Lpc2000
Cycles timing for barrel-shifter usage
2006-05-06 by MB
I use the LPC2103 microprocessor and I like it very much.
I was wondering if the usage of barrel shifter in the ARM instruction
set eats up more cycles.
ARM datasheets mention the SHIFT(Rs) eats up one more cycle, though
I'm not sure if they mean that shifting by a register takes a cycle,
but shifting by a const is free, or any shift takes a cycle.
MOV r0, r1, ASR #16 ; 1 Cycle ? 2 Cycles ?
MOV r0, r1, ASR r2  ; 1 Cycle ? 2 Cycles ? 3 Cycles ?
Thanks in advance,
MB
Re: [lpc2000] Cycles timing for barrel-shifter usage
2006-05-06 by Peter Jakacki
Good question, I had to check the extra cycle thing myself. The ARM uses
a barrel shifter which means that it can perform multi-bit shifts in one
operation, so it doesn't matter whether you specify 1 or 31 bits, or
whether the operand is a register or a constant. The shift operation
takes take one extra cycle (Internal cycle) over a normal data operation
though.
The shift operand is taken either from the instruction field or read
directly from a register so it makes no difference to the instruction
processing as both operands are "on-hand".
MOV r0, r1, ASR #16  ; 2 cycles
MOV r0, r1, ASR r2  ; 2 cycles
The only 3 cycle data operations are when a shift is specified and r15
is the destination.
*Peter*
2006-05-06 by Dominic Rath
The ARM7TDMI-S TRM says something different:
Data processing Single-cycle                  +S
Data processing Register-specified shift      +I +S
Data processing R15 destination               +N +2S
Data processing R15, register-specified shift +I +N +2S
Only a shift by register (ASR r2) requires an additional datapath cycle. The
immediate variant (ASR #16) is executed in a single cycle. If the PC is the
destination register, two additional cycles are required, to refill the
pipeline.
Dominic
> though.
> is the destination.
> *Peter*
