Lpc2000
DCD signal force LPC2xxx go into Bootloader during reset
2006-04-26 by misstero
Dear All,
I have design which is connected modem signals to UART1 (Full UART) of
LPC2xxxx but I found serious problem with DCD signal.
DCD signal of UART1 is alternate function on P0.14 which is LPC2xxx
bootloader determine during reset to go into Bootloader mode if it low.
Our problem occur when modem connected that DCD is active (Active Low
same as bootloader mode request) and LPC2xxx is reseted which may
cause by unstable power or external reset via RESET pin by
supervisory. This made LPC2xxx  go into bootloader mode forever cannot
return back to our application code even modem's DCD inactive later.
Only power cycle both LPC2xxx and modem to restart it to application
code. This case unaccetable when devices are installed in unman location.
I have an idea to solve this problem but it need help from Philips by
add time-out in Bootloader mode if it does not have any activity for
short period of time (etc. 3s) it should be retry to execute
application code repeatly so I'd like to ask Philips is it possible?
Anyone have other ideas to solve this problem? Please share with me. I
prefer to solve by software first if it possible.
Suriyan.
Re: DCD signal force LPC2xxx go into Bootloader during reset
2006-04-26 by brendanmurphy37
It's probably not much help to you, but we specifically don't use
the DCD line in a connection to a modem for this very reason.
In other words, if there's even a chance that something connected to
the line can fool the part into thinking it's being requested to
enter bootloader mode, then you're best not to connect it. As you
point out, there are failure modes that can lead to an unrecoverable
state (in the field).
We connect all modem signals (RTS/CTS/RI etc.) as normal, but
connect the DCD to an external interrupt line instead of the DCD
line on the LPC part, and modify the UART driver software
accordingly. If this isn't an option (i.e. you've finalised your
hardware design, or you're really short on pins), then there is one
possibility you can look at: if the (internal) watchdog resets the
device, the external request to enter the boot-loader is ignored.
You can probably make use of this to come up with a scheme for
improving the situation.
However, it's difficult to see how you could prevent the lockout
situation when an external reset is applied whilst a modem DCD is
being asserted. Power fails are less of an issue: presumably the
modem is powered off the same source, in which case DCD will be de-
asserted on power-up (unless there's some modem that can establish a
connection in less than 3ms?).
I doubt Philips would modify the boot-loader in such a way as you
propose: there could be unintended side effects for parts already
deployed if they did.
Sorry not to be of more help: I'd be interested to hear if you come
up with some other suggestions.
Brendan
--- In lpc2000@yahoogroups.com, "misstero" <suriyant@...> wrote:
> Dear All,
UART) of
low.
Low
cannot
later.
application
location.
by
for
possible?
me. I
> Thanks,
> Suriyan.
2006-04-27 by jayasooriah
location.
Have you considered using another pin for DCD purposes so that it does
not intefere with Bootloader functions?
One client had the same problem (was using this pin for a different
purpose though), and they patched the boot loader to use a different
pin to enter Bootloader mode.  Incidentally this pin is determined by
Bootloader firmware, not the hardware.
The downside is that Philips will not guarantee your part if you patch
(or replace) the boot loader.
Hope this helps.
Jaya
2006-04-27 by brendanmurphy37
If you're producing product in any sort of volume this is a poor
strategy, in my opinion. Apart from not guaranteeing the part, Philips
are under no obligation to keep the boot loader the same: they can
change it at any time (as long as the published interface and
production functionality remain the same). If part of your production
process is to patch the device before you use it, what happens when
the patch location changes? Doesn't bear thinking about....
Brendan
Murphy's law of this forum seems to have struck yet again -- if there
is any way a comment can be misinterpreted, someone surely will :)
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
Nobody said anything about this being a production stragegy.  The
original poster was looking at recovery options.
The bootloader in the parts out in the field do not change on their own.
If you do not know what you are doing, you deserve what you get.  One
patches blindly only when one does not know what one is doing.
If one knows what one is doing, then this approach is a recovery
strategy.  I have seen a number of cases being reported here.
Jaya
Re: [lpc2000] DCD signal force LPC2xxx go into Bootloader during reset
2006-04-27 by Branko Karaklajic
Hello misstero,
Wednesday, April 26, 2006, 8:42:10 PM, you wrote:
m> Dear All,
m> I have design which is connected modem signals to UART1 (Full UART) of
m> LPC2xxxx but I found serious problem with DCD signal.
m> DCD signal of UART1 is alternate function on P0.14 which is LPC2xxx
m> bootloader determine during reset to go into Bootloader mode if it low.
m> Our problem occur when modem connected that DCD is active (Active Low
m> same as bootloader mode request) and LPC2xxx is reseted which may
m> cause by unstable power or external reset via RESET pin by
m> supervisory. This made LPC2xxx  go into bootloader mode forever cannot
m> return back to our application code even modem's DCD inactive later.
m> Only power cycle both LPC2xxx and modem to restart it to application
m> code. This case unaccetable when devices are installed in unman location.
m> I have an idea to solve this problem but it need help from Philips by
m> add time-out in Bootloader mode if it does not have any activity for
m> short period of time (etc. 3s) it should be retry to execute
m> application code repeatly so I'd like to ask Philips is it possible?
m> Anyone have other ideas to solve this problem? Please share with me. I
m> prefer to solve by software first if it possible.
m> Thanks,
m> Suriyan.
In similar situation, I use one pin for powering up modem over MOSFET
which is always off after any kind of reset. MOSFET is controlled by
pin, and after reset pin is input, and MOSFET is off. after some
init, I turn ON modem and it works fine!
Best regards,
 Branko
I don't believe I did misinterpret what the original poster said:
they expressed a concern that units in the field could potentially be
left in a state that is unrecoverable without manual intervention.
Whether you know what you're doing or not is immaterial when doing
something like patching a boot loader: it's relying on undocumented
and unsupported features. I'm happy to stand over my contention that
this is a poor strategy for anyone putting product into the field,
regardless of whether it works.
You are of course entitled to disagree with this, and to advise
others as you see fit.
Brendan
there
different
different
can
own.
when
One
> Jaya
2006-04-27 by John Heenan
What about a simple brute force hardware approach that
1. Forces P0.14 high as soon as power is available.
2. Turns off the brute force during initialisation.
It is not pretty and depending on implementation may cost more power
than you might like.
John Heenan
> Dear All,
of
low.
Low
cannot
location.
by
me. I
> Thanks,
> Suriyan.
John,
I don't think this approach would solve the basic problem, which as
I understand it is something like:
- system is using modem, which is on a call: hence DCD is asserted
(low)
- software fails on the LPC2xxx (e.g. enters an infinite loop)
- external supervisor detects the problem and asserts RESET to reset
the LPC2xxx
- as DCD (P0.14) is still low when reset happens, system enters boot
loader mode
- system is now unrecoverable without manual intervention (as the
original post said, a simple power cycle can do the actual recovery)
I guess you could use a hardware approach similar to the one you
suggest to ensure P0.14 is high when RESET is asserted, as well as
when power is 1st applied (on the basis that any re-flash will
probably require manual intervention and override in any case). A
simpler hardware fix as I previously suggested is just to avoid
using the pin as DCD.
Unless of course I'm misunderstanding both the original post and
your suggested fix....
Brendan
power
> John Heenan
> --- In lpc2000@yahoogroups.com, "misstero" <suriyant@> wrote:
> > Dear All,
UART)
> of
LPC2xxx
it
> low.
(Active
> Low
> cannot
later.
application
> location.
Philips
> by
for
possible?
> me. I
> > Thanks,
> > Suriyan.
Re: [lpc2000] Re: DCD signal force LPC2xxx go into Bootloader during reset
2006-04-27 by Mark Norton
Use a transceiver chip with an enable pin.  The enable
is controlled by the micro so on reset the transceiver
is disabled and thus the micro will not go into
bootloader mode.
--- brendanmurphy37 <brendanmurphy37@...> wrote:
> John,
> problem, which as
> DCD is asserted
> (low)
> infinite loop)
> the LPC2xxx
> system enters boot
> loader mode
> actual recovery)
> the one you
> re-flash will
> any case). A
> just to avoid
> original post and
> Brendan
> that
> available.
> initialisation.
> may cost more
> power
> > John Heenan
> <suriyant@> wrote:
> > > Dear All,
> to UART1 (Full
> UART)
> > of
> signal.
> P0.14 which is
> LPC2xxx
> Bootloader mode if
> it
> > low.
> is active
> (Active
> > Low
> reseted which may
> RESET pin by
> > cannot
> DCD inactive
> later.
> restart it to
> application
> installed in unman
> > location.
> help from
> Philips
> > by
> have any activity
> for
> retry to execute
> Philips is it
> possible?
> Please share with
> > me. I
> possible.
> > > Thanks,
> > > Suriyan.
Do You Yahoo!?
http://mail.yahoo.com
I think the problem can be solved with a single OR gate.
1. As soon as power becomes available to a reset LPC2xxx any free
port1 pin will be pulled high due to internal pullups on all port 1
pins and due to port 1 default state as all inputs. This will
probably occur before pin 0.14 is read. If not an external pull up
resistor can be used.
2. The high signal can feed into an OR gate along with the DCD
signal. No matter what the state of the DCD signal the output of the
OR gate will be high. The output of the OR gate can be connected to
pin 0.14.
3. Since pin 0.14 is high the LPC2xxx will not forced to enter the
bootloader. During initialisation the port1 pin feeding the OR gate
can be made an output and forced low. Pin 0.14 will now reflect the
state of the DCD pin. However an approach this simple permanently
forces a pulled up resistor low and so affects the power budget.
John Heenan
> John,
> (low)
reset
> the LPC2xxx
boot
> loader mode
> Brendan
> power
> > John Heenan
> > > Dear All,
> UART)
> > of
> LPC2xxx
> it
> > low.
> (Active
> > Low
may
> > cannot
> later.
> application
> > location.
> Philips
> > by
activity
> for
> possible?
with
> > me. I
> > > Thanks,
> > > Suriyan.
John,
I'm sure what you describe, or something close to it can be made to
work OK. I guess we just took the easy way out and said: let's not
use the pin for anything other than selecting the bootloader.
It just goes to show though how careful you have to be with multi-
purpose pins, especially one that can force you into a completely
different mode that (your application) software can't get you out of.
Best to know of these things before you have tens or hundreds of
thousands (or millions?) of units in the field.....
Like the original poster, I'd be curious to know if there's a
software way out of this (without modifying the bootloader). If you
restrict RESETs to just power-on resets and internal watchdog ones,
you're probably fine (but can you guarentee 100% the modem you're
connected to won't pull DCD low during power-on?). If there are
other sources of (external) RESET, my guess is only something like
your (hardware) suggestion would be guarenteed to work.
Brendan
1
to
> pin 0.14.
gate
> John Heenan
> > John,
as
asserted
> > (low)
> reset
> > the LPC2xxx
> boot
> > loader mode
recovery)
as
A
> > Brendan
> > power
> > > John Heenan
> > > > Dear All,
(Full
> > UART)
> > > of
> > LPC2xxx
if
> > it
> > > low.
> > (Active
> > > Low
which
> may
forever
> > > cannot
inactive
> > later.
> > application
unman
> > > location.
> > Philips
> > > by
> activity
> > for
> > possible?
> with
> > > me. I
> > > > Thanks,
> > > > Suriyan.
