Lpc2000
Please help:: checking for data receive in USB Endpoint
2006-04-07 by Manisha Kalita
Hi all,
i am designing an USB driver in lpc2000 board. it is sending the data
properly. however, during reception, i am checking if any data is there in
the deveice register RXPLENGTH. if there is any peacket, PKT-RDY bit of this
register is set. but, in my case, even though no data is sent from the host,
PKT_RDY bit is always set. i am using interrupt transfer and so using
logical endpoint as 1.
i am really stuck in this big problem. its urgent. if anyone has any idea
please reply.
thanks for going through the problem.
Thanks & Regards
Manisha
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s)and may contain confidential or privileged information. If you are not the intended recipient, please notify the sender or administrator@...
Re: Please help:: checking for data receive in USB Endpoint
2006-04-07 by ian.scanlon
--- In lpc2000@yahoogroups.com, Manisha Kalita <manisha@...> wrote:
> Hi all,
lpc2000 board?? what hardware? compiler? using example code from
____? PC test application?
there in
bit of this
the host,
using
any idea
> please reply.
> Thanks & Regards
> Manisha
administrator@...
RE: [lpc2000] Re: Please help:: checking for data receive in USB Endpoint
ya its lpc 2148 board
ARM7 running at 60MHz, flash of 512 KB, RAM with 32 KB + 8 KB Shared with
USB DMA & USB 2.0 Device controller (Full Speed)DMA supported. using gcc. &
yes some help from sample code, i dont remeber the source.
Manisha
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of ian.scanlon
Sent: Friday, April 07, 2006 6:36 PM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Re: Please help:: checking for data receive in USB
Endpoint
> Hi all,
there in
bit of this
the host,
using
any idea
> please reply.
> Thanks & Regards
> Manisha
administrator@...
Yahoo! Groups Links
Shared with
using gcc. &
> Regards,
> Manisha
Behalf
> Of ian.scanlon
USB
> Endpoint
> --- In lpc2000@yahoogroups.com, Manisha Kalita <manisha@> wrote:
> > Hi all,
> there in
> bit of this
> the host,
> using
Can't really say why your code doesn't work, but the example code
from Keil and IAR works well (mostly).
Take a look at the IAR USB sample code. LPC_USB.c -> USB_EpRead(...
It is copyrighted so I won't post it here.  Did you write the Read
enable bit?
can you give me the proper link for IAR code?
about my code:
/*Enable Read Mode and program the LOG_ENDPOINT High*/
USB_CTRL = (DATA_TRANS_EP  << 2) | CTRL_RD_EN;
& then i am checking for PKT_RDY bit as below.
if (RX_PLENGTH & PKT_RDY)
read the data.
& here the if condition is always true. thats the main problem.
regards,
Manisha
Of ian.scanlon
Sent: Friday, April 07, 2006 7:13 PM
Endpoint
Shared with
using gcc. &
> Regards,
> Manisha
Behalf
> Of ian.scanlon
USB
> Endpoint
> > Hi all,
> there in
> bit of this
> the host,
> using
enable bit?
Yahoo! Groups Links
> about my code:
> read the data.
> regards,
> Manisha
Behalf
> Of ian.scanlon
USB
> Endpoint
> Shared with
> using gcc. &
> > Regards,
> > Manisha
> Behalf
> > Of ian.scanlon
> USB
> > Endpoint
> > > Hi all,
is
> > there in
> > bit of this
from
> > the host,
> > using
> enable bit?
administrator@...
Look here for the IAR code.
http://www.olimex.com/dev/soft/arm/LPC/LPC2148_USB.zip
You will have to spend your own time at the IAR site or Keil site for
more.(www.IAR.com, www.keil.com)
I emailed you the IAR epRead function from IAR
-Ian
A new problem:: checking for data receive in USB Endpoint
hi
the previous problem got solved. actually i was not checking the DataValid
bit,.
But, now, a new bug has come, the PKT_RDY is set only when interrupt is
enabled, however, in the spec i suppose, this is not mentioned anywhere. and
according to the design, i am using polling mode for data reception. so, can
anyone help me to check for data reception in polling?
thanks.
Of ian.scanlon
Sent: Friday, April 07, 2006 7:33 PM
Endpoint
> about my code:
> read the data.
> regards,
> Manisha
Behalf
> Of ian.scanlon
USB
> Endpoint
> Shared with
> using gcc. &
> > Regards,
> > Manisha
> Behalf
> > Of ian.scanlon
> USB
> > Endpoint
> > > Hi all,
is
> > there in
> > bit of this
from
> > the host,
> > using
> enable bit?
administrator@...
-Ian
Yahoo! Groups Links
SOLVED:: new problem:: checking for data receive in USB Endpoint
we can check the Buffer1_full bit is set or not after selecting the End
point.
anyway, thanks a lot.
Of Manisha Kalita
Sent: Friday, April 07, 2006 8:22 PM
Subject: [lpc2000] A new problem:: checking for data receive in USB
Endpoint
hi
bit,.
thanks.
Of ian.scanlon
Endpoint
> about my code:
> read the data.
> regards,
> Manisha
Behalf
> Of ian.scanlon
USB
> Endpoint
> Shared with
> using gcc. &
> > Regards,
> > Manisha
> Behalf
> > Of ian.scanlon
> USB
> > Endpoint
> > > Hi all,
is
> > there in
> > bit of this
from
> > the host,
> > using
> enable bit?
administrator@...
-Ian
Yahoo! Groups Links
Yahoo! Groups Links
