Lpc2000
LPC2000 Flash utilty problem
2005-04-29 by 김동휘
Hi.
I now design a test board using LPC2214.
When I download hex code to target, I use the LPC2000 flash utility.
If my hex code is over 130KB, flash utility annouces the following message.
"Code in HEX file exceeds Flash Limitations!"
The internal flash of LPC2214 is 256KB.
But my code size is about 130KB.
Why does this problem happen to?
How can I settle to this problem?
Dong-hwi Kim(金桐煇)
Senior Engineer of FAE Team.
Syncoam Co., Ltd.
TEL : 82-31-788-7843
FAX : 82-31-788-7846
E-mail : dhkim@...
Re: [lpc2000] Re: LPC2000 Flash utilty problem
2005-04-29 by 김동휘
Thanks for your response.
I don't know what I do according to your message.
What program is 'dsdc.exe'?. What does that roll?
Where do I execute that, 'bsdc -l comX'
What is the boot loader jumper?
Does you have any document for this?
I want to reply a detail reponse.
You can do that? I am sorry.
  To: lpc2000@yahoogroups.com
  Sent: Saturday, April 29, 2006 10:26 AM
  Subject: [lpc2000] Re: LPC2000 Flash utilty problem
  message.
  Try my diagnostic tool available at:
      http://www.cse.unsw.edu.au/~jayas/esdk/files/lpc/bsdc.exe
  Install the boot loader jumper, reset the target board and run this
  command as:
      bsdc -l comX
  where COMX is the serial port your board is connected to.
  It should print enough information from boot sector about your device
  that may give a hint as to what is happening.
  Jaya
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-04-29 by jayasooriah
message.
command as:
    bsdc -l comX
Jaya
RE: [lpc2000] Re: LPC2000 Flash utilty problem
2006-04-29 by Pandurang Shinde
hi ,
"Install the boot loader jumper" what is it?Is it any hex file? (if yes then pl send me the path)
Pandurang S.
From: lpc2000@yahoogroups.com on behalf of jayasooriah
Sent: Sat 4/29/2006 6:56 AM
message.
command as:
    bsdc -l comX
Jaya
SPONSORED LINKS
Microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PMg>  	Microprocessor <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ>  	Intel microprocessors <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5quAgrl5w>
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
	 lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
hi,
             have u read the device id (you can read this by flash downloader).Is it matches with your specified part.
Pandurang S.
Sent: Fri 4/29/2005 8:54 AM
Subject: Re: [lpc2000] Re: LPC2000 Flash utilty problem
  message.
  command as:
      bsdc -l comX
  Jaya
  YAHOO! GROUPS LINKS
SPONSORED LINKS
YAHOO! GROUPS LINKS
--- In lpc2000@yahoogroups.com, "Pandurang Shinde" <pandurang@...> wrote:
> hi ,
I meant the jumper on your board that pulls P0.14 low so that on
reset, your LPC enters ISP mode.  By install, I meant inserting this
jumper or its equivalent for your board.  I do not mean software
installation.
Jaya
thanks for your reply.
i use the jumber to make P0.14 line low.
But when i run the bsdc it showing ERROR 21 the device is not ready.
(I have test the link with flash downloader & it is ok)
what should i do?
Pandurang S.
Sent: Sat 4/29/2006 12:59 PM
> hi ,
installation.
Jaya
SPONSORED LINKS
YAHOO! GROUPS LINKS
> what should i do?
Assuming your target board is working, the most likely reason for
  connect .... bsdc: error 21: the device is not ready
is that you indicated the wrong comms port or there is a handshake
problem.
I am interested in fixing it so it works for you.  Lets do this by
direct emails... the manual page for that utility is long overdue!
Jaya
