Lpc2000
IRQ / FIQ status register general question.
2006-01-27 by Dmitry Diky
Fellows,
In my application it is convenient to switch between IRQ and FIQ in some
interrupt service routine.
As I know FIQ mode used banked r8-r14 registers and no registers have to be
saved on stack (providing I want to have the things working :)
So, when an IRQ interrupt occurs, I immediately enter to FIQ, then process my
interrupt request and then exit..
xxx_IRS:
	msr cpsr_c, #MODE_FIQ|FIQ_BIT|IRQ_BIT	; @ switch to FIQ with ints dsbld.
	... ISR code ...
	msr cpsr_c, #MODE_IRQ|FIQ_BIT|IRQ_BIT	; @ back to IRQ mode
	sub pc,lr,#4						; @ return from interrupt
Everything seems to be working except I am not sure what happens to CPSR of
the user mode. As I understand, when nIRQ is asserted, CPSR being copied to
SPSR_irq and on IRQ exit SPSR_irq -> CPSR_usr. But what happens when I switch
to FIQ and back? Does the CPU core copy cpsr_irq to spsr_fiq and back
or... ??? In a few words: will be user's CPSR kept alive with such IRQ
servicing scheme?
Dmitry.
Re: [lpc2000] IRQ / FIQ status register general question.
2006-01-27 by Sten
Dmitry Diky wrote:
> Fellows,
> xxx_IRS:
> 	... ISR code ...
> servicing scheme?
> Thanks,
> Dmitry.
Hi Dimitry,
Uuuuuuuuuhhhhhhh, ... Are you sure you know what you are doing?
FIQ- and IRQ-mode are dedicated modes for the two types of interrupts (FIQ and IRQ) ARM have. If you
define an interrupt as a fast-IRQ (FIQ) than you have the goal that the system automatically enters
FIQ mode and will save some additional registers when this interrupt occurs. If you define an
(normal) IRQ your system will enter IRQ-mode. In opposite to other architectures ARM can perform a
kind of hardware context switch by switching to another mode. In general you should NEVER change
those modes manually in your software! These modes are changed by core itself when raising dedicated
exceptions. There are only a few exceptions where to change it manually: e.g. after startup has
finished you can switch form supervisor-mode to system-mode or user-mode before you enter
application code. But in user-mode you will have only restricted access to system resources. This
mode is dedicated for use with a RTOS which is protecting OS-layer from (evil) user-land applications.
  Sten
 Do you need a tiny and efficient real time
 operating system (RTOS) with a preemtive
 multitasking for LPC2000 or AT91SAM7?
   http://nanortos.net-attack.de/
 Or some open-source tools and code for LPC2000?
   http://www.net-attack.de/
Hi Sten,
Well, I am pretty sure...
To be precise I got two possible interrupt requests: - timer and SPI ones.
I assign timer interupt to IRQ and SPI to FIQ. However, on timer interrupt,
the SPI transfer should be initiated.
To save some interrupt processing time I initiate timer and SPI register, the
switch to FIQ mode (via swi interrupt) and assign some peripherial regs to
FIQ registers r8_fiq, r8_fiq, ... So, in FIQ mode I do not have to load
complicated values (0xe0020000 for example) to the register.
However, in timer ISR I have to manipulate with timer registers and SPI
registers which are already assigned to _fiq registers... So, why not to
switch to FIQ mode in IRQ ISR providing no other interrupts can occur during
IRQ processing?
> and IRQ) ARM have. If you define an interrupt as a fast-IRQ (FIQ) than you
> have the goal that the system automatically enters FIQ mode and will save
Yes, thats why I assign FIQ to SPI - I need a counter which I keep in a
register and therefore do not have to load it from memory...
The overall process is the following:
fiq_isr:	(located at 0x1c)
		... just maipulate with SPI
		... uses r8_fiq... r13_fiq as general-purpose registers
		sub pc, lr, #4	<- exit from FIQ
timer_isr:	(called via vectored interrupt controller)
		msr cpsr_c, #mode_fiq|i_bit|f_bit
		... manipulate with timer
		... start SPI transfer
		... uses r8_fiq...r13_fiq
		msr cpsr_c, #mode_irq|i_bit|f_bit
		sub pc, lr, #4
I am pretty sure, that timer interrupts can occur only when CPU is in idle
state, except when UART transfer is in progress. However, I do not facilitate
nested interrupts, so no problems with cpsr_c should happen...
The question is: will be cpsr_of-current-mode copied to SPSR when I manually
switch the modes?
Dmitry.
Re: IRQ / FIQ status register general question.
2006-01-27 by Guillermo Prandi
Hi, Dmitry. I am no ARM7 expert, but perhaps what you're looking for
is this:
xxx_IRS:
with ints dsbld.
        ... ISR code ...
        subs pc,lr,#4                           ; @ return from
interrupt
(Notice the use of SUBS instead of SUB). The S flag to SUB tells the
µP to restore the saved mode register, thus switching back to user
mode.
Of course this will work only if you don't nest FIQs or IRQs.
Guille
--- In lpc2000@yahoogroups.com, Dmitry Diky <ddiky@a...> wrote:
> Fellows,
some
have to be
process my
> xxx_IRS:
with ints dsbld.
> 	... ISR code ...
> 	sub pc,lr,#4						; @
CPSR of
copied to
when I switch
back
IRQ
> servicing scheme?
> Thanks,
> Dmitry.
manually
> switch the modes?
According to the Addison Wesley's ARM Architecture Reference Manual,
MSR will update your choice of CPSR or SPSR but not BOTH. However,
changing modes will switch registers, so when CPSR is updated, SPSR
will be switched to the new mode's.
You should not exit an IRQ or FIQ with SUB but with SUBS in order to
return to the previous (user or other) mode. Otherwise, you would be
leaving the IRQ still in IRQ mode.
The way I see it:
; Scenario: IRQ triggered when in user mode
; The µP saves user mode CPSR to spsr@IRQ, switches to IRQ mode
(switching registers) and jumps to xxx_IRS
; spsr@FIQ has some unknown value
xxx_IRS:
dsbld.
; both spsr@FIQ and spsr@IRQ remain unchanged; you've got now
spsr@FIQ visible, which has garbage (i.e., a previous unpredictable
value)
... ISR code ...
spsr@IRQ visible, which has the user mode CPSR
subs pc,lr,#4 ; @ return from interrupt
; subs copies spsr@IRQ to CPSR and now everybody is happy ;)
Guille
> Hi Sten,
SPI ones.
interrupt,
register, the
regs to
load
SPI
not to
occur during
> IRQ processing?
interrupts (FIQ
than you
will save
in a
registers
> 		sub pc, lr, #4
in idle
facilitate
manually
> switch the modes?
> Thanks,
> Dmitry.
2006-01-27 by Sten
Dmitry Diky wrote:
> Hi Sten,
Hi Dimitry,
but this is not what the guys from ARM intended. It seems to be working hack for your special case. ;-)
2006-01-28 by jayasooriah
As you are entering and leaving the exception in the same mode, and
given you are allowed to change modes when you have the privilege, I
do not see anything wrong with your code.
I do someting similar to stash context informatinon in FIQ bank (so
that the code is RAM independent) and had no problems with exceptions,
although I have no FIQ/IRQ type of exceptions.
CPSR of
copied to
I switch
> servicing scheme?
RE: [lpc2000] IRQ / FIQ status register general question.
2006-01-31 by Bruce Paterson
> registers have
Steb replied:
> ..... (normal) IRQ your system will enter IRQ-mode. In opposite to
> other architectures ARM can perform a kind of hardware
> should NEVER change those modes manually in your software!
I haven't used an FIQ myself yet so excuse the possibly silly question.
Surely if you are using an alternate register set in an FIQ, at some
early stage, somewhere, you'd want to initialise those registers (eg.
Setup a pointer at the start of a circular buffer). How would you
achieve this if you aren't able to/allowed to switch modes manually ?
Bruce
2006-01-31 by Sten
Bruce Paterson wrote:
>>registers have
> Steb replied:
Hi Bruce,
it is allowed to switch context manually, during starup for example. But I think it is not
recommended to do this in application code. You must initialize all modes you want to use (FIQ, IRQ,
USR, SVR, SYS) or modes that might be used (for you) (ABT, UND) during startup.
  Sten
2006-01-31 by jayasooriah
When doing data transfers on FIQ and using FIQ bank (eg a pointers and
a byte count), then you have no choice but to set up, and/or examine
these in "application code" (meaning code not running in FIQ context).
Often completion of transfer triggers a (lower priority) IRQ, and in
this case, the code running in IRQ context peeks/pokes registers in
the FIQ bank by switching to FIQ and then back to IRQ.
Summary: there is nothing wrong at all with switching banks in any
code segment (not just in startup code) provided you leave the
exception in the same state that you entered in.  (You can leave in a
different mode if you know what you are doing but I am not sure the
behaviour can be generalised across all ARM implementations.)
> for example. But I think it is not recommended to do this
> want to use (FIQ, IRQ, USR, SVR, SYS) or modes that might
Re: [lpc2000] Re: IRQ / FIQ status register general question.
2006-02-01 by Sten
in your case it works. No doubt!
This is a special case in which you must setup FIQ state to use it.
Ok, I think I understood! You want to modify your special pointers/counters, used by the FIQ, from a
IRQ for example. This is quite tricky!
