Lpc2000
Re: Peter's questions for Jaya
2006-02-23 by Jayasooriah
Peter, I am happy to accept your taunt ...
--- In lpc2000@yahoogroups.com, Peter Jakacki <peterjak@...> wrote:
 > Please tell us if this is for real. Are they your own findings? Maybe
 > you are gleaning off a student perhaps?, and that is why you are not
 > able to give us any concrete evidence. ***Take this as a friendly taunt,
 > one that you should be able to refute in a microsecond if you are
 > genuine. We just want to know facts, not enter into a slinging match,
 > otherwise just end this thread here and now.
They are my own findings.  Not based on client's findings or that of students.
What "concrete" evidence do you need?  Feel free to phrase your questions.
Jaya
Send instant messages to your online friends http://au.messenger.yahoo.com
Re: Tom's questions for Jaya
2006-02-23 by lpc2100
Jayasooriah, I hope you don't mind me asking for proof. Please backup
the following statement of yours with solid evidence i.e. code example
You claim "I discovered  that calls to the on-chip boot loader using
IAP interface caused corruption of on-chip flash in unexpected ways.
On two instances, part became unusable after IAP calls failed."
This group can benefit from your exemplary research if you could post
the code example and conditions which can render part unusable. I am
willing to loose some parts. I hope Philips can fix the problem if it
exists.
Tom
taunt,
students.
questions.
> Regards,
> Jaya
Most recently Philips said "the bootloader is unlikely to get erased or
corrupted during IAP call even if wrong frequency is used."  This is is
proof enough from the horse's mouth that the problem exists.
I noticed the system crashed frequently while porting my Flash Translation
Layer (FTL) package from another system.  Most of the time I could recover
by simply resetting, but one time too many I had to have to get the LPC2105
replaced.
It would not come up in ISP mode no matter what.  No, I was not using the
watchdog at all and yes I power cycling did not help.
After the second or third time this happened (I cannot remember), I looked
at the errata sheet and found this problem documented as IAP calls that do
not return.
I upgraded my boot loader from 1.03 to 1.52 but the problem did not go
away.  [I really cannot remember if it got worse or better because code was
volatile during that time.]
I then put probes before and after IAP calls and established I would lose
the system during IAP calls, most of the time during writes but sometimes
during erase too.
I looked at the flash algorithm implementation in 1.03 and 1.52 versions of
the boot loader and worked out what was happening.  So I modified it to do
what I thought it should be doing and lo and behold, my FTL project was
done and over with in no time after that.
The above is my grounds on which I make the claim.  I still have two boards
with dead LPC on my desk if someone wants to do forensics to confirm that
boot loader is indeed dead.  I will swap it for good boards anytime.
 > exists.
Sure it would be nice bugs could be demonstrated by code examples.  Timing
problems unfortunately depend on far too many variables to be reproduced in
a deterministic manner.
Having said this, we know for a fact that there was a timing problem that
causes IAP calls to not return, and this was addressed by way of a boot
loader update.  Why is it not reasonable to ask if that did really fix the
problem, given the code does not seem to do what it appears it ought to be
doing?
Jaya
[lpc2000] Jump from variable
2006-02-23 by Marko Pavlin
How can I call function where address is in pointer? Something like this:
void test1(void){
   puts("blah");
void *exec;
void main(void) {
    exec = (void *)test1;
    __asm
    	BL 		exec
It's out of context. There will be more pointers and *exec can be constant:
const void *exec = (void *)test1;
Thanks!
Marko
Re: [lpc2000] Jump from variable
2006-02-23 by Jim Parziale
After setting:
Just call via exec:
     exec();
> void test1(void){
>    puts("blah");
> void *exec;
> void main(void) {
>     __asm
>           BL             exec
> constant:
> Thanks!
> Marko
>  SPONSORED LINKS
>   Microcontrollers<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ>
> Microprocessor<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=9jjd2D3GOLIESVQssLmLsA>  Intel
> microprocessors<http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw>   Pic
> microcontrollers<http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw>
> YAHOO! GROUPS LINKS
>    -  Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000>"
>    on the web.
>    -  To unsubscribe from this group, send an email to:
>     lpc2000-unsubscribe@yahoogroups.com<lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>    -  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>    Service <http://docs.yahoo.com/info/terms/>.
Jim Parziale
nuncio.bitis@...
Malden, MA
2006-02-23 by brendanmurphy37
Jaya,
Your reply below is interesting, but only in a historic sense (unless
I'm missing something). The problem you referred to in IAP has been
acknowledged by Philips and a fix provided (updated boot loader for
some parts).
I'll repeat the question I asked: do you have any evidence to back up
your claim that the "boot loader is broken"?
To give some background on why this is important (to me): I'm
currently involved in a project that uses the LPC2134. Right now,
towards the end of a fairly lengthy development program and
manufacture of some pre-production prototypes, we have no reason to
suspect there is a problem with the boot loader. This statement is
based on our own experience of using the parts. In a few months time
we will be in production at a rate of a couple of thousand units per
month. Every single one of these will be programmed using the built-
in boot loader. If there's any evidence that we may encounter a
problem, either in production or in the field, I'd really, really,
like to know about it now.
I'm sure our situation is not unique. I'm also very sure Philips
would be very interested in the answer.
Hence my question: is there any evidence of a problem with the
(current) boot loader, based on empirical data (not opinion or
supposition), that ought to concern me and the others who are using
these parts?
If the answer's "no", then that's great. If it's "yes", can you
please supply details of the specific problem you have observed, and
the circumstances in which it occurs, so that I (and others) can
evaluate any risk that might be present.
Many thanks in advance for any assistance you can give on this.
Brendan
backup
example
erased or
is is
using
ways.
Translation
recover
LPC2105
> replaced.
using the
looked
that do
> not return.
go
code was
would lose
sometimes
> during erase too.
versions of
it to do
was
two boards
confirm that
post
I am
if it
>  > exists.
Timing
reproduced in
problem that
boot
fix the
ought to be
> doing?
> Jaya
2006-02-23 by Guillermo Prandi
Brendan, Jayasooriah already said that the problem didn't go away
with Philips' new bootloader. It only went away with Jayasooriah's
own bootloader.
Guille
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
<brendan.murphy@...> wrote:
> Jaya,
(unless
> some parts).
up
time
per
> these parts?
and
> Regards
> Brendan
> backup
> example
> erased or
> is is
> using
> ways.
> Translation
could
> recover
> LPC2105
> > replaced.
> using the
I
> looked
calls
> that do
> > not return.
not
> go
because
> code was
> would lose
> sometimes
> > during erase too.
> versions of
> it to do
project
> was
> two boards
> confirm that
anytime.
could
> post
unusable.
> I am
problem
> if it
> >  > exists.
examples.
> Timing
> reproduced in
> problem that
a
> boot
really
> fix the
> ought to be
> > doing?
> > Jaya
2006-02-23 by marko.panger@siol.net
Define a function pointer:
STATUS (*ptrghigh_fxn)(uint8 evt, void *parg1, void *parg2); /* Pointer to the trigger function */
Initi it:
ptrghigh_fxn = &TriggerFxn;
Call it:
ptrghigh_fxn(1,2,3);
Function:
STATUS TriggerFxn(uint8 ucEvent, void *pArg1, void *pArg2) {
   /* do something */
Hope it helps,
marko
---- Marko Pavlin <mp@...> piše:
> void test1(void){
>    puts("blah");
> void *exec;
> void main(void) {
>     __asm
>     	BL 		exec
> Thanks!
> Marko
--- In lpc2000@yahoogroups.com, "Guillermo Prandi"
> own bootloader.
> Guille
Guille,
Jayasooriah provides a description of a problem with an application
using IAP. With the details provided I'd find it difficult to establish
if the problem is with the application, the IAP functions or some
combination of the two.
I'm trying to find out if there's a problem with the boot loader, which
as I've explained we use to program the devices.
If there's any confision, I'll try and make the question simpler: "is
there a problem with the boot loader that could cause it to fail to
function, and if so, under what circumstances?"
In case there's any confusion over what the boot loader is: my
understanding is that it's the first piece of software to run on the
device, the primary function of which is to start any valid application
it finds in flash or to load the flash through the serial port. This is
the thing I'm being told is "broken".
I hope this clarifies matters.
Brendan
2006-02-23 by haare_in_der_dusche
> Initi it:
The address operator & can be omitted in that case.
Thus
  ptrghigh_fxn = TriggerFxn;
renders the same functionality.
___________________________________________________________
Telefonate ohne weitere Kosten vom PC zum PC: http://messenger.yahoo.de
--- In lpc2000@yahoogroups.com, "brendanmurphy37" <brendan.murphy@...> wrote:
 > some parts).
Yes you are missing the something an important fact.  Boot loader update
did not stop my code from falling over.  Replacing the flash algorithm did.
I said it boot loader is broken because I am able crash the boot loader at
will on my LPC 2292 irrespective of whether or not CRP is enabled.
 > these parts?
See above.
Yes.  See above.
What happens when the boot loader crashes is indeterminate.  No exception
handling makes matters worse.  In most security contexts, this poses
unacceptable risks.
My task (what I am paid to do) is to mitigate or eliminate threats to
security.  Providing a replacement boot loader is how I chose to do this. I
looked at other options and these were either too expensive or did not
mitigate enough.
You must get your own security assessment done for your particular situation.
 > Regards
 > Brendan
Re: [lpc2000] Re: Tom's questions for Jaya
2006-02-23 by mfrazier@governors-america.com
I also am at the end of a rather long development project on the verge of
production roll out. I have been testing the LPC2134  processor for quite
some time now and have not seen any issues with the boot loader. If it
does exist then either I've been very lucky or the condition exists only
under specific conditions.
Mike
Re: [lpc2000] Jump from variable -> define variable as function
2006-02-23 by Jean-Rene David
* Marko Pavlin <mp@...>:
> > void test1(void){
> >    puts("blah");
> > void *exec;
> > void main(void) {
> >     __asm
> >           BL             exec
You need to declare exec as a function pointer.
Then you can assign it the address of any function
with the same prototype and call it like any other
function:
void test1(void){
   puts("blah");
void (*exec)(void); // Declare as function pointer.
void main(void) {
    exec = test1;
    exec();
* Jim Parziale <nuncio.bitis@...>:
> After setting:
> Just call via exec:
>      exec();
exec must be declared as a function pointer,
otherwise the compiler won't know how to set up
the parameters and pick up the return value for
the function (even if there are none in this
case.)
JR
Jaya,
Many thanks for the prompt answers. A couple of follow-up points below.
loader at
When you say you can crash the boot loader at will, are you talking
about the boot loader itself crashing (i.e. during the boot process
and/or flash load through the serial port), or an application that
calls the IAP functions crashing? We don't use IAP. We do however, use
the boot loader (as I imagine everyone else does).
Also, you mention the LPC2292. Do you happen to know if the problem you
observed is present on the LPC2134?
As a minor point: we're happy with the security of the device. When I
used the term risk assesment, I meant the normal evaluation of product
prior to release to determine how likely it is we'll get problems in
production and/or returns from the field.
I really apreciate your input on this, as I'm sure others do too.
Brendan
You say at will...what exactly are you doing that causes this failure?? We
also have a project in mid stages of development that use the LPC2292 and
speaking with other engineers on the project they claim they have not yet
had any issues.
Mike
2006-02-23 by Marko Panger
Its rather a programming style. I prefer to add the & operator, so I am
sure what I am doing. Everyone has his own style. Apart from this you
are right - same functionality.
marko
haare_in_der_dusche wrote:
>>Initi it:
>Thus
>Yahoo! Groups Links
2006-02-24 by lpc2100
<snip>
Only Taxes and Death are certain (Don't recall who said that). Ok you
can evade taxes. No one makes absolute claim these days to avoid
liability. I won't worry about that statement. Have you got anything else?
code was
> volatile during that time.] <snip>
I have a different experience. After upgrade failing parts programmed
flawlessly. I don't read this group regularly. Did anyone else report
flash problems after upgrade on the group?
boards
that
Is it possible that you erased the philips bootloader while reverse
engineering the bootloader. Can't you revive the dead boards since you
have the ability to reprogram the boot sector with your own
bootloader. Have you tried to reprogram the chip via JTAG using your
own flash programming algorithms? If you can't access those chips via
jtag then this would indicate dead parts. This means that something
else went wrong which caused dead parts.
Timing
reproduced in
that
fix the
to be
> doing?
No offence but without a solid example above explanation sounds like
putting 2 and 2 together unscientifically.
2006-02-24 by Jayasooriah
Hello lpc2100, I will answer you question assuming it is an open question:
It is not possible to erase the boot loader by reading it out.  All my
reverse engineering was done using the hex file.
 > bootloader.
If the boot loader is dead my loader does not get run.
No.
I do not know.  See above.
Reverse engineering can also mean verifying your findings. What if you
erased the philips bootloader while developing your own.
Anyway I can rest easy and hope other IAP users too. It is safe to
make IAP calls.
Tom
2006-02-25 by Jayasooriah
Tom, what you say does not appear to add up:
>Message: 12
>    Date: Fri, 24 Feb 2006 17:06:25 -0000
>    From: "lpc2100" <lpc2100@...>
>Subject: Re: Tom's questions for Jaya
All my reverse engineering was done using the hex file.  (I can point you
to the URL if you like to know more...)
As I explained, my findings during in FTL testing are that IAP calls failed
and did not return.  Anyone who knows about FTL would immediately recognise
how good FTL is in flushing out flash memory reliability problems.
I was also reminded that Philips took set an entire section to explain
ECC  alludes one to problems with flash reliability.
While the ECC section appears to be a spin doctoring (reporting a bug as a
feature) of defects in the ECC implementation, the fact that ECC is
required IMO is there are flash reliability problems.
I have never previously worked with flash memories for which I could not
take advantage of their NOR or NAND properties.
Philips most recently has given a further indication of this by stating
"the bootloader is unlikely to get erased or corrupted during IAP call even
This begs the question: what does happen then?
>What if you
My boot loader (in the context of the FTL problem I reported) is no more
than an application run by the Philips boot loader and which sits in sector
0.  It does not have any flashing capability whatsoever.
It does not speak well of the LPC if the boot sector can be destroyed in
the process of developing an "application", albeit this application serves
to load Intel-Hex formatted files into RAM, not flash.
>make IAP calls.
I have no objections to you resting easy, but advising other uses IMO does
not make sense.  What is your justification for refuting my evidence?
Jaya
2006-02-27 by brendanmurphy37
I think anyone reading the message below, and in particular the
statement "....there are flash reliability problems", needs to ask
themselves what hard evidence is being produced for the claim.
I just raise this as a question: I've no intention of getting sucked
into yet another discussion on whether particular problems exist or
not.
Brendan
> >Message: 12
All my
point you
calls failed
recognise
explain
bug as a
could not
stating
call even
> >What if you
more
in sector
destroyed in
serves
> >make IAP calls.
IMO does
evidence?
> Jaya
2006-02-27 by Jayasooriah
I find Brendan Murphy's comments very unprofessional.  I am not sure if he
is are deliberately being slippery.  Here is why I question his modus operandi:
1/  This thread was created by Tom (on my accepting Peter's taunt') to put
his questions for discussion.
Brendan butts in with his requests for confirmation or denial of his
wording of what I say as if he needs this clarification formally.
2/  He sends me long unsolicited private emails, two which I discovered
while cleaning up my junk mailbox.  I responded to the third and and told
you in in one line what I think he should do with private email to me.
When I refer to this conduct as:
>You would have realised I did this if only you spent less time attacking
>the messenger and put more effort in digesting the message.
he responds:
>I'd hardly call asking for evidence for a claim as attacking the messenger!
Now he says:
3/  What is this "hard evidence" I am supposed to put on on this forum for
Brendan?  My application that failed, my fix of Philips "proprietary" flash
algorithm?  What is unscientific and unclear about what I found:
a)  Application failed.  Traced it to IAP calls relating to flash erases
and writes.
b)  Looked at the implementation of flash write and erase algorithms in
boot loader (that IAP uses) and found defects.
c)  Fixed these defects.  Application no longer failed as it did before I
fixed the defect.
d)  Explained what the fix is, how it addressed the problem using the above
findings other information -- the problem was reasonably well documented
despite the fact that the algorithm is "proprietary".
 > not.
Yeah sure.
2006-02-27 by lpc2100
failed
recognise
bug as a
not
Flash ECC requirement varies from technology, process, type. Nand
flash  memories have 16 bytes allocated per 512 bytes for ECC data.
Presence of ECC does not indicate a problem as long as data is intact.
AFAIK only Philips has cmos 18 embedded flash technology. ECC might be
a requirement at this process geometry.
call even
Again this type of language is used by companies to avoid making
absolute claims. Does not bother me at all. I don't expect programming
/erase to succeed with wrong frequency.
> >What if you
more
sector
destroyed in
serves
Didn't you say (in some other post) that you have a better flash
programming algorithm than Philips? While developing that algorithm it
is possible to erase the boot sector. My apologies if you did not make
that claim.
IMO does
Lack of concrete evidence (code example/conditions demonstrating the
problem). Thousands of lpc users around the world are
using IAP/ISP without any failure. BTW ISP also uses IAP to program
the flash. I expect to see a lot more users reporting erased boot
sector. So far there are only two. One of them turned out to be a
false alarm.
Tom
2006-02-28 by brendanmurphy37
if he
modus operandi:
to put
> [...and mouch more along this vein]
I've already said I wasn't going to be sucked into more discussions on
this, much less into trading abusive comments.
I won't be making any further comments on this whole series of related
threads.
As I said before, people should and will make up their own minds on
the merits of any message posted.
Brendan
