Paul,
> LPC-E2124/9 has a
> Headers:
> Examples:
> Joel
> 1.2 million kids a year are victims of human trafficking.
> Stop slavery.
> http://us.click.yahoo.com/WpTY2A/izNLAA/yQLSAA/dN_tlB/TM
Simon,
> Paul,
> a thought.
That doesn't really address the root problems of the Hobbyist License.
Our Educational License software is identical to the Commercial License
software, only difference being the use that is made of it.
We have given a number of licenses to worthy users absolutely free of
charge so they can pursue projects that may or may not make money--on
the understanding that if the project starts coining it, then a license
is purchased.  This has worked well for us.  But this is different from
the Hobbyist License which is just a "I want to tinker" license.
I would like to help hobbyists, for sure, as we have done for university
and research work with our very generous educational discounts (they are
just 20% of our commercial prices).  The educational licenses have been
very popular, being taken up by a wide range of universities and
research institutes around the world.
The problems are as I stated, a hobbyist license is open to abuse by
companies masquerading as hobbyists and also the perception of squeezing
the last drop of money out of our customer base by offering hobbyists
licenses to prop up sales.  I can't see how to resolve the hobbyist
license other than by having the hobbyist sign a document (as CadSoft do
for example). And we don't need revenue from hobbyists because
CrossWorks is successful enough on its own.
We have had endless conversations about the hobbyist license here and
although I'd like to be philanthropic and introduce such a license, the
last throes of Introl hoping hobbyists would help prop up the company is
strongly implanted in my mind.
So, tell me how can I be persuaded on this?  My leaning would be to
introduce a hypothetical "hobbyist license" at, say, £99 and require the
user to sign an undertaking of no commercial use.  However, I really do
need to be convinced that this is a good thing...
>   Hi,
> opens us up to
> concern that
> trouble, trying to
> license is a
>   viable product.
> with examples
>   > There's
> LPC-E2124/9 has a
> microcontrollers
>         8051 microprocessor
>   YAHOO! GROUPS LINKS
> Terms of Service.
> Get fast access to your favorite Yahoo! Groups. Make Yahoo!
> your home page
> http://us.click.yahoo.com/dpRU5A/wUILAA/yQLSAA/dN_tlB/TM
Hi Joel,
> Ah yes.  I'm too quick with the fingers and not quick enough
> in the head
> sometimes. IAR has no example for the the LPC-E2124.  Your link is
> prominently displayed on olimex.com for the LPC-E2124 product.
> What sort of through put are you able to sustain with your
> code on this board?
Good question, never bothered to test it.  Note that uIP has some
restrictions and doesn't interoperate well with delayed-ACK
implementations as uIP can only have a single segment in flight at any
one time.  If you don't understand this implication, you'll need to have
a look at a good book on Internet protocols or the RFCs.
Hi Paul,
Ah yes.  I'm too quick with the fingers and not quick enough in the head
What sort of through put are you able to sustain with your code on this
board?
Joel
2005-11-24 by rtstofer
require the
really do
> Regards,
From a business point of view, a larger user base is a good thing;
any level of user.  Hobbyists probably break down into two
categories:  those who are working in industry in a different but
vaguely related field and may someday develop commercial
applications with the software and those, like me, who are retired
or working in an unrelated field and will never contribute to your
profits.
I don't see how it would make sense to provide a hobbyist license to
those who will never develop commercial applications.  But, if you
do, sign me up!
Richard
2005-11-25 by compuguru64
I can only speak for myself.  I'm a professional programmer of
vertical business applications.  I also consider myself a perpetual
student.  My hobby is robotics and I take it seriously.  I consider
the hobby to be preparation for an alternate career path.  If
personal robotics ever takes off enough and can support more people
in the field, then I would be happy to make a career move.  At that
point I would be happy to pay for the professional tools needed.  In
the meantime I'm always a student, even if I'm only sporadically
taking courses at community college to refresh atrophied skills like
linear algebra (for vision processing).
So I guess I'm saying that I don't see much of a neccessary
difference between intense hobby and more formal student activities
(regarding learning intent - I'm not talking about business
models).  Not everyone into hobbies is retired.  I'm a member of the
Dallas Personal Robotics Group, and only a couple of the guys in
that group are retired.  The rest are like me - eager to learn,
possibly in preparation for a career move, or otherwise hoping to
hit on a commercial angle.  If I got lucky and built something with
commercial potential I'd be happy to opt into a full commercial
license for the tools I'm using.
to
> require the
> really do
> > Regards,
> profits.
to
> do, sign me up!
> Richard
RE: [lpc2000] Re: Problems with olimex (wiggler) jtag and olimex lpc2129 proto board
2005-11-25 by Paul Curtis
This is the sort of feedback that is useful.  I think we've been very
good in providing free licenses and (in some cases) hardware to many
users for their use--but we don't shout about it.  I may actually put a
page up on the website with the more interesting projects we have
supported, but we have sent more keys to "intense hobbyists" that have
the front to contact us directly.  I'm getting soft... :-)
I *know* that I'd like to do something for hobbyists, but I'm really
unsure as to what the impression would be.  The current company policy
is to offer what *I* would like to see from a company if I used its
tools.  That is, we fix bugs free of charge because we made the mistake,
and we offer e-mail support that isn't limited because if users have
problems then it's a documentation issue or should be covered by a FAQ.
In the three years that we've been selling CrossWorks for MSP430, our
original users have never needed to pay for an upgrade.  However, I can
say now, that when v2 ships, there *will* be a small cost associated
with it because it's a major upgrade in function.
Sorry, I'm rambling.
> From: compuguru64 [mailto:karim@...]
> Sent: 25 November 2005 00:24
> Subject: [lpc2000] Re: Problems with olimex (wiggler) jtag
2005-11-25 by Joel Winarske
> > code on this board?
Yes, yes I'm aware of all the latter.  I'm just looking for a rough unit of
measure; To determine if it might be applicable in a commercial product.
Perhaps it's a better fit for the hobby market?
Joel
2005-11-25 by Michael Rubitschka
Hi Paul
I think your free licences requests will explode after this email ;-)
I am also thinking to take heart to send one.
Cheers
Michael
>From: "Paul Curtis" <plc@...>
>Reply-To: lpc2000@yahoogroups.com
>Subject: RE: [lpc2000] Re: Problems with olimex (wiggler) jtag and olimex
>lpc2129 proto board
>Date: Fri, 25 Nov 2005 00:31:52 -0000
Joel,
> > > code on this board?
> flight at any
> need to have
> rough unit of
> commercial product.
I believe uIP is now used in a number of commercial products and I'd say
that it isn't just for a hobby market.  I have uIP running on an EDTP
AirDrop-A with a WiFi driver I wrote and integrated into uIP so I can
telnet into the AVR wirelessly and run my NetBASIC interpreter on it.
OT: Aidrop
Is it possible to run Airdrop (after some modifications) on an SD Wlan card?
Adrop has a top priority on my to do list, but I don't like compact flash
cards.
A SD card is so much easier to work with.
Cheers
Michael
>lpc2129 proto board
>Date: Fri, 25 Nov 2005 10:52:13 -0000
RE: [lpc2000] OT: Aidrop
Michael,
> an SD Wlan card?
I'm sure it is.  If you are a member of the AirDrop Yahoo! hroup, then
you'll have seen that some people are working on using SDIO.  The
AirDrop itself doesn't have an SD connector, so that hardware platform
is not likely to help you.
> compact flash cards. A SD card is so much easier to work with.
The WiFi adapters that are readily available are all SDIO as far as I
can tell.  There was some e-mails on the AirDrop group about
publicly-available information on SD/SDIO.  However, concensus was that
you'd probably need to stump up the cash to become a member of the SDIO
club.  I'm not sure how far that will get you because the SDIO interface
is one thing, the way to access the chipset/firmware is another which
may require vendor support.
The nice thing about the CF cards available is they all use one or other
of the two available chipsets, and a lot of work has been put into the
AirDrop PRISM drivers by quite a number of people, so that does work.
[lpc2000] Low power RTOS or "normal" program only with interrupts?
2005-11-25 by Marko Pavlin (home)
I am looking for (RT)OS for LPC210x for wireless sensor. Sensor itself
runs for less than 1% of all time. It should be in powerdown mode during
the remaining 99% of  time. Is it possible to run RTOS in such way that
idle process switch the power-down mode after no task is active for some
time? Wakeup would be via external interrupt or RTC.
2005-11-26 by Karim Virani
Paul,
>However, I really do need to be convinced that this is a good thing...
OK, let me try.  You've expressed a number of concerns:
1. Abuse mitigation
2. Perception management
3. The business case
Regarding abuse mitigation - I think hobbyists would be happy to sign a document promising to upgrade to a commercial license if their use of the product led in a for-profit direction.  I would.  It might, however, be costly to administer.  You could also require proof of membership in an established hobby group.  The Dallas Personal Robotics Group (autonomous, not remote control oriented robots) has a membership page on their website - http://www.dprg.org/members.html.  Most established groups have a similar way to verify membership as it's not new to offer discounts to club members.  This approach would, however, lock out some legitimate but unaffiliated intense hobbyists.  But we can't complain if that's the route you take.
Regarding perception management.  I don't think it's a big issue.  Your own perception of Introl seems mostly due to your knowledge of their failure and that the move was a desperation measure.  It was particularly desperate if they were needing to get real immediate revenue from the hobby market - it just isn't there.  In your case, it's known that crossworks is doing well.  If you decide to support the hobbyist market, it'll be seen as a sign of strength, you can commit to a move that has insignificant immediate benefit, but could have a longer term payoff.  You can afford to invest in good will.
Regarding the business case.  I'd think of it as developing long-term market potential and brand recognition more than direct revenue.  In the robot hobbyist culture, folks can't afford traditional high-end development environments, much as we desire them.  In fact, the availability of a suitable development environment is the most restrictive factor in moving to newer microcontrollers like the ARM family.  I'm certain that 32bit microcontrollers have many advantages over the PICs and AVRs most used for autonomous robots, and I'm eager to lead us in that direction.  If DPRG had a couple of licenses for use in our lab (we have a dedicated warehouse with a number of machines for programming where members meet at least weekly), then more folks would become aware of the possibilities.  But they'd still need access to the discussed hobbyist license so they could take their work home and really commit to the switch.  Some will still go the gnuarm route either for a totally free solution or because of open-source religion, but most of us would be drooling to use a truly professional environment.
Regarding potential.  Many of these folks will remain hobbyists, but some will move on to become professionals in the field.  It's happened many times at DPRG.  We have about 60 members right now, but hundreds more worldwide participate on our list.  Seattle Robotics is even bigger and there are numerous other significant groups in this one hobby alone.  A very large percentage of us are programmers or electrical engineers.  It wouldn't hurt to develop a reputation among this crowd.  And ultimately it will lead to commercial conversion sales.  Possibly at a similar rate that your educational license does.  It'll also lead to a larger base of shared code examples written for your environment.  It's an investment in momentum.
It's also reasonable to expect that you might limit costs by limiting support (telephone and email - something worth paying for in for-profit settings) for this license.  I'd still hope that you would offer free minor version upgrades and forum-based support.  I'd also suggest targeting $99 US as the price tag - 3 figures throw up a real mental block for most hobbyists.  These individuals are not in the same category as educational institutions.
So that's my spiel. Best wishes,
Karim Virani
Of Paul Curtis
Sent: Thursday, November 24, 2005 3:41 PM
lpc2129 proto board
Simon,
> Paul,
> a thought.
>   Hi,
> opens us up to
> concern that
> trouble, trying to
> license is a
>   viable product.
> with examples
>   > There's
> LPC-E2124/9 has a
> microcontrollers
>         8051 microprocessor
>   YAHOO! GROUPS LINKS
> Terms of Service.
> your home page
Yahoo! Groups Links
