Check out my site http://www.wackyland.net/ARM7kits.html, there is a list
of ARM 7 development kits, most are reasonably priced, and a lot cheaper
than Keil's. (Again, if anyone has anything to add to this site, please
let me know).
Secondly search the archives of this group for "wiggler clone", or do a
google search for that. Recently there has been a fair amount of
discussion on how to make your own JTAG wiggler-style debugging cable, if
you are crafty and careful you can make it for next to nothing.
If you are new at this I would *Strongly recommend* that you do NOT try to
make something yourself as your first project. Keep in mind that nothing
and noone is perfect, so there will always be problems. You will spend far
longer in the long run trying to figure out "ok, is this problem due to my
schematic, due to a hardware issue, due to my soldering, due to ...?",
whereas the < $100 to buy a ready made development kit with software and
tools and everything is far easier and cheaper in the long run. For ~ $100
USD you can easily have a development kit shipped to you, buy a wiggler
clone and have everything that you need to start development the day that
you receive the hardware.
Doing this yourself will probably take you (conservatively) at least 50
hours of development time, anywhere up to 200 hours. Unless your time is
worth less than $1/hr, it's better to just buy something.
-- Sean
At 02:44 PM 1/22/2006, you wrote:
>hi
>i am new to ARM microcontroller and found this group very good.
>i want to make evaluation board from the schematic give at the keil
>website for model MCB2140 (LPC2148)
>1) will this schematic work
>2) if the above schematic doesn't work please give a schematic
>2)does any one has JTAG circuit for the above circuit board (i cant
>afford to buy JTAG from keil)
>bye
>sudhir
