Lpc2000
Problem running LPC2106 with MAM, PLL and UART1 interrupts.
2006-04-24 by karlstiller
Hi guys,
Another new member, and another problem.  I appreciate any help, and
I hope to be able to return the favor in the future.
I am in the final stages of a project that uses a LPC2106.  Things
work perfectly as it is, but we have recently discovered that we are
getting low performance issues as we are running without the MAM and
PLL.
I am currently working on trying to add in the MAM and PLL, but I
have run into problems.  Basically what I have found is the following:
1. When running either the MAM or the PLL, interrupts from UART1 TX
stop occurring
2. When running both the MAM and the PLL, the processor doesn't seem
to run properly, or digital outputs no longer happen.
I am testing, using a program that does the following:
1. Clears Pin
2. Enables PLL (and or) MAM
3. Sets Pin
4. Calls function
5. Clears Pin.
The program was made to see the performance increases using the PLL
and MAM.  When running the PLL or the MAM the program works fine.
However, when running both the PLL and MAM, the last clear pin does
not occur.  I'm unsure what's happening, as when I step through the
program step by step using J-Tag, it works as expected!
When adding the PLL or the MAM into the existing project,
communication on UART1 stops working.  The first byte is sent
correctly, but the rest of the string (sent using the interrupt
generated from UART1 TX) isn't sent.
I have read the Philips datasheet, and the guide from Hitex (The
Insider's Guide To The Philips ARM7-Based Microcontrollers) and
haven't found anything relating to the MAM or PLL and its effects on
interrupts.
Any ideas?
Karl
Re: Problem running LPC2106 with MAM, PLL and UART1 interrupts.
2006-04-24 by rtstofer
--- In lpc2000@yahoogroups.com, "karlstiller" <karls@...> wrote:
> Hi guys,
> PLL.
> stop occurring
> 1. Clears Pin
> 3. Sets Pin
> 4. Calls function
> 5. Clears Pin.
> interrupts.
> Any ideas?
> Karl
But, you haven't told us the important stuff: what crystal frequency,
what PLL setup (for a 14.7456 MHz crystal, PLLCFG=0x23 works), what
MAM setup (MAMCR=0x02 and MAMTIM=0x04 works) and what VPBDIV (0x01 works).
These values are from James Lynch's excellent tutorial. Rev 3 is here:
http://www.olimex.com/dev/pdf/ARM%20Cross%20Development%20with%20Eclipse%20version%203.pdf
There is a complete distribution of the entire tool chain somewhere.
Search the archives here to see who hosts it.
Richard
Re: [lpc2000] Re: Problem running LPC2106 with MAM, PLL and UART1 interrupts.
2006-04-24 by Robert Adsett
> > interrupts.
> > Any ideas?
> > Karl
You can definitely get odd behaviour if you operate the PLL outside of its
range.  The CPU may run but the peripherals may behave strangely.  You can
also look at the support routines in the newlib-lpc lib for an example that
takes the crystal frequency and desired operating frequency as inputs and
set the PLL registers accordingly.  That might give you a double check on
your values.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2006-04-25 by karlstiller
frequency,
works).
Oops.. I knew I forgot something.
I'm running using an external crystal of 14.7456 MHz.  VPDIV = 0
default -> one fourth of the processor clock.   I'm using the
following code snippet for setting up the PLL and MAM:
// PLL
PLLCFG = 0x23;    // M = 4 P = 2 -> FOSC x 4 = 58980000(cclk)
PLLFEED = 0xAA;
PLLFEED = 0x55;   // PLL feed sequence
PLLCON = 0x1;     // habilita PLL e conecta PLL
PLLFEED = 0xAA;
while( !(PLLSTAT & 0x400) );    // wait for PLL lock
PLLCON = 0x3;      // Connect PLL
PLLFEED = 0xAA;
// MAM
MAMCR = 0x00;
MAMTIM = 0x02;     // 2 processor clocks in duration for fetch cycles
MAMCR = 0x02;
I don't know if its relevant, but I'm using the IAR compiler (version
4.30) to develop.
example that
inputs and
check on
> your values.
> Robert
Thanks, I'll check that out.
Karl
2006-04-25 by rtstofer
> frequency,
> works).
> // PLL
> PLLFEED = 0xAA;
> PLLFEED = 0xAA;
> PLLFEED = 0xAA;
> // MAM
> MAMCR = 0x00;
> MAMCR = 0x02;
> 4.30) to develop.
> example that
> inputs and
> check on
> > your values.
> > Robert
> Karl
It is worth noting that in "MAM USAGE NOTES" on page 59 or the
September 17, 2003 User Manual, for a speed above 40 MHz, 3 CCLKs are
proposed as the MAMTIM value.  Just 'proposed', mind you.
Your MAMTIM value is probably too small.  I have had good success with
a value of 4 but I haven't tried 3.
VPBDIV can be 0x00 if you wish.  I use 0x01 so the VPB bus clock is
the same as the processor clock.
Richard
Hi guys,
I've done some more testing with some of the different values
proposed for the PLL and MAM, but the problems continue.  From this I
suppose that the problem with the communication may be in the UART
settings rather than the PLL or MAM settings.
But the problem of the last pin clear is still strange...it must be
something setting or affect I've overlooked.  Is the operation of the
processor so sensitive to these changes?
I will do some further study of the PLL, MAM and UART, as well as my
code and see what I can uncover.
Thanks for the help so far.
Karl
> > example that
> > inputs and
double
> > check on
> > > your values.
> > > Robert
are
with
> Richard
2006-04-25 by Robert Adsett
Quoting karlstiller <karls@...>:
Just a thought but you don't try to use the same UART settings both before and
after setting the PLL do you?
Not that I've noticed.  I did see some odd behaviour when I misset the PLL and
had too high an intermediate frequency.  And I wouldn't try MAMTIM below the
recommended value at full speed.
Robert
2006-04-26 by karlstiller
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@...>
before and
No no, nothing like that, just a set-up and use strategy.
After a somewhat decent sleep I will add in use of the UART in the test
program to confirm that there is nothing in the rest of the project
that screws up the UART interrupt.
Karl
2006-04-27 by karlstiller
Hey Guys,
Problem solved.  The supply of 1.8V to the processor was ok when
running without the PLL and MAM.  When the PLL was added, the voltage
fell to 1.3V.  Thus leading to the strange operation.
Just goes to show that when you are dealing with embedded processors
you have to keep in mind both hardware and software.
Thanks for the help!
