Lpc2000
program starting problem
2005-12-06 by arm_beta_tester
Hello,
I've written a simple program for ARM LPC2138 to flash on and off LED.
I use IAR EWARM software.
When the code is debbuged everything is ok.
But when I disconnet JTAG HW and reset microcontroller, it's not starting.
I noticed that if I disconnect the supply voltage and immediately
after that connect the plug program starting.
Hubert Gawinski
Re: [lpc2000] program starting problem
2005-12-06 by Mike Nelson
Hubert:
Have you configured IAR EWARM to program the flash?
See Project, Options, Debugger, Download.
Regards:
Mike Nelson
--- arm_beta_tester <h11@...> wrote:
> Hello,
> and immediately
> Regards
> Hubert Gawinski
__________________________________________
Yahoo! DSL \ufffd Something to write home about.
Just $16.99/mo. or less.
dsl.yahoo.com
2005-12-06 by mfrazier@governors-america.com
Have you checked the reset circuit...in debug mode the jtag handles the
reset...this could be why it's acting this way.
Good Luck,
The Wizard
Re: program starting problem
The download option is turned on
(Project->Options->Debugger/Download->Use flash loader(s))
The flash memory is downloaded properly.
As I mentioned sometimes the microcontroller starts and then work well.
But if I disconnect supplying plug for a second and connect once again
it doesn't work.
--- In lpc2000@yahoogroups.com, Mike Nelson <m1k3n3ls0n@y...> wrote:
> Hubert:
> Regards:
> Mike Nelson
The reset pin of the microcontroller is connected by 10k to VCC and
also to GND in series with 100n capacitor.
--- In lpc2000@yahoogroups.com, mfrazier@g... wrote:
> Have you looked at the reset circuit??
Re: [lpc2000] Re: program starting problem
2005-12-06 by Mauricio Scaff
Apears to be a reset problem or your start.s is not initializing
properly the stack pointer.
> it doesn't work.
> > Hubert:
> > Regards:
> > Mike Nelson
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-12-07 by fredvermejo
It can be a reset or oscillator problem too.
Check the rise time of reset and start-up time of oscillator.
If (rise time < start-up time) change the Caps value connected to
XTAL.
work well.
again
> > it doesn't work.
wrote:
> > > Hubert:
> > > Regards:
> > > Mike Nelson
> > YAHOO! GROUPS LINKS
of
2005-12-07 by arm_beta_tester
Finally, I've found the problem.
A value of the MEMMAP register (it is used for memory mapping) was
equal to 0x00 by default. In this case interrupt vector are remapped
to boot block.
If I exchange the value of this register for 0x01(in debugger mode),
when the reset vector is reached the program works fine. In that case
interrupt vectors are not remapped and reside in flash.
So, I have to change the cstartup.s79 file. So far I use precompiled
runtime libraries, then I must to write a piece of code.
regards,
hg
--- In lpc2000@yahoogroups.com, "arm_beta_tester" <h11@o...> wrote:
> Hello,
starting.
> Regards
> Hubert Gawinski
