Lpc2000
Interrupt pending but not raised
2005-12-06 by andersryl
I have a very peculiar problem regarding interrupts on my Olimex
E2214 board (using gcc and gld with Eclipse).
I'm trying to get my board to communicate with a Windows application
using the UART1. The way it works is that the Win app sends frames
with commands to the test board to which the ARM responds by sending
a new frame back to the PC. I have set the UART1 to give interrupts
when the RxFIFO is filled with 8 bytes.
Each frame consists of 12 to 100 bytes (11 bytes header and 1-89
bytes of data).
The communication works fine the first 4 rounds (request+reply).
However the fifth time the Win app starts sending a "request-frame"
the ARM does not generate any interrupts. I can see that there are
interrupts pending (by debug print-outs with the other UART from a
busy-waiting loop*) and that the peripherals that should give
interrupts are enabled to do so.
I also have a timer running giving an interrupt after 2 seconds if
no data is received (should not happen in normal operation due to
frequent requests from the Win app). This timer interrupt works fine
until the Win app starts sending frames. After the last request
(as described above) this interrupt is also pending but no interrupt
is raised.
From debug print-outs from the ISRs I also see that I never leave my
two ISRs (One for UART1 and one for Timer0) with any interrupts
pending.
*) Debug print-outs after the fifth Win app request frame:
VICIRQStatus: 0x00000080
VICIntEnable: 0x00000090
VICVectAddr:  0x000000D4
T0IR:               0x00
T0TCR:              0x01
T0MCR:            0x0003
U1IIR:              0xC4
VICIRQStatus: 0x00000090
VICVectAddr:  0x00000000
T0IR:               0x01
T0TCR:              0x01
T0MCR:            0x0003
U1IIR:              0xC4
Sorry about the long post.
Any help is greatly accepted.
/Anders
Re: [lpc2000] Interrupt pending but not raised
2005-12-07 by 3gpabko
On the first thought you have problems in your ISR's.
Perhaps you are not correctly handle and acknowledge
IRQ's.
Be sure that before exiting the ISR you are correctly
clearing the interrupt flags in the peripheral
registers(UART and Timer) and that you have a write to
the VICVectAddr register in the VIC in order to update
the VIC priority.
Hope this helps.
Zdravko
--- andersryl <andersryl@...> wrote:
> Hi,
> on my Olimex
> Windows application
> app sends frames
> responds by sending
> give interrupts
> header and 1-89
> bytes of data).
> (request+reply).
> "request-frame"
> that there are
> other UART from a
> should give
> after 2 seconds if
> operation due to
> last request
> but no interrupt
> is raised.
> I never leave my
> interrupts
> pending.
> frame:
> T0IR:               0x00
> T0TCR:              0x01
> T0MCR:            0x0003
> U1IIR:              0xC4
> T0IR:               0x01
> T0TCR:              0x01
> T0MCR:            0x0003
> U1IIR:              0xC4
> /Anders
__________________________________________
Yahoo! DSL \ufffd Something to write home about.
Just $16.99/mo. or less.
dsl.yahoo.com
Re: Interrupt pending but not raised
2005-12-07 by andersryl
Thanks for your reply.
The fact that the ISR's servicing the interrupts from both UART1 and
Timer0 work up to a certain point makes me think that the ISR's are
working properly. I'm not 100% sure though...
Here is the code for the ISR's if anyone wants to have a look:
irq.s:
UART1_Routine:	subs	lr, lr, #4
		stmfd	sp!, {R0-R12, lr}
		ldr	r4, =UART1Handler
		mov	lr, pc
		bx	r4
		ldmfd	sp!, {R0-R12, pc}^
/* End UART1_Routine */
Timer0_Routine:	subs	lr, lr, #4
		ldr	r4, =Timer0Handler
		mov	lr,pc
		bx	r4
/* End Timer0_Routine */
main.c:
void UART1Handler (void) {
   BYTE stat;
   WORD i;
   stat = U1IIR & 0x0F;
   while (stat != 1) {
      switch (stat) {
      case 4:	/* Rx FIFO filled to threshold level. Read bytes */
         for (i=0; i<RX_FIFO_THRESHOLD; i++) {
            uart0RxBuffer[uart0RxByteCounter++ % uart0RxBufferSize]
= U1RBR;
         break;
      case 12:	/* Old bytes still in RX FIFO. Read the bytes */
         while ((U1LSR & 0x01) == 1) {
= U1RBR;
         break;
      default:		/* Unidentified interrupt cause */
         sendString("Error:");   /* Debug print-out */
         sendString(stat);       /* Debug print-out */
         break;
   VICVectAddr = 0;	// Enable new IRQ-interrupts
   return;
void Timer0Handler (void) {
   T0TCR = 0x03;	// Reset and stop timer0
   switch (T0IR) {
   case 1:		// MR0 interrupt
      T0IR = 0x01;	// Clear MR0 interrupt
      sendString("Time out");  // Debug print-out
      break;
   default:		// Other interrupt
      T0IR = 0xFF;	// Clear the generating interrupt
      sendString("Undefined");  // Debug print-out
      break;
   T0TCR = 0x01;	// Restart timer0
   return;
Am I missing something?
/Anders
> IRQ's.
> the VIC priority.
> Hope this helps.
> Zdravko
> --- andersryl <andersryl@y...> wrote:
> > Hi,
> > on my Olimex
> > Windows application
> > app sends frames
> > responds by sending
> > give interrupts
> > header and 1-89
> > bytes of data).
> > (request+reply).
> > "request-frame"
> > that there are
> > other UART from a
> > should give
> > after 2 seconds if
> > operation due to
> > last request
> > but no interrupt
> > is raised.
> > I never leave my
> > interrupts
> > pending.
> > frame:
> > T0IR:               0x00
> > T0TCR:              0x01
> > T0MCR:            0x0003
> > U1IIR:              0xC4
> > T0IR:               0x01
> > T0TCR:              0x01
> > T0MCR:            0x0003
> > U1IIR:              0xC4
> > /Anders
> Yahoo! DSL – Something to write home about.
> dsl.yahoo.com
Re: [lpc2000] Re: Interrupt pending but not raised
2005-12-07 by Tom Walsh
>main.c:
>   BYTE stat;
>   WORD i;
>   while (stat != 1) {
>      switch (stat) {
>= U1RBR;
>         break;
>= U1RBR;
>         break;
>         break;
>   return;
FWIW, I'd declare stat as volatile:
volatile BYTE stat;
Just to ensure it isn't going to get optimized into a static (assumed
unchanging) value.
TomW
Re: Interrupt pending but not raised [Solved]
Oh my God!
I was so sure that there was "something going on behind the
curtains" I didn't understand that I didn't even bother to check any
code "not near" the ISR's.
Apparently I had disabled both IRQ and FIQ...
Shame on me. :(
/Anders
and
are
> >main.c:
> >   BYTE stat;
> >   WORD i;
> >   while (stat != 1) {
> >      switch (stat) {
bytes */
uart0RxBufferSize]
> >= U1RBR;
> >         break;
bytes */
uart0RxBufferSize]
> >= U1RBR;
> >         break;
> >         break;
> >   return;
> volatile BYTE stat;
(assumed
> unchanging) value.
> TomW
