Lpc2000
AD0 not working properly - help
2006-03-03 by Sutton Mehaffey
I am trying to read a battery voltage (~12V) on AD0 channel 2.  I have
a breadboard circuit with a voltage divider that is working properly
that gives a reading between 1.8V and 2.3V more or less.  I am using a
variable power supply to generate these voltages.
When I connect the 1.8-2.3V to P0.29 (AD0.2), I read CFF (all 10 bits
high) no matter what.  Can someone tell by the code below if I have a
setting wrong?  My PCLK is 12Mhz.
AD0CR |= 0x00200000;  // turn on AD0
AD0CR |= 0x00000400;  // divide 12Mhz clock by 3 (max 4.5Mhz ADC clk)
AD0CR |= 0x00000004;  // select channel AD0.2
AD0CR |= 0x01000000;  // start conversion now
while ((AD0STAT & 0x00000004) == 0);   // DONE2 status bit in AD0STAT
result = (AD0DR2 & 0x0000FFC0) >> 6;   // bits 6-15 are result (0-2055)
DONE2 is set, and result is always CFF.
Sutton - dodge1955
Re: [lpc2000] AD0 not working properly - help
2006-03-03 by Richard Duits
You should start the AD conversion with a single write and not a series
of read-modify-write operations.
Also make sure that none of the ADC capable pins stay below 3.3 Volt
even if they are not used as ADC inputs (see errata for more info).
Make sure you configure the pin as ADC input with the pin configuration
registers.
Richard.
Sutton Mehaffey wrote:
> Please help us to improve Yahoo! Groups. Take the survey now!
> <http://v2.decipherinc.com/survey/yahoo/yah05014?list=18>
> Sutton - dodge1955
Re: AD0 not working properly - help
Richard,
I had these set up in an init file that I didn't include with the code.
Also, it didn't matter if I did the write to AD0CR all at once or
separate.  No change in the data.
I couldn't find anything in the errata sheet.  I printed out Errata
1.2 released on 2/27.  Where is the errata you were referring to?
Sutton
IODIR0 &= 0x8FFFFFFF;   // AD0 (P0.28, P0.29, P0.30) defined as inputs
PCONP |= 0x00001000;    // Enable AD0
PINSEL1 |= 0x15000000;  // AD0.1, AD0.2, AD0.3 all defined
AD0CR = 0x01200404;
// AD0CR |= 0x00200000;  // turn on AD0
// AD0CR |= 0x00000400;  // divide 12Mhz clock by 3 (max 4.5Mhz ADC clk)
// AD0CR |= 0x00000004;  // select channel AD0.2
// AD0CR |= 0x01000000;  // start conversion now
> registers.
> Regards,
> Richard.
(0-2055)
> > Sutton - dodge1955
Re: [lpc2000] Re: AD0 not working properly - help
You did not say which part you are using. The issues with the ADC pins
not being fully 5 volt tolerant may be solved in the newer parts
(LPC214x, etc).
The others items were things I would check or do diffirently, I had no
idea if they are the cause of your problem. Are you sure the conversion
starts? You can add a counter to the wait loop to see if it waits a few
cycles. If it doesn't, you did not start the AD conversion and you need
to check the value you write to the ADCR register.
Richard.
> Richard,
> Sutton
> AD0CR = 0x01200404;
> > registers.
> > Regards,
> > Richard.
> (0-2055)
> > > Sutton - dodge1955
Sorry.  Using LPC2148 on an Embedded Artists Quickstart and Prototype
Board.  Prototype board is nice to have.  Conversion starts because I
get the DONE bit set after a few cycles.  But value read is always all
10 bits high.  I've tried all 3 AD0 (0 doesn't exist) channels (1
channel was determined bad - it has a short to ground).  Haven't
figured out why yet on the all high readings.
Sutton
> (LPC214x, etc).
> Richard.
> > Richard,
code.
> > Sutton
> > AD0CR = 0x01200404;
ADC clk)
series
configuration
> > > registers.
> > > Regards,
> > > Richard.
 I have
properly
using a
10 bits
have a
ADC clk)
AD0STAT
> > (0-2055)
> > > > Sutton - dodge1955
2006-03-07 by K B Shah-lascaux
Is it not suppose to be IO0DIR  &= 0x8FFFFFFF;...???  (You have IODIR0 )   ???
  To: lpc2000@yahoogroups.com
  Sent: Friday, March 03, 2006 4:56 PM
  Subject: [lpc2000] Re: AD0 not working properly - help
  Richard,
  Sutton
  AD0CR = 0x01200404;
  > registers.
  > Regards,
  > Richard.
  (0-2055)
  > > Sutton - dodge1955
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
        Pic microcontrollers
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
  Checked by AVG Free Edition.
  Version: 7.1.375 / Virus Database: 268.1.1/273 - Release Date: 02/03/2006
2006-03-07 by Sutton Mehaffey
It is IODIR0 in the Keil compiler.  I think it is IO0DIR in IAR and
others.
Sutton
IODIR0 )   ???
>   ----- Original Message -----
>   From: Sutton Mehaffey
>   Richard,
code.
>   Sutton
>   AD0CR = 0x01200404;
ADC clk)
series
Volt
configuration
>   > registers.
>   > Regards,
>   > Richard.
 I have
properly
using a
10 bits
have a
ADC clk)
AD0STAT
>   (0-2055)
>   > > Sutton - dodge1955
microprocessors
>   YAHOO! GROUPS LINKS
Service.
02/03/2006
2006-03-07 by 3gpabko
I think that you miss some details in your question.
 Can you verify  that at the moment of starting of the AD conversion the AINx pins are  configured as analog inputs. If you write to the PINSEL register at the  beginning of the program and after that you have another write to the  same PINSEL register which changes the configuration...
 Sure you  have to write to AD0CR in a separate write for setting the START bit.  First you can write to the register a configuration word and then with  a separate write to set the START bit. Be careful when  read-modify-write the AD0CR. If you have START bit already set it will  accidentally start a conversion. Then when you attempt to start the  conversion in the next line you may have the DONE bit set. Read the  manual and errata for details. In this case ensure that your  configuration word for AD0CR clears the START bitfield.
 Can you  verify that your hardware is setup properly. How you source the input  voltage to the AIN0 pin? Are the voltages on the other analog inputs  below 3.3V?
Sutton Mehaffey <sutton@...> wrote:          It is IODIR0 in the Keil compiler.  I think it is IO0DIR in IAR and
  others.
  Sutton
  IODIR0 )   ???
  >   Richard,
  code.
  >   Sutton
  >   AD0CR = 0x01200404;
  ADC clk)
  series
  Volt
  configuration
  >   > registers.
  >   > Regards,
  >   > Richard.
   I have
  properly
  using a
  10 bits
  have a
  ADC clk)
  AD0STAT
  >   (0-2055)
  >   > > Sutton - dodge1955
  microprocessors
  >   YAHOO! GROUPS LINKS
  Service.
  02/03/2006
          SPONSORED LINKS
                                                        Microcontrollers                                          Microprocessor                                          Intel microprocessors        Pic microcontrollers
    YAHOO! GROUPS LINKS
Yahoo! Mail
Bring photos to life! New PhotoMail  makes sharing a breeze.
2006-03-30 by clemens fischer
> Sutton Mehaffey:
what about your Vref?
  clemens
2006-03-30 by Sten
clemens fischer wrote:
>>Sutton Mehaffey:
>   clemens
There're some nasty issues in the errata sheet concering AD!
  Sten
 Do you need a tiny and efficient real time
 operating system (RTOS) with a preemtive
 multitasking for LPC2000 or AT91SAM7?
   http://nanortos.net-attack.de/
 Or some open-source tools and code for LPC2000?
   http://www.net-attack.de/
