Lpc2000
IAP and then strange behavior
2006-02-02 by fl429
Hi, Folks,
Hopefully, someone can shed some light to this. Thanks.
First, this is not my first app on the LPC2138. I had no trouble
before, until I use IAP in this one.
The IAP calls seem working OK. No error reported. Flash memory does
program as expected, as far as I can see.
But, a simle C structure in one of the functions now behaves wierdly
SOMETIMES. This is called repeatedly in a loop.
switch(m_CmdTmp) {
case 1:
    ..... codes here
    m_CmdTmp=2;
    break;
case 2:
    if(!Started()) {
         Starting();         <<====== Point 1
         // some other stuff ... here
         m_CmdTmp=3;
    break;
case 3:
    break;
After some poking around, I found I am at Point 1 while m_CmdTmp
already equals 3 (m_CmdTmp=3).
There is no interrupts changing the value of m_CmdTmp behind my
back ! m_CmdTmp is supposed to progress ONLY in this switch routine.
I tried to change stack sizes to no avail. I reserved 256 bytes from
the TOP of SRAM (0x400007e00 and up) from being used by this APP.
No, I still have this problem.
Any ideas ?
Thanks a lot,
Greg
Re: IAP and then strange behavior
2006-02-02 by Guillermo Prandi
Can you try declaring your m_CmdTmp as static? This will remove it
from the local registers into a specific memory location. Volatile is
even better. This might give you some clues either if it works or it
does not.
Guille
--- In lpc2000@yahoogroups.com, "fl429" <fl429@...> wrote:
> Hi, Folks,
wierdly
> switch(m_CmdTmp) {
> case 1:
>     ..... codes here
>     m_CmdTmp=2;
>     break;
> case 2:
>     if(!Started()) {
>          m_CmdTmp=3;
>     break;
> case 3:
>     break;
from
> Any ideas ?
> Thanks a lot,
> Greg
2006-02-03 by lpc2100_fan
Hi Greg,
one thing that I have seen before that ended up with the same symptoms
your are describing is an IAP call with the wrong frequency. What I am
referring to is you boot up let's say with 14.756 MHz and do some IAP
calls, then you enable the PLL and still call IAP with the same 14.756
although now it is 59 MHz.
I have seen the programming work "most of the time" but one bit or one
byte being incorrect.
May be this helps, Bob
> Hi, Folks,
> switch(m_CmdTmp) {
> case 1:
>     ..... codes here
>     m_CmdTmp=2;
>     break;
> case 2:
>     if(!Started()) {
>          m_CmdTmp=3;
>     break;
> case 3:
>     break;
> Any ideas ?
> Thanks a lot,
> Greg
2006-02-03 by fl429
Well. I guess it was not IAP after I put a dummy function in the
place of the IAP Call.
I tried to use a static variable. The problem was still there. BTW, I
am using GCC 3.4.4. It is a cpp program.
I looked at the assembly. It may have something to do with R11, the
frame pointer. The problem seems appear when under stress. OK, I am
working on my own bootloader. Bootloading a really small code, it
works ok. When loading a few KBytes, it shows up.
I can get around the symptom by a simple if statement, such as,
switch(m_CmdStep) {
case 1:
  break;
case 2:
  if(!Started()) {
     if(m_CmdStep==2)
        Starting();
     m_CmdStep=3;
  break;
case 3:
  break;
But I fear I hid the real problem. Any ideas ?
Thanks for all replies.
Greg
> Hi, Folks,
wierdly
> switch(m_CmdTmp) {
> case 1:
>     ..... codes here
>     m_CmdTmp=2;
>     break;
> case 2:
>     if(!Started()) {
>          m_CmdTmp=3;
>     break;
> case 3:
>     break;
from
> Any ideas ?
> Thanks a lot,
> Greg
Re: [lpc2000] Re: IAP and then strange behavior
2006-02-03 by Tom Walsh
lpc2100_fan wrote:
>Hi Greg,
Is that how you read the manual?  I thought that "system clock" was
referring to that of the external clocking rate, not that as the PLL clock?
Do I have to use the PLL clock rate for this?
TomW
Tom,
I am absolutely certain about this, it has been verified with Philips.
Each IAP call needs to have the frequence the device is currently
running at. If the PLL is active the parameter needs to be PLL*ext. Freq.
The "funny" part is, it works ALMOST all the time even with the wrong
frequency.
Bob
--- In lpc2000@yahoogroups.com, Tom Walsh <tom@...> wrote:
> lpc2100_fan wrote:
> >Hi Greg,
clock?
> Regards,
> TomW
lpc2100_fan wrote:
>Tom,
>frequency.
LOL, thanks!
TomW
>Bob
>>lpc2100_fan wrote:
>>>Hi Greg,
>clock?
>>Regards,
>>TomW
>Yahoo! Groups Links
2006-02-04 by Jayasooriah
Bob,
Those who feel offended when I point out deficiencies in boot loader
implementation please do not read further.
I found that the need to specify CPU clock frequency at run-time IMO causes
a number of problems including the one you pointed out.  Sometimes CPU
clock is changed at runtime based for power considerations you have to keep
track of this for IAP calls.
Flash programming requires three parameters relating to CPU clock.  The
first two of these, relating to writing to LPC timing registers #1 and #2
appear to accept a large degree of variation, at least 1:4 in my case.
I did away with the need for CPU clock at the third instance where boot
loader IAP implementation uses CPU clock parameter.  After issuing a flash
command, it is possible to determine when this is complete by examining LPC
flash controller status register.  I do this, but boot loader code does
not.  Instead, it waits for a programmed number of cycles based on the
supplied clock frequency.
When the programmer inadvertently supplies a low clock speed, the IAP call
terminates before the flash controller is ready, and you can see that what
happens after this is indeterminate.  Worse, it can permanently destroy the
part.
It appears that for the timing register parameters accept quite a large
variance, at least 1 to 4 variance in my case.  If Philips would disclose
what are these limits are, it is possible one could do away with need for
CPU clock frequency altogether for IAP or ISP calls.
My experience is limited to boards with 14M7456 crystals and with  PLL
speeds between 1 to 4 times that.
Jaya
--- In lpc2000@yahoogroups.com, "lpc2100_fan" <lpc2100_fan@...> wrote:
 > Tom,
 > frequency.
 > Bob
Send instant messages to your online friends http://au.messenger.yahoo.com
2006-02-07 by fl429
Hi, Bob,
Thank you for your help.
It turned out the problem was caused by a buffer overflow. My own
fault. Your tip helps.
Best regards !
Greg
wrote:
> Hi Greg,
symptoms
I am
IAP
14.756
one
> --- In lpc2000@yahoogroups.com, "fl429" <fl429@> wrote:
> > Hi, Folks,
does
wierdly
> > switch(m_CmdTmp) {
> > case 1:
> >     ..... codes here
> >     m_CmdTmp=2;
> >     break;
> > case 2:
> >     if(!Started()) {
> >          m_CmdTmp=3;
> >     break;
> > case 3:
> >     break;
routine.
from
APP.
> > Any ideas ?
> > Thanks a lot,
> > Greg
