OpenOCD Data aborts
2006-04-01 by yugandhar_vasi
I am unable to debug the programs properly using Open OCD and Olimex cable + Olimex 2148 board. I get a lot of these messages when debugging. Sometimes it just recovers but after 10-12 attempts, it just doesn't proceed. Is it the same case with everybody or nobody has seen these messages so far at all? Everybody is able to debug properly without any problems for the program running in Flash and program in RAM? The same happens to me either I try to debug from flash or RAM. For RAM I enable soft breakpoints and for flash I use only onchip breakpoints. I use GDB (Insight). Error: arm7_9_common.c:1628 arm7_9_read_memory(): memory read caused data abort Thanks Yug
