Lpc2000
Bootloader not always invoked after reset with P0.14 low
2006-02-06 by Guillermo Prandi
Hi, I wonder if anyone has seen this before.
While developing the firmware for my LPC2138-featured board, I noticed
that the bootloader is not always invoked after a reset with P0.14 low.
Even when the bootloader is not invoked, the device still responds to
reset.
I tested with the Philips bootloader utility, which, measured at the
reset and P0.14 pins, gives me:
1) At T+0, P0.14 goes down from 3.3V to 0V sharply.
2) At T+0, Reset starts going down from 3.3V to 0V in an RC-type curve
of 750µS.
3) At T+750µS both Reset and P0.14 are now 0V.
4) At T+500 mS reset starts going up, having been effectively low for
499mS. The rising curve is also RC-type and takes about 2 mS to reach
85%.
5) At T+840 mS, P0.14 goes up sharply. This is 338 mS *after* reset
went high.
By the spec, these figures should be large enough to trigger the
bootloader, and it does, except when I've been playing around with my
firmware for a while (several cycles of compile+flash programming,
tests, an occasional crash, watchdog triggered, etc.). When the
bootloader stops responding, the only way to regain the bootloader is
by removing power.
Any ideas?
Guille
re: Bootloader not always invoked after reset with P0.14 low
2006-02-07 by Jayasooriah
Hi Guille,
I have seen this problem before on 2292 and the culprit appears to be what
the boot loader does on watchdog resets when there is on-chip flash with
external memory boot capability.
The "USAGE NOTES ON WATCHDOG RESET AND EXTERNAL START" section of 2292
explains (in a longish way) the limitations (see below).
If you cannot guarantee that certain GPIO signals (not just those
documented) are not in a particular state when configured as input at the
time watch dog timer fires, you can lock yourself up in ways and require
hard reset.
It does not matter if you are not using the external boot feature, or for
that matter, use the external memory interface.
It is a pity, this appears not to be a processor limitation, but a boot
loader limitation or bug.  I have not had time to look at the boot loader
source as yet.
Jaya
>When LPC2292/2294 is conditioned by components attached to the BOOT1:0
>pins to start execution in off-chip memory, and is programmed to enable
>the Watchdog Timer to reset the part if it is not periodically serviced,
>care must be taken to avoid problems due to the interaction of these features.
>First, the BOOT1 and/or BOOT0 pin(s) must be biased to ground using
>pulldown resistors, not transistors driven from RESET low, because RESET
>is not driven low during a Watchdog Reset.
>Second, if either or both of the BOOT1:0 pins are used as inputs in the
>application, the application designer must ensure that the external driver
>will not be enabled during an internal Reset generated by the Watchdog Timer.
>(One way to do this is to use one of the CS3:0 outputs to enable the driver.)
>If these two conditions cannot be met, an external Watchdog facility can
>be used.
>    Date: Mon, 06 Feb 2006 12:53:07 -0000
>    From: "Guillermo Prandi" <yahoo.messenger@...>
>Subject: Bootloader not always invoked after reset with P0.14 low
>went high.
>by removing power.
>Any ideas?
>Guille
Send instant messages to your online friends http://au.messenger.yahoo.com
Re: Bootloader not always invoked after reset with P0.14 low
2006-02-07 by Guillermo Prandi
Hi, Jayasooriah. What do you mean by "hard reset"? If you mean having
the reset pin low, then I *am* performing a hard reset. The problem
shows up when I attempt to access ISP via serial port (DTR goes to
RESET, RTS goes to P0.14).
Guille
--- In lpc2000@yahoogroups.com, Jayasooriah <jayasooriah@...> wrote:
> Hi Guille,
be what
with
2292
at the
require
> hard reset.
or for
boot
loader
> source as yet.
> Jaya
BOOT1:0
enable
serviced,
these features.
using
RESET
in the
external driver
Watchdog Timer.
the driver.)
facility can
> >be used.
> >    From: "Guillermo Prandi" <yahoo.messenger@>
> >went high.
my
is
> >by removing power.
> >Any ideas?
> >Guille
2006-02-08 by Jayasooriah
Hi Guile, I should have said "power on reset".
I removed the problem (was not keen on solving it at that time) by avoiding
use of GPIO pins that the boot loader has allocated for purposes of
"external boot" feature (something that is not necessary and hence of
dubious value in the context of embedded systems).
I believe there are some registers that the boot loader fiddles with which
exhibit "stuck zero" behaviour -- when one writes a zero, these bits stays
zero until power on reset event.
In the 2292 that I am now working on for POE application, I found that if
you do not re-map interrupt vectors to your own memory space, UND, PRE, and
ABT type exceptions can also cause the system to lock up in similar
ways.  Power on reset got me out each time this happened.
Jaya
>    Date: Tue, 07 Feb 2006 13:07:11 -0000
>Subject: Re: Bootloader not always invoked after reset with P0.14 low
>Guille
2006-02-08 by Guillermo Prandi
Ooof... seems like a stinky sticking problem. I'll better attack it
only if it becomes a real PITA. For the moment, instructing the
programming operator to do a power-on reset by hand is perfectly
acceptable.
Thanks a lot.
Guille
avoiding
of
with which
bits stays
that if
PRE, and
> Jaya
low
having
> >Guille
2006-02-23 by philips_apps
Hello Guille,
In case of a watchdog triggered reset, P0.14 pin is ignored by the
bootloader and the valid user application is executed. If valid user
application is not found then only isp is entered. In LPC2138 the WDT
flag is not cleared by pin reset. POR reset clears the WDT flag. What
you are observing is expected behavior. I am assuming that WD reset
happened since you have mention it.
Philips Apps
--- In lpc2000@yahoogroups.com, "Guillermo Prandi"
> reset.
> of 750µS.
> 85%.
> went high.
> by removing power.
> Any ideas?
> Guille
2006-02-23 by Guillermo Prandi
My code is clearing the RISR flags at boot time by doing:
#define RSIR (*((volatile unsigned char *) 0xE01FC180))
RSIR = 0x0f;
After that, the boards still ignores P0.14 after a watchdog reset.
Since I cleared the watchdog reset flag, I expected the bootloader to
invoke ISP. Is there anything else I could do from software in order
to make the bootloader honor the P0.14 pin?
Guille
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@...>
wrote:
> Hello Guille,
WDT
What
> Regards
> Philips Apps
noticed
P0.14 low.
responds to
> > reset.
curve
> > of 750µS.
for
reach
> > 85%.
reset
> > went high.
with my
programming,
bootloader is
> > by removing power.
> > Any ideas?
> > Guille
2006-02-23 by Jayasooriah
Hi Guile,
If you look at the user manual for WTOF bit which the boot loader checks,
it is quite clear that "external reset" will clear this bit.
Can you try without arming the watchdog to see if the problem goes away?
Jaya
--- In lpc2000@yahoogroups.com, "Guillermo Prandi" <yahoo.messenger@...> wrote:
 > RSIR = 0x0f;
 > Guille
 > --- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@>
 > wrote:
 > > Hello Guille,
 > WDT
 > What
 > > Regards
 > > Philips Apps
Hi, Jayasooriah. Indeed the watchdog is the problem. At this stage of
development I am only using the watchdog to provide a software reset
function. Apparently this behavior is triggering only after using
this function. And yes, you are right; the bit should be cleared by
the external reset.
It looks like this behavior is 'by design' so there is no other
workaround than switching off the unit.
Guille
> Hi Guile,
checks,
away?
> Jaya
>  > RSIR = 0x0f;
reset.
bootloader to
order
>  > Guille
>  > wrote:
>  > > Hello Guille,
valid user
>  > WDT
flag.
>  > What
reset
>  > > Regards
>  > > Philips Apps
The bootloader does not look at the RISR register. It looks at the
WDTOF flag in WDMOD register.
Even clearing of watchdog flag in user application may not help (if
timeout is too small) because the bootloader runs before application.
If you are using the watchdog only to trigger ISP then Reinvoke ISP
command might be a better choice. This was added to 213x,214x devices.
Restore Timer1 to reset state if your application uses it.
Refer to Table 218 on page 235 of the user manual
http://www.semiconductors.philips.com/acrobat_download/usermanuals/UM10120_1.pdf
The LPC213x/214x user manual will be updated to reflect the WTOF clear
conditions.
Philips Apps
> RSIR = 0x0f;
> Guille
> wrote:
> > Hello Guille,
> WDT
> What
> > Regards
> > Philips Apps
> noticed
> P0.14 low.
> responds to
> > > reset.
> the
> curve
> > > of 750�S.
> > > 3) At T+750�S both Reset and P0.14 are now 0V.
> for
> reach
> > > 85%.
> reset
> > > went high.
> with my
> programming,
> bootloader is
> > > by removing power.
> > > Any ideas?
> > > Guille
2006-02-24 by Guillermo Prandi
Oh, thanks Richard!
After your words, the following sequence in my startup code seems to
do the trick:
WDMOD = 0; // I don't know if this is actually required
WDFEED = 0xaa;
WDFEED = 0x55;
Guille
application.
devices.
0120_1.pdf
clear
> conditions.
> Regards
> Philips Apps
> > RSIR = 0x0f;
reset.
bootloader to
order
> > Guille
> > wrote:
> > > Hello Guille,
user
> > WDT
flag.
> > What
reset
> > > Regards
> > > Philips Apps
I
> > noticed
> > P0.14 low.
> > responds to
> > > > reset.
at
> > the
type
> > curve
> > > > of 750�S.
low
> > for
to
> > reach
> > > > 85%.
> > reset
> > > > went high.
> > with my
> > programming,
> > bootloader is
> > > > by removing power.
> > > > Any ideas?
> > > > Guille
2006-02-25 by Jayasooriah
Hi Guile,
I am looking at what appears to be a different manifestation of the problem
you encountered in that power cycling is required to recover form a lockup
in order to transfer control to ISP by pulling P0.14 low.
Philips explains this happens can if "timeout value is too small".  The
user manual seems to say writing anything less than 0xff will result in
minimum timeout of PCLK x 256 x 4.
The test code below then should create the lockup scenario, but it does not
on my 2292.  I cannot see where I got it wrong.
Can you try this on your board please?
Thanks.
Jaya
GNU Source:
>@ Interrupt Vectors
>         .code   32
>         @ entry points vector
>start:
>         ldr     pc, =error
>         ldr     pc, =error
>         ldr     pc, =error
>         ldr     pc, =error
>         ldr     pc, =error
>         ldr     pc, =error
>         ldr     pc, =error
>         ldr     pc, =error
>         .ltorg
>@ End of Interrupt Vectors
>@ Error Scenario
>         .code   32
>error:
>         @ force reset
>         ldr     r0, =WATCH_DOG
>         mov     r1, #3
>         str     r1, [r0, #0]
>         str     r1, [r0, #4]    @ WDTC = 3
>         mov     r1, #0xaa
>         str     r1, [r0, #8]    @ WDFEED = 0xaa
>         mov     r1, #0x55
>         str     r1, [r0, #8]    @ WDFEED = 0x55
>         b       .
>@ End Error Scenario
HEX Binary: (vectors not check-sum patched)
>:1000000018F09FE514F09FE510F09FE50CF09FE5D8
>:1000100008F09FE504F09FE500F09FE504F01FE580
>:10002000240000000E02A0E30310A0E3001080E50E
>:10003000041080E5AA10A0E3081080E55510A0E3A5
>:08004000081080E5FEFFFFEA55
>:00000001FF
>Message: 17
>    Date: Thu, 23 Feb 2006 12:30:37 -0000
>the external reset.
>Guille
>Message: 8
>    Date: Thu, 23 Feb 2006 23:28:38 -0000
>    From: "philips_apps" <philips_apps@...>
2006-02-25 by Guillermo Prandi
I don't understand very well what is it that you want me to test. By
clearing the watchdog flags my problem went away.
Guille
> Hi Guile,
problem
lockup
The
result in
does not
> Thanks.
> Jaya
> GNU Source:
> >@ Interrupt Vectors
> >         .code   32
> >start:
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         .ltorg
> >@ Error Scenario
> >         .code   32
> >error:
> >         @ force reset
> >         ldr     r0, =WATCH_DOG
> >         mov     r1, #3
> >         str     r1, [r0, #0]
> >         mov     r1, #0xaa
> >         mov     r1, #0x55
> >         b       .
> >:00000001FF
> >Message: 17
low
of
reset
> >the external reset.
> >Guille
> >Message: 8
low
application.
2006-02-26 by Jayasooriah
Hi Guile,
I may be misunderstanding the problem.
You made the comment:
>It looks like this behavior is 'by design' so there is no other workaround
Philips followed up:
For purposes of ruling out watchdog issues in problem I am looking into, I
want to recreate the above watchdog problem.
My sample code sets up the watchdog to trigger in minimum time, and does
nothing but wait for the watchdog to trigger.
In had no problems getting back to ISP with this code on my 2292.  I did
not need to switch off.
I wanted to try this on your board.  If it works without need to switch
off, then my understanding of the problem is incorrect.  If it does need
you to switch off, then the problem may be specific to the part of version
of boot loader.
I like to find out which of the above is the case.
Jaya
2006-02-26 by Guillermo Prandi
OK. I'll run your code. What is exactly what you want me to report
about it? Whether it can call the bootloader without a power-on reset?
Guille
> Hi Guile,
workaround
(if
application.
into, I
does
I did
switch
need
version
> of boot loader.
> Regards,
> Jaya
2006-02-26 by jayasooriah
Yes, that will do.  Thanks.
Jaya
2006-02-28 by Guillermo Prandi
Jaya: with your code, bootloader is not invoked if the reset/P0.14
signals don't run along with a power on. This was the expected
behavior, isn't it?
Guille
> Hi Guile,
problem
lockup
The
result in
does not
> Thanks.
> Jaya
> GNU Source:
> >@ Interrupt Vectors
> >         .code   32
> >start:
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         ldr     pc, =error
> >         .ltorg
> >@ Error Scenario
> >         .code   32
> >error:
> >         @ force reset
> >         ldr     r0, =WATCH_DOG
> >         mov     r1, #3
> >         str     r1, [r0, #0]
> >         mov     r1, #0xaa
> >         mov     r1, #0x55
> >         b       .
> >:00000001FF
> >Message: 17
low
of
reset
> >the external reset.
> >Guille
> >Message: 8
low
application.
