Lpc2000
AD problem
AD problem
2005-12-22 by zhengy_yong
the problem is i can only enter the interrupt
funciton once,then never enter the function again.
are there any problems with my program?
anyone can give me a suggestion?
#include "config.h"
unsigned int  result[20];
unsigned char channelx[20];
void __irq IRQ_ADC(void)
   unsigned int  value   = 0x0000;       //result of the ADC converter
   unsigned char channel = 0x00;         //the channel
   unsigned char i	       = 0;
   value        = ADDR;  //read the result and clear the DONE sign
   channel      = (value>>0x18)&0x07; //get the channel
   value        = (value>>6)&0x03ff;  //convert the ADC result
   if(channel == 0x00)                //switch the channel
       	ADCR = ADCR&0xFFFFFF00|0x02;
    else if(channel == 0x01)
       	ADCR = ADCR&0xFFFFFF00|0x04;
    else if(channel == 0x02)
      	ADCR = ADCR&0xFFFFFF00|0x08;
    else if(channel == 0x03)
      	ADCR = ADCR&0xFFFFFF00|0x01;
    channelx[i]  = channel;
	result[i]    = value;
	i++;
	if(i<20)             //whether get 20 result ?
		i++;
	else
		i = 0;
	VICVectAddr0 = 0;    //clear the IRQ function address
int main(void)
    PINSEL1 	 = 0x01400000;//connect the pin to adc
    ADCR    	 = 0x00201501;//setup the ADCR only use the ain0
    ADCR		 = ADCR|0x00010000;//use burst model
    VICIntSelect = 0x00000000;      //
    VICVectCntl0 = 0x32;
    VICVectAddr0 = (int)IRQ_ADC;    //address of the IRQ function
    VICIntEnable = 0x00040000;      //enamble the ADC interrupt
    while(1)
	;                           //wait for the interrupt
	return(0);
Re: [lpc2000] AD problem
2005-12-22 by Richard Duits
The line:
VICVectAddr0 = 0;
in IRQ_ADC should be
VICVectAddr = 0;
Richard.
> #include "config.h"
>       result[i]    = value;
>       i++;
>             i++;
>       else
>             i = 0;
> int main(void)
>     while(1)
>       return(0);
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
JTAG debugging options
2006-01-03 by Sean
Hello All,
I have seen a lot of talk around about Wiggler-based JTAG debugger boards,
which can be built for < $1, and I see several commercial JTAG debugging
pods that are > $1000.  What is it that these things do that you can't do
with a simple wiggler interface?  I.e. for most intents and purposes what
can you not do with a wiggler interface?
Even the original maker of wiggler charges > $150 for this board, which can
be built for like $1.  What's the deal there?
-- Sean
Re: [lpc2000] JTAG debugging options
2006-01-03 by Peter Jakacki
That's not even a realistic comparison, if I gave you <$100 would
you/could you supply me with 100 wigglers? Are you even considering that
the newer ones are USB based and much more complicated than a simple
parallel port device? If for instance an engineers time is valued at
$100 an hour, could he produce a one-off "professional finish" wriggler
for less then $150? That's right, why bother!
Have you ever been involved in marketing? A humble can of beans may only
contain a few cents worth of beans but I'm sure you pay a lot more than
that for it quite happily. You could save yourself some money and grow
them yourself, but isn't there always a cost involved in everything we do?
BTW, I have never needed to use ARM wrigglers myself.
*Peter*
2006-01-03 by Sean
Easy, Tiger :)   Yes... I understand that time = money.
Perhaps I have misunderstood something.  Is this not a Wiggler-compatible
interface?
http://www.micronix.ca/sbc213x_main.htm
http://www.micronix.ca/catalog/product_pages/images/JTAG02_SCH_011.jpg
Perhaps I should rephrase my original question:
What JTAG debugging options are there, and what's the difference between
the ~$150 and > $1000 board options?
-- Sean
>*Peter*
> can
>YAHOO! GROUPS LINKS
>    *  Visit your group "<http://groups.yahoo.com/group/lpc2000>lpc2000"
> on the web.
> <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>lpc2000-unsubscribe@yahoogroups.com
> <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
Re: JTAG debugging options
2006-01-03 by lynchzilla
Sean pointed out that the Macraigor Wiggler is $150 whilst the
Olimex clone is $19 and asks "what's the deal here?"
Open up a wiggler and you'll see that it's a cheap level-shifter
chip and a transistor built into a DB-25 shell. Admittedly, $19
seems more like a fair price, but Olimex didn't write the OCDRemote
and OCDCommander software and didn't have to ammortize any software
development (Macraigor does). Macraigor probably provides more
telephone support if the customer has trouble getting it to work.
Even the fastest wiggler baud rate is slow in comparison to the
newer USB and Ethernet JTAG debuggers. This is not obvious in short
demo programs, but painful if you are downloading a very large
program.
I worry about myself and others relying on the Macraigor OCDRemote
JTAG program that interfaces GDB to the JTAG pins. OCDRemote is NOT
open-source. Macraigor allows free downloads of the OCDRemote
executable but the source code has always been proprietary. They
could withdraw this "freebie" at any time.
We need two things. A reasonably priced USB JTAG debugger supported
by a true "open-source" GDB/JTAG driver. Until then, the debugging
situation will remain tenuous, at best (for those on limited
budgets).
James P. Lynch
Since I'm not speaking to you face to face I just cut to the chase :)
> interface?
The JTAG-02 is only CAD $35, I'm not sure where you find the $150
option. The Keil ULINK (USB) is only $199 but I'm not aware of any
 >$1000 options. As James pointed out, the basic hardware is
straightforward but the driver software is a different story altogether.
*Peter*
2006-01-03 by Sean
Ok, the one I saw was
http://www.gwmicros.com/public_html/pages/products/iproducts/BDM_JTAG/Macraigor/BDM-JTAG_Macraigor_usbDemon.htm
or
http://www.gwmicros.com/public_html/pages/products/iproducts/BDM_JTAG/Macraigor/BDM-JTAG_Macraigor_Raven.htm
both 818EUR
And their wiggler is 188 EUR.  Yes, most others I see are in the $150 -
$300 range.
I'm just trying to understand here.  I can see how originally there were
few (expensive) options, and there was a lot of design and support and
software creation necessary, so yes, it was expensive.  However from the
point of view of anyone who is starting a design, be it a starving student
or a multinational corporation, what do the expensive emulators do that I
can't do with a $1 DIY one?  Can I get by with a DIY one, or should I
actually fork out the cash for the name-brand ones?  Let's assume that I
need to do non-trivial debugging here.
I too am a fan of alternate methods for debugging, or creating modules on
the PC and then porting them, or loggers, or serial port dumps, however
there are times when having an ICE makes it a lot easier to figure out.
Thanks for the advice,
-- Sean
> > interface?
> <http://www.micronix.ca/sbc213x_main.htm>http://www.micronix.ca/sbc213x_main.htm
>*Peter*
>YAHOO! GROUPS LINKS
> on the web.
Re: [lpc2000] Re: JTAG debugging options
2006-01-03 by Sean
This is a very good point:  why are they offering their software for free,
knowing full well that other people are using it on competitor's hardware?
Yes, baud rates are slower over parallel, although you can get > 1mbit/sec
on the parallel port itself, perhaps only 25KB/sec when using wiggler, but
even there, even with a rather large code size of 512KB, this is only 20
seconds to download...  For most debugging scenarios you won't need to
download the full size anyway, and if you split your program into modules
you can get by with only debugging a module at a time, which means you only
need to load a few dozen KB at a time?
-- Sean
>program.
>budgets).
>Cheers,
>James P. Lynch
>YAHOO! GROUPS LINKS
> on the web.
2006-01-03 by rtstofer
> or
> both 818EUR
$150 -
> $300 range.
there were
and
from the
student
that I
should I
that I
Well then, if you want to do non-trivial debugging, you'll certainly
hate Insight->OCD Remote->Wiggler clone.  As James Lynch points out
in his excellent tutorial, there are days when it just won't work.
To be blunt, it sucks.  It isn't worth the aggravation to get it
working; printf works better.
Now, Tom Walsh is more than happy with his high dollar solution
(Abatron BDI2000) and if I were doing this for money, I would buy
the same interface he has.  If I could find a distributor in the
US...
And, if the US$ wasn't complete worthless when converted to British
Pounds, I might consider the Rowley CrossConnect package.
Richard
modules on
however
out.
> -- Sean
chase :)
compatible
> > > interface?
3x_main.htm
g
difference between
altogether.
> >*Peter*
> >YAHOO! GROUPS LINKS
> >    *  Visit your
> > on the web.
2006-01-03 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Tuesday, January 03, 2006 4:21 AM
Subject: Re: [lpc2000] JTAG debugging options
> or
> both 818EUR
> $300 range.
A DIY one will be fine. I designed a PCB for one that may easily be made at
home with rudimentary facilities (artwork in jtag.zip in the Files area).
It'll probably take a couple of hours to make the PCB and get it working.
I already had a genuine Macraigor Wiggler and mine works at higher speeds
than the real thing; my PCB layout is better. I've also got a Rowley
CrossConnect (99 GBP) with a USB connection to the PCB, and that works very
well. USB is more convenient than a parallel port connection, and faster.
Amontec sells their Chameleon interface, which is based on a reconfigurable
CPLD. It can emulate a Wiggler or Raven, as well as lots of other
interfaces, including JTAGs for Xilinx and Altera parts. I've got one of
those, as well. Worth getting if you want to play with FPGAs and other JTAG
MCUs.
Leon
2006-01-03 by Anton Erasmus
> free, knowing full well that other people are using it on competitor's
> hardware?
The advertising value they get is immense. Anybody who has used a
wiggler or wiggler clone would at least give their more sophisticated
models a look if they are considering getting something a bit better
than a wiggler.
> 1mbit/sec on the parallel port itself, perhaps only 25KB/sec when
> using wiggler, but even there, even with a rather large code size of
> 512KB, this is only 20 seconds to download...  For most debugging
> scenarios you won't need to download the full size anyway, and if you
> split your program into modules you can get by with only debugging a
> module at a time, which means you only need to load a few dozen KB at
> a time?
The biggest issue with using the wiggler, is that it is temperamental. It works
quite nicely when it works, but there are days when it just refuses to work - normally
when you actually need it. Any JTAG interface where the JTAG signal timing is
independant of the PC hardware/software used are going to be more stable.
An open hardware / open source JTAG interface with USB / ethernet interface
would be great. Designing and building the hardware is not such a big problem.
Writing the software is the biggest issue for such a project.
  Anton Erasmus
> -- Sean
> >Open up a wiggler and you'll see that it's a cheap level-shifter chip
> >and a transistor built into a DB-25 shell. Admittedly, $19 seems more
> >like a fair price, but Olimex didn't write the OCDRemote and
> >program.
> >budgets).
> >Cheers,
> >James P. Lynch
> >YAHOO! GROUPS LINKS
> >    *  Visit your group
> > on the web.
A J Erasmus
2006-01-03 by Stephen Pelc
> Date: Mon, 02 Jan 2006 21:01:04 -0500
> From: Sean <embeddedrelated@...>
> debugger boards, which can be built for < $1, and I see several
> commercial JTAG debugging pods that are > $1000.  What is it that
> these things do that you can't do with a simple wiggler
> interface?
Warning: Response from JTAG vendor: See
  http://www.mpeforth.com/jtagwidget.htm
which is designed for hardwaare bring-up as well as software
debugging.
There are three aspects to consider:
  connection to PC host
  connection to ARM target
  software
Host Connection
The host connection in rough order of performance and cost is
  PC parallel port
  USB
  dedicated PCI card
Some parallel port interfaces are powered from the parallel
port. Without great care in component selection and PC layout
these can be unreliable. We have several, some work well, some
don't.
USB interfaces can draw power from the USB port. In general,
these are the most convenient for site use. But the hardware is
more expensive and software is required, probably both on the PC
and on the JTAG adaptor. Software costs.
PCI interfaces will give the highest performance, but are
usually only found on dedicated testers.
ARM target connection
As the JTAG speed increases, you need to be more careful with
drive levels, cable length and cable impedances. We do not use a
cheap HC244, we use a real level shifter on the JTAG side. It's
rated to below 1.8 volts. Similarly, the lifetime and cost of a
good quality 3M connector is much higher than that of a generic
20 pin connector.
Software
Once you move away from the parallel port connection, you'll
most likely have to write software for the adaptor as well as
for the PC.
Conclusion
Better (performance, reliability ...) JTAG debuggers require
more work, which has to be paid for somehow or other. Technical
support costs time/money too. There's a lot more to ARM JTAG
debuggers than at first meets the eye.
Stephen
Stephen Pelc, stephen@...
MicroProcessor Engineering Ltd - More Real, Less Time
133 Hill Lane, Southampton SO15 5AF, England
tel: +44 23 80 631441, fax: +44 23 80 339691
web: http://www.mpeforth.com - free VFX Forth downloads
2006-01-03 by derbaier
> debugging.
>   software
> Host Connection
>   PC parallel port
>   USB
>   dedicated PCI card
> don't.
> 20 pin connector.
> Software
> for the PC.
> Conclusion
> Stephen
> Stephen Pelc, stephen@m...
Nice analysis, Stephen.
I just wanted to note that you left out my favorite as the most
powerful of the JTAG to workstation connection methods.
 Ethernet!!!!
The Lauterbach Trace32 Ethernet is the fastest and most powerful of
all the JTAG setups that I have used, and extremely expensive.  :-(
One big advantage of Ethernet, is that the workstation and the debug
target do not have to be in the same location. Of course, it is not as
fast over the Internet as it is with a direct local connection.  :-)
Care to give them some competition in that arena?  :-)
-- Dave
> budgets).
> Cheers,
> James P. Lynch
I posted a question re: using Insight under Linux on the Sparkfun
Forum.  I received this site as a reply: http://openocd.berlios.de/web/
This may be a HUGE step in the right direction.
Richard
2006-01-03 by David Hawkins
> US...
 > If I could find a distributor in the US...
Try Ultimate Solutions ...
http://www.ultsol.com
I requested a quote for PowerPC 4xx and ARM development ...
BDI2000+bdiGDB PPC4xx $2570
bdiGDB for ARM7/9/9E  $1000
I just have to figure out how to get that passed the guys with
the money ...
Dave
2006-01-03 by Tom Walsh
>>US...
Interesting.  I got the BDI2000+bdiGDB option for the ARM7/9/9E for the
same price.  I suspect that the config files are all that is different
between the models.  I'm still not sure what that "bdiGDB" is all about...
TomW
2006-01-03 by Bertrik Sikken
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
>> budgets).
>> Cheers,
>> James P. Lynch
I played around with this in the past week and I think this is the
most promising open-source ARM7 JTAG project.
The source code looks well organised and extensible.
The latest version (download with subversion) is now able to run
under windows (with cygwin), it supports the ARM7TDMI-S micro and
works with various type of JTAG cables (parallel port and USB).
It successfully stepped through some simple programs in both
gdb and insight.
Kind regards,
Bertrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDuu3NETD6mlrWxPURAtgWAKC6T0KPR1s7J4o0ZEXhPM19zhI1LACeMM6c
hlCeE8YOe76AeQHEubaZsow=
=JTW+
-----END PGP SIGNATURE-----
2006-01-04 by Stephen Pelc
>  Ethernet!!!!
> of all the JTAG setups that I have used, and extremely expensive.
> debug target do not have to be in the same location. Of course,
> it is not as fast over the Internet as it is with a direct local
> connection.  :-)
How many would you like?
We did consider Ethernet, but USB is much more convenient for
site work. It may become an option ...
Stephen
2006-01-04 by derbaier
> Stephen
I get your point!  :-)
Unfortunately I am no longer in a position to influence the purchase
of debug hardware, since I am recently retired. My former employer
bought large numbers of the Ethernet debuggers that I was refering to,
and we found the Ethernet connection to be very very handy.  The
ability to debug from a distance was a highly used feature in that
work environment.
I don't think that it would all that difficult to enable remote
debugging using USB as long as a local workstation was available to
act as the local USB connection to the target?
Thanks for the reply!
-- Dave
