Lpc2000
read wrong part id of lpc2136
2006-03-23 by topandurangs
Hi all,
     I have two LPC2136 chips,in which when i am reading there part id
through Philips downloader utility i am getting part id as 2131.
     what is it mean? also when i try to download my code in it ,it
gives error insufficient flash.
     I guess it is problem from philips.
     How to overcome this problem?
Pandurang S.
Re: read wrong part id of lpc2136
2006-03-26 by topandurangs
--- In lpc2000@yahoogroups.com, "topandurangs" <pandurang@...> wrote:
> Hi all,
part id
it ,it
> Regards,
> Pandurang S.
hi,
     Since i am not getting reply for the message i am posting it
again.Pls approch this serious problem if any one can.
Pandurang S.
Re: [lpc2000] Re: read wrong part id of lpc2136
2006-03-26 by Peter Jakacki
I think the obvious answer is that they are 2131s? The Flash utility
says they are plus they do not have the memory of the larger 2136. How
are they branded, have you checked?
Hint! If you cannot read/load more than 32K of Flash then they are 2131s!
*Peter*
topandurangs wrote:
>>      I have two LPC2136 chips,in which when i am reading there part id through Philips downloader utility i am getting part id as 2131.
>>      what is it mean? also when i try to download my code in it ,it gives error insufficient flash.
RE: [lpc2000] Re: read wrong part id of lpc2136
2006-03-26 by Pandurang Shinde
thanks Peter for reply, on the chip it is printed as
        LPC2136FBD64
        S60735.1        04
        ZPG0602B
                      So i am concludung that is LPC2136 only ,but reading LPC2131.
                      Why this happen.
                      Can u suggest any solution for it.
Pandurang S.
From: lpc2000@yahoogroups.com on behalf of Peter Jakacki
Sent: Sun 3/26/2006 4:36 PM
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] Re: read wrong part id of lpc2136
*Peter*
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
	 lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
2006-03-26 by Martin Maurer
Hello,
can you post the id itself, so you can decide if the chip's answer is wrong
or the software on pc is identifying the wrong chip.
As you can see on
http://guest.engelschall.com/~martin/lpc21xx/lpc_ids/index.html
the id for the chip should be the following:
LPC2131: 0x0002FF01 -> 196353
LPC2132: 0x0002FF11 -> 196369
LPC2134: 0x0002FF12 -> 196370
LPC2136: 0x0002FF23 -> 196387
       Martin
To: <lpc2000@yahoogroups.com>
Sent: Sunday, March 26, 2006 2:16 PM
Subject: RE: [lpc2000] Re: read wrong part id of lpc2136
> LPC2136FBD64
> S60735.1        04
> ZPG0602B
> LPC2131.
>                      Why this happen.
> Regards,
> Pandurang S.
> *Peter*
> YAHOO! GROUPS LINKS
> the web.
It is possible that it is branded incorrectly or that an incorrect ID
has been loaded. What you can do is to construct a 32K dummy file to
confirm that it does load and then step it up to 64K, 128K and so on
until you ascertain the memory size.
Once you are sure of your facts you can go back to your supplier to
rectify the situation.
Either way, let us know what you found out.
*Peter*
>        LPC2136FBD64
>        S60735.1        04
>        ZPG0602B
>                       Why this happen.
2006-03-26 by Gerrit de Waard
Hello Pandurang Shinde,
Is it only one chip, or do you have several with the same problem?
I will look into this problem,
Gerrit de Waard,
Product Enigineer Microcontrollers
Philips Semicondictors
ID
to
on
to
> *Peter*
      LPC2136FBD64
      S60735.1        04
      ZPG0602B
> >                       Why this happen.
2006-03-26 by Jayasooriah
Hi Pandurang,
Alternatively you can use my loader available at:
   http://www.cse.unsw.edu.au/~jayas/esdk/sill.html
which reports top ROM (flash) and RAM addresses when you hit the space bar.
I expect the addresses you get will correspond to LPC2131.
The difference between LPC2136 and LPC2131 inside the package is the part
ID that is stored in the boot parameter block.  The boot loader loads this
part ID to a special register on startup and this determines how much RAM
and ROM is enabled.
I too am interested in what you find out.
Jaya
 > *Peter*
LPC2136FBD64
S60735.1        04
ZPG0602B
LPC2131.
 >                       Why this happen.
2006-03-26 by Tom Walsh
>        LPC2136FBD64
>        S60735.1        04
>        ZPG0602B
>                      Why this happen.
Yes, contact your local Philips representative and ask them the
question.  Traditionally, semiconductor manufacturers have a staff of
field personnel who answer such questions about thier products.
Here on this list, we are like you: we have used the Philips products in
our PCB designs, or are doing projects using such boards.
I would suggest you begin with the distributor who sold you the chips.
Ask them this question.  Ask them if they have a either a "Field
Engineer"  or "Technical Representative" for Philips.
TomW
Hello,
Sorry I mistakenly said you should use the space bar.  As the on-line
manual says, the use the '?' character to print memory limits.
Jaya
>Message: 2
>    Date: Mon, 27 Mar 2006 01:57:52 +1100
>    From: Jayasooriah <jayasooriah@...>
>Subject: Re: read wrong part id of lpc2136
>Hi Pandurang,
CORRECTION: not space bar, but the '?' character ... see the on-line manual.
>and ROM is enabled.
>Jaya
>  > *Peter*
>LPC2136FBD64
>S60735.1        04
>ZPG0602B
>LPC2131.
>  >                       Why this happen.
Send instant messages to your online friends http://au.messenger.yahoo.com
2006-03-26 by derbaier
     LPC2136FBD64
     S60735.1        04
     ZPG0602B
reading LPC2131.
>                       Why this happen.
> Regards,
> Pandurang S.
It is fairly common to "bin" parts during prepackaging testing, so
that chips that have failed some part of the testing can still be
used.  If a segment of memory fails in testing the part can simply be
downgraded to the next smaller memory specification and sold at a
reduced price. In other kinds of ASIC chips that is usually done as a
bond out option, but in this case it was apparently done when the boot
loader was programmed prior to packaging. Since the tests are
performed prior to packaging, it is possible that the chips you have
were simply mispackaged if you only have a very small quantity of
chips exibiting the problem that you describe. If you can, it would
probably be good if you could return the chips to your distributor for
replacement. That way, Phillips would be able to verify the problem
and possibly eliminate future occurances. In other words, it is fairly
likely that you have an LPC2131 silicon in a LPC2136 package.
That's just my guess!
-- Dave
2006-03-27 by Jayasooriah
Dave,
An alternative scenario (that was suggested by a foundry expert I spoke to
when I first discovered this) is more plausible for the following reasons:
1/  The boot loader does not select good segment(s) for RAM or ROM.  It
only limits their sizes by reducing the respective bound.  In other words
the boot loader does not set or change the base.
2/  It is very unusual to use this method (of selecting using bound only)
to improve yield.  He thought that for the sizes of RAM and ROM involved
here, it is unlikely there are yield problems to the extent software is
used to adjust the bound post production.
Jaya
 > -- Dave
2006-03-27 by derbaier
--- In lpc2000@yahoogroups.com, Jayasooriah <jayasooriah@...> wrote:
> Dave,
spoke to
reasons:
words
That particular assertion would be much more assuring if it was coming
from Phillip's.   As for size limiting, of course the FLASH address
decoder requires some remapping, but if that is implemented in FLASH
itself that is really trivial.
only)
> to improve yield.
Selecting bounds only would be practically useless, since error
segments are randomly located. The FLASH address decoder also needs
adjustment. However, remapping FLASH segments during prepackaging
tests is a very routine operation.
GIGO
> Jaya
boot
distributor for
fairly
>  > -- Dave
re: read wrong part id of lpc2136
Hello,
Consider results for LPC2292 I just did to test out your proposition:
The code I used to test this out is as follows:
>         ldr     r1, =0x3fff8000
>         ldr     r0, =0x0401ff13
>         str     r0, [r1, #0]
The part ID for LPC2292 is 0x0401ff13.  The table below gives the max ROM
and RAM addresses I get when I changed the each of the last two digits of
part ID as follows:
>Part Id   ROM lim    RAM lim
>0401ff13  0003ffff   40003fff
>0401ff12  0001ffff   40003fff
>0401ff11  0000ffff   40003fff
>0401ff10  00007fff   40003fff
>0401ff03  0003ffff   40001fff
The fist one is with the correct part ID.  The next three show how ROM is
reduced by changing the last digit.  The last one shows how RAM is reduced
by changing the last second digit.
 > --- In lpc2000@yahoogroups.com, Jayasooriah <jayasooriah@> wrote:
 > > Dave,
 > spoke to
 > reasons:
 > words
Philips has not commented on this issue when I first raised it.  It was
left to the rest of us who do not know authoritatively what happens in the
boot loader to debate on possible scenarios.
 > only)
 > > to improve yield.
There seems to be nothing more than just the loading of the part ID to the
special address that does the trick.  The same pattern for ROM also exists
for RAM.
Thus I do not think any flash decoder operations are involved.
Jaya
2006-03-27 by Pandurang Shinde
hi,
        thanks to all.
        Gerrit, i have 45 chips out of  300  having this problem.I can make arrangment to send you the chip.If you want any more details please contact.
        When i am using LPC downloader  to download the file in to chip,i get warning that flash limit excedded & downloading of file continues.
        I also have doubt to jaya that i download the file in path:
        for using these files i have need  any different develoment board,because presently i dont have any USB port.
       The part id that i read is 196353 which correspond to LPC2131 as per table given by Martin.
Pandurang S.
From: lpc2000@yahoogroups.com on behalf of Gerrit de Waard
Sent: Sun 3/26/2006 8:11 PM
Subject: [lpc2000] Re: read wrong part id of lpc2136
Gerrit de Waard,
ID
to
on
to
> *Peter*
      LPC2136FBD64
      S60735.1        04
      ZPG0602B
> >                       Why this happen.
SPONSORED LINKS
Microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ>  	Microprocessor <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=9jjd2D3GOLIESVQssLmLsA>  	Intel microprocessors <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw>
Pic microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw>
YAHOO! GROUPS LINKS
Hi Pandurang,
You do not need USB to use the tools I have put up.  It was originally for
the CSE@UNSW board that has FT232 interface in lieu of conventional serial
port.
In your case, if you are connecting your board to "com1" for example, then
replace all references in the pages to "usb.1" with "com1" and it will work.
If you can get SILL into your flash, I have a couple of hex files that I
can send you that will, for example, dump the contents of boot sector and
help you work out what exactly is happening to the culprit parts in your batch.
The boot parameter block not only holds the part ID, but also start and end
addresses of every flash sector in your part.
Jaya
