Lpc2000
LPC2106 and JEENI ICE
2004-03-18 by roland_winistoerfer
Hi
I tried to get the JEENI ICE from EPI to work with the LPC2106, but
without any success. The poeple from EPI told me it would not run with
this ARM core, because there is not support of the RTCK signal on the
JTAG.
I'm a little bit confused, because I had a look at the Wiggler
connection schematic on the homepage of Leon Heller. The RTCK signal
is not used for the Wiggler (and I guess it works with the Wiggler).
The JEENI is not able to stop the core, so it is possible to debug
code inside the LPC2106.
Does anybody have an idea whats going on ?
Is this actually a problem with the JEENI ?
Thanky for any hint.
Bye, Wini
Notes:
DGBSEL is connected to 3.3V. All other JTAG signals are connected like
the Wiggler schematic from Leon.
Re: LPC2106 and JEENI ICE
2004-03-22 by embeddedjanitor
--- In lpc2000@yahoogroups.com, "roland_winistoerfer" <roland.
winistoerfer@w...> wrote:
> Hi
with
> JTAG.
> Bye, Wini
> Notes:
like
The RTCK is used to synchonise devices with a slow clock.
I'm quite suprised that the use of RTCK is not optional on the JEENI
because quite a few devices do not support it.
The LPC210x has RTCK output on pin 26. Attach this to the JEENI's RTCK
input and try that out.
-- CHarles
2004-03-22 by roland_winistoerfer
--- In lpc2000@yahoogroups.com, "embeddedjanitor" <manningc2@a...>
RTCK
> -- CHarles
Unfortunately, the JEENI does not support the RTCK signal, so it is
not possible to connect to it.
I also checked the connection of the JTAG on several other schematics
on the net and mostly they to not use the RTCK signal.
Any other suggestion ?
Wini
JEENI
> RTCK
> > -- CHarles
schematics
> Wini
Suggestion: Slow your JTAG clock down.
The JTAG clock must not be faster than 1/6 of the core clock
frequency. So, if you're running from a 10MHz crystal, and the PLL has
not been set up yet, then don't run the JTAG clock any faster than
1MHz.
-- Charles
2004-03-23 by roland_winistoerfer
has
> 1MHz.
> -- Charles
Tried this, but without success.
I now will try to get the MAJIC (this is the successor of the JEENI)
for some tests. I guess with the MAJIC this should not be a problem.
I also have some other problem with my hardware, but I will this post
as new thread to this forum.
Thank you very much your help.
Wini
2004-03-23 by jvedum
PLL
> has
than
> > 1MHz.
> > -- Charles
JEENI)
post
> Wini
Do you have any contact with the uC over the JTAG if at all?
Which of the JTAG ports are you using?
Jon
> Jon
No, I can not connect to the uC over the JTAG interface at all. I use
the primary JTAG port (enabled trough the DGBSEL pin).
Wini
Re: [lpc2000] Re: LPC2106 and JEENI ICE
2004-03-25 by Leon Heller
From: "roland_winistoerfer" <roland.winistoerfer@...>
To: <lpc2000@yahoogroups.com>
Sent: Tuesday, March 23, 2004 4:53 PM
Subject: [lpc2000] Re: LPC2106 and JEENI ICE
> > Jon
If you are using my circuit, try tying nTRST high (pin 3 of JTAG and pin 47
of LPC210x).
Leon
2004-05-04 by rebloby
Hi Guys,
I'm trying to get a connection to my LPC2104 with also the JEENI from
EPI, but without succes. Is it really not possible to use the JEENI
for this uC? I have the new firmware (v2.2).
Rev 2.2 firmware performs a self-test to verify that the JTAG
connection to the target is working properly. The JEENI puts the JTAG
TAP into BYPASS mode, writes out 32-bit pattern of ones and zeros
(0x59A6956A) and tries to read it back.
(JTAG TAP CONTROLLER)
On my scope I see that more then 5 cycles of tck with tms '1', so the
LPC is in test logic reset. Then its going to select IR-SCAN and goes
to capture-IR and four times shift-IR with TMS '1'. Is this a good
instuction for the LPC2104 to select te BYPASS register???? is the
opcode only 4 bits????? I cant find information about that on the
philips website.
Then I see it goes to select DR scan and writes the pattern of ones
and zeros. Later it wants to read it back, but the TDO stays '0' and
the error JTAG ERROR TDO=0000.0000 appears (from the firmware). (TDO
is connected fine, so thats not it)
Does some of you know more about the tap controller and instructie
register of the LPC210x or where I can find that and more about the
compactability with the JEENI?
2004-05-07 by tendoskeleton
See message 2007: -Does ARM EMBEDDEDICE work with LPC210x-  for the
answer if the JEENI support the LPC210x.
--- In lpc2000@yahoogroups.com, "rebloby" <rebloby@y...> wrote:
> Hi Guys,
from
JTAG
goes
> philips website.
and
(TDO
