Data lines in Big Endian mode
2006-01-13 by Pieter Verstraelen
Hello group, we will be using the LPC2210 in Big Endian mode to interface to an Epson S1D13A05. In Little Endian you simply start at D0 and use up to D7, D15 or D31 depending on the bus size. But how does this work in Big Endian? Will an 8-bit bus run on D24..D31 and a 16-bit bus on D16..D31? Or does the chip solve this internally? Best regards, Pieter Verstraelen [Non-text portions of this message have been removed]
