Keil's ULINK interfaced with Embedded Artists LPC2148 Quickstart and Prototype
2006-05-30 by Sutton Mehaffey
I have been unable to get Keil's ULINK (JTAG) to work with Embedded Artist's LPC2148 V1.1 Quickstart and Quickstart Prototype board. I have downloaded the latest Keil 'reset patch' and have the latest uVision software. I have put 10K pullups on TDO, TDI, TRST, and TMS since the Prototype Board schematic didn't have those on it. Also the JTAG jumper is set on the prototype board. Anything else to set or do from the default configuration? Thanks. Is anyone using the EA Prototype board? If so, which wiggler are you using? Thanks. Sutton Mehaffey Kennesaw, GA sutton@...
2006-05-30 by Marko Pavlin (home)
Is it possible your LPC starts bootloader code? Check the enable pin on port1. M. Sutton Mehaffey wrote:
> I have been unable to get Keil's ULINK (JTAG) to work with Embedded > Artist's LPC2148 V1.1 Quickstart and Quickstart Prototype board. I > have downloaded the latest Keil 'reset patch' and have the latest > uVision software. > > I have put 10K pullups on TDO, TDI, TRST, and TMS since the Prototype > Board schematic didn't have those on it. Also the JTAG jumper is set > on the prototype board. Anything else to set or do from the default > configuration? Thanks. > > Is anyone using the EA Prototype board? If so, which wiggler are you > using? Thanks. > > Sutton Mehaffey > Kennesaw, GA > sutton@... > > > > > > SPONSORED LINKS > Microcontrollers > <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PMg> > Microprocessor > <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ> > Intel microprocessors > <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5quAgrl5w> > > > > YAHOO! GROUPS LINKS > > * Visit your group "lpc2000 > <http://groups.yahoo.com/group/lpc2000>" on the web. > > * To unsubscribe from this group, send an email to: > lpc2000-unsubscribe@yahoogroups.com > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > >
Which pin in particular? RTCK? I have also made sure that P0.14 is HIGH on reset. --- In lpc2000@yahoogroups.com, "Marko Pavlin (home)" <mp@...> wrote: > > Is it possible your LPC starts bootloader code? Check the enable pin on > port1. > > M. > > Sutton Mehaffey wrote: > > > I have been unable to get Keil's ULINK (JTAG) to work with Embedded > > Artist's LPC2148 V1.1 Quickstart and Quickstart Prototype board. I > > have downloaded the latest Keil 'reset patch' and have the latest > > uVision software. > > > > I have put 10K pullups on TDO, TDI, TRST, and TMS since the Prototype > > Board schematic didn't have those on it. Also the JTAG jumper is set > > on the prototype board. Anything else to set or do from the default > > configuration? Thanks. > > > > Is anyone using the EA Prototype board? If so, which wiggler are you > > using? Thanks. > > > > Sutton Mehaffey > > Kennesaw, GA > > sutton@... > > > > > > > > > > > > SPONSORED LINKS > > Microcontrollers > > <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PMg> > > Microprocessor > > <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ> > > Intel microprocessors > > <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5quAgrl5w>
> > > > > > > > YAHOO! GROUPS LINKS > > > > * Visit your group "lpc2000 > > <http://groups.yahoo.com/group/lpc2000>" on the web. > > > > * To unsubscribe from this group, send an email to: > > lpc2000-unsubscribe@yahoogroups.com > > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > >
