Lpc2000
Flashless LPC2210, flash download?
2006-03-30 by volunteer_sysu
I am beginner in LPC2000. I want to ask some questions. Thank you!
1. I wonder whether there's any free software that can be used to
download programs to the external flash via UART or JTAG?
2. I don't know how to use the ISP protocol provided by Philips, will
anyone who has written a program to download programs to the external
flash teach me how to do that, or send me the source code? thanks!
Re: [lpc2000] Flashless LPC2210, flash download?
2006-03-30 by Dominic Rath
Hello,
you can't use the ISP protocol to program an external flash. On the 2210/20
it's only possible to transfer code to target RAM. Philips can't know how
your external memory wants to be programmed.
The OpenOCD (GPLed JTAG debugger for ARM7/9 systems, happens to be my
project ;)) supports programming of external CFI compatible flashes using the
Intel commandset.
Dominic
Re: Flashless LPC2210, flash download?
Thank Dominic, I heard that first I could write my program to the on-
chip RAM via ISP, then I could used the pre-downloaded program to
download my bootloader to flash if the program running in RAM is a
flash program. Is it that possible? Is there anyone doing this
before, and will it be very difficult? Another question is where can
I download openOCD?
Best Regards
--- In lpc2000@yahoogroups.com, Dominic Rath <Dominic.Rath@...>
wrote:
> Hello,
the 2210/20
know how
my
flashes using the
> Intel commandset.
> Regards,
> Dominic
you!
will
external
thanks!
Re: [lpc2000] Re: Flashless LPC2210, flash download?
Sure, you could write a flash program, write that to target RAM, and execute
it there. It could then write your external flash. Maybe one of the free
bootloaders (Apex?) is small enough to fit into the LPC2000, and has already
been ported. Ecos/Redboot has support for the lpc2000, but I'm not sure if
that's available in the free version, or only via EcosPro.
The OpenOCD is available at openocd.berlios.de
Dominic
> I download openOCD?
> Best Regards
I have downloaded the openOCD from the website you gave to me,
however, when I tried to make the Makefile, errors always occured.
It happened both in Linux and Window using cygwin. Then what's the
problem?
Best Regards.
and execute
the free
has already
sure if
> Regards,
> Dominic
the on-
a
can
> > I download openOCD?
> > Best Regards
Sorry to ask so many question. One more. ^_^
Does the openOCD support flashless LPCs?
Thank you indeed!
and execute
the free
has already
sure if
> Regards,
> Dominic
the on-
a
can
> > I download openOCD?
> > Best Regards
What version did you download? What errors occured? If there are more
problems, consider using the OpenOCD help forum at
https://developer.berlios.de/forum/forum.php?forum_id=12655
OpenOCD should work with flashless LPCs, too, just don't specify a "flash
bank" in the configuration file.
You should have a look at the documentation at
http://openfacts.berlios.de/index-en.phtml?title=Open_On-Chip_Debugger
Dominic
> problem?
> Best Regards.
The errors are as follows. I have no idea about what happend. I
think I downloaded the latest version.
Best Regards
Kevin
if gcc -DHAVE_CONFIG_H -I. -I. -I../..     -g -O2 -MT command.o -MD -
MP -MF ".deps/command.Tpo" -c -o command.o command.c; \
then mv -f ".deps/command.Tpo" ".deps/command.Po"; else rm -
f ".deps/command.Tpo"; exit 1; fi
rm -f libhelper.a
ar cru libhelper.a binarybuffer.o configuration.o log.o
interpreter.o command.o
ranlib libhelper.a
make[3]: Leaving directory
`/cygdrive/d/kevin/software/openocd/src/helper'
Making all in jtag
make[3]: Entering directory
`/cygdrive/d/kevin/software/openocd/src/jtag'
if gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/helper -
I/home/vmaster/D2XX_3.01.04//     -g -O2 -MT jtag.o -MD -MP -
MF ".deps/
jtag.Tpo" -c -o jtag.o jtag.c; \
then mv -f ".deps/jtag.Tpo" ".deps/jtag.Po"; else rm -
f ".deps/jtag.Tpo"; exit 1; fi
I/home/vmaster/D2XX_3.01.04//     -g -O2 -MT bitbang.o -MD -MP -
MF ".de
ps/bitbang.Tpo" -c -o bitbang.o bitbang.c; \
then mv -f ".deps/bitbang.Tpo" ".deps/bitbang.Po"; else rm -
f ".deps/bitbang.Tpo"; exit 1; fi
I/home/vmaster/D2XX_3.01.04//     -g -O2 -MT parport.o -MD -MP -
MF ".de
ps/parport.Tpo" -c -o parport.o parport.c; \
then mv -f ".deps/parport.Tpo" ".deps/parport.Po"; else rm -
f ".deps/parport.Tpo"; exit 1; fi
I/home/vmaster/D2XX_3.01.04//     -g -O2 -MT ftd2xx.o -MD -MP -
MF ".dep
s/ftd2xx.Tpo" -c -o ftd2xx.o ftd2xx.c; \
then mv -f ".deps/ftd2xx.Tpo" ".deps/ftd2xx.Po"; else rm -
f ".deps/ftd2xx.Tpo"; exit 1; fi
ftd2xx.c:36:20: ftd2xx.h: No such file or directory
ftd2xx.c:72: error: parse error before "ftdih"
ftd2xx.c:72: warning: initialization makes integer from pointer
without a cast
ftd2xx.c:72: warning: data definition has no type or storage class
ftd2xx.c: In function `ftd2xx_speed':
ftd2xx.c:100: error: `FT_STATUS' undeclared (first use in this
function)
ftd2xx.c:100: error: (Each undeclared identifier is reported only
once
ftd2xx.c:100: error: for each function it appears in.)
ftd2xx.c:100: error: parse error before "status"
ftd2xx.c:108: error: `status' undeclared (first use in this function)
ftd2xx.c:108: error: `FT_OK' undeclared (first use in this function)
ftd2xx.c: In function `ftd2xx_send_and_recv':
ftd2xx.c:186: error: `FT_STATUS' undeclared (first use in this
function)
ftd2xx.c:186: error: parse error before "status"
ftd2xx.c:203: error: `status' undeclared (first use in this function)
ftd2xx.c:203: error: `FT_OK' undeclared (first use in this function)
ftd2xx.c: In function `ftd2xx_init':
ftd2xx.c:621: error: `FT_STATUS' undeclared (first use in this
function)
ftd2xx.c:621: error: parse error before "status"
ftd2xx.c:631: error: `status' undeclared (first use in this function)
ftd2xx.c:631: error: `FT_OPEN_BY_DESCRIPTION' undeclared (first use
in this function)
ftd2xx.c:631: error: `FT_OK' undeclared (first use in this function)
ftd2xx.c:634: error: `FT_LIST_NUMBER_ONLY' undeclared (first use in
this function)
ftd2xx.c:644: error: `FT_LIST_ALL' undeclared (first use in this
function)
ftd2xx.c:703: error: `FT_PURGE_RX' undeclared (first use in this
function)
ftd2xx.c:703: error: `FT_PURGE_TX' undeclared (first use in this
function)
ftd2xx.c: In function `ftd2xx_quit':
ftd2xx.c:714: error: `FT_STATUS' undeclared (first use in this
function)
ftd2xx.c:714: error: parse error before "status"
ftd2xx.c:716: error: `status' undeclared (first use in this function)
make[3]: *** [ftd2xx.o] Error 1
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/cygdrive/d/kevin/software/openocd/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/cygdrive/d/kevin/software/openocd'
make: *** [all] Error 2
kevinzhu@jerryliu /cygdrive/d/kevin/software/openocd
more
a "flash
Chip_Debugger
> Regards,
> Dominic
occured.
> > problem?
> > Best Regards.
I guess this was the last release from the files section, precompiled for
Cygwin with support for FTDI FT2232 based JTAG interfaces.
Try this one instead:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/openocd_svn55_win32_cygwin.zip
It comes with all the files necessary and you don't have to build it yourself.
Dominic
> Best Regards
> Kevin
Thanks a lot.
Best Regards.
Kevin
precompiled for
it yourself.
> Regards,
> Dominic
> > Best Regards
> > Kevin
Dominic,
I still meet a problem when trying to run the version you
recommended. The problem is where I should run this version, cygwin,
DOS, or just double click it? I tried all of them, but none worked.
And the problem with the version I downloaded before is that one
headfile missing, exactly ftd2xx.h, whose directory is
openocd\src\jtag. And this version was downloaded from the website
showing as follows:
http://prdownload.berlios.de/openocd/openocd-cygwin-ftd2xx-
20060213.tar.gz
Best Regards
Kevin
precompiled for
it yourself.
> Regards,
> Dominic
> > Best Regards
> > Kevin
Hello,
the OpenOCD requires a configuration file, specifying the JTAG interface to
use, the layout of the JTAG scan chain, the target connected, and other
things. By default, it tries to open 'openocd.cfg' in the same directory as
the binary, but you can select the configuration file with the '-f
config.file' command line switch.
This means that double-clicking wont work, unless you use a link specifying
the appropriate command line arguments.
Dominic
On Thursday 30 March 2006 14:48, volunteer_sysu wrote:
> Dominic,
> showing as follows:
> 20060213.tar.gz
> Best Regards
> Kevin
2006-03-30 by fordp2002
You need to :-
1) Get Jim Lynch's latest tutorial. Search elsewhere in this group for
where to get it from. Make sure it is the version based on OpenOCD and
you use the exact version that jim mentions. You can however use the
latest version of OpenOCD that dominic gave you a URL too.
2) Adapt Jim's Led Flashing program to suit your chip, this will at
least need modification of the Linker scripts. Make sure you try the
running from RAM bit and skip past the running from Flash bit.
Does anybody in this group have or know where to get a linker script
for Kevin's chip ????? It may be in the files section of this group.
3) Once you have LED flashing then your Toolchain is working. Then you
can move on to look at using OpenOCD to write to your flash.
--- In lpc2000@yahoogroups.com, "volunteer_sysu" <volunteer01@...> wrote:
> Dominic,
> showing as follows:
> 20060213.tar.gz
> Best Regards
> Kevin
> --- In lpc2000@yahoogroups.com, Dominic Rath <Dominic.Rath@>
> precompiled for
> it yourself.
> > Regards,
> > Dominic
> > > Best Regards
> > > Kevin
2006-03-30 by Robert Adsett
Well, you could use the serial ISP to bootstrap the programming routines
into RAM.  That's how some serial ISPs work even for internal flash.  The
ST10 as an example loads something like 16 bytes from the serial port to a
fixed memory location and then jumps to it.  The serial ISP process is a
set of step loading larger programs into RAM until you have one that can
handle the flash programming.  It's a lot more straightforward than I just
made it sound.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2006-03-31 by volunteer_sysu
Hello, Dominic
I wonder whether I can use the schema of the JTAG in your
document "Open On-chip Debugger" to make a JTAG interface. Then I
can use it to debug my evaluation kit in openOCD, right?
Thanks & Regards!
Kevin
wrote:
> Hello,
the 2210/20
know how
my
flashes using the
> Intel commandset.
> Regards,
> Dominic
you!
will
external
thanks!
Bascom Arm
2006-04-08 by Alex Gibson
Just noticed on the Bascom discussion list
that they have announced that there will be a Bascom Arm version.
No availability announced
Mark Alberts wrote:
 > Hi,
 > kill is not needed, next version has 2561 support and 2560 will also
 > follow quick.
 > And instead of avr32 i have decided to go ARM. ARM is multi vendor and
 > AVR32 not.
 > But only after new bascom-avr and bascom-8051 IDE's are released which
 > will be this year.
 > mark
 > On Tue, 04 Apr 2006 07:37:26 -0700, Ken Arck wrote:
 >> At 10:30 AM 4/4/2006 -0400, you wrote:
 >> I am not suggesting the end of Bascom-Avr,  but the beginning of
 >> Bascom-ARM.
 >> <---Agreed! I'd kill for AT2560 & 2561 support!
 >> Ken
Alex
