Lpc2000
LPC2292 startup code wrong?
2006-05-30 by frank_gruber11
I have a problem with the startup code for the LPC2292!
My selfmade target consist of: onchip Flash; CS0:Ram 32 Bit;
CS1:Ram32Bit; CS2: Peripherals16Bit; Cs3 Display+Uart 8bit
The problem I encounter is that I can`t access external memory. The
controller doesn´t generate the strobe signals nor any addresses!
What am I doing wrong?!
My startup code:
	Mode_USR  EQU      0x10
        Mode_FIQ  EQU      0x11
        Mode_IRQ  EQU      0x12
        Mode_SVC  EQU      0x13
        Mode_ABT  EQU      0x17
        Mode_UND  EQU      0x1B
        Mode_SYS  EQU      0x1F
        I_Bit     EQU      0x80
        F_Bit     EQU      0x40
        UND_Stack_Size  EQU     0x00000004
        SVC_Stack_Size  EQU     0x00000004
        ABT_Stack_Size  EQU     0x00000004
        FIQ_Stack_Size  EQU     0x00000004
        IRQ_Stack_Size  EQU     0x00000080
        USR_Stack_Size  EQU     0x00000400
AREA   STACK, DATA, READWRITE, ALIGN=2
        DS   (USR_Stack_Size+3)&~3  ; Stack for User/System Mode
        DS   (IRQ_Stack_Size+3)&~3  ; Stack for Interrupt Mode
        DS   (FIQ_Stack_Size+3)&~3  ; Stack for Fast Interrupt Mode
        DS   (ABT_Stack_Size+3)&~3  ; Stack for Abort Mode
        DS   (SVC_Stack_Size+3)&~3  ; Stack for Supervisor Mode
        DS   (UND_Stack_Size+3)&~3  ; Stack for Undefined Mode
Top_Stack:
// Phase Locked Loop (PLL) definitions
        PLL_BASE        EQU     0xE01FC080  /* PLL Base Address */
        PLLCON_OFS      EQU     0x00        /* PLL Control Offset*/
        PLLCFG_OFS      EQU     0x04        /* PLL Configuration  */
        PLLSTAT_OFS     EQU     0x08        /* PLL Status Offset */
        PLLFEED_OFS     EQU     0x0C        /* PLL Feed Offset */
        PLLCON_PLLE     EQU     (1<<0)      /* PLL Enable */
        PLLCON_PLLC     EQU     (1<<1)      /* PLL Connect */
        PLLCFG_MSEL     EQU     (0x1F<<0)   /* PLL Multiplier */
        PLLCFG_PSEL     EQU     (0x03<<5)   /* PLL Divider */
        PLLSTAT_PLOCK   EQU     (1<<10)     /* PLL Lock Status */
// PLL Setup
        PLLCFG_Val      EQU     0x00000025
        VPBDIV			EQU		0xE01FC100
        VPBDIV_Val		EQU		0x11			// Memory Accelerator Module (MAM)
definitions
        MAM_BASE        EQU     0xE01FC000  /* MAM Base Address */
        MAMCR_OFS       EQU     0x00        /* MAM Control Offset*/
        MAMTIM_OFS      EQU     0x04        /* MAM Timing Offset */
        MAMCR_Val       EQU     0x00000002
        MAMTIM_Val      EQU     0x00000004
// External Memory Controller (EMC) definitions
        EMC_BASE        EQU     0xFFE00000  /* EMC Base Address */
        BCFG0_OFS       EQU     0x00        /* BCFG0 Offset */
        BCFG1_OFS       EQU     0x04        /* BCFG1 Offset */
        BCFG2_OFS       EQU     0x08        /* BCFG2 Offset */
        BCFG3_OFS       EQU     0x0C        /* BCFG3 Offset */
// Bank Configuration BCFG 0 - 3
        BCFG0_Val   	EQU     0x2000FFEF
        BCFG1_Val   	EQU     0x2000FFEF
        BCFG2_Val   	EQU     0x1000FBEF
        BCFG3_Val   	EQU     0x0000FBEF
       	PCONP			EQU		0xE01FC0C4
       	PCONP_Val		EQU		0x00000002
// External Memory Pins definitions
	IO0DIR			EQU		0xE0028008
	IO0DIR_Val		EQU		0x2BFE0331
	IO1DIR			EQU		0xE0028018
	IO1DIR_Val		EQU		0x00000003
	IO2DIR			EQU		0xE0028028
	IO2DIR_Val		EQU		0xFFFFFFFF
	IO3DIR			EQU		0xE0028038
	IO3DIR_Val		EQU		0xFFFFFFFF
	PINSEL0        	EQU    	0xE002C000
       	PINSEL0_Val    	EQU    	0x00000000
      	PINSEL1        	EQU    	0xE002C004
       	PINSEL1_Val    	EQU    	0x00000000
       	PINSEL2       	EQU    	0xE002C014
       	PINSEL2_Val  	EQU    	0xD816924
 	CODE_BASE       EQU     0x00000000	// internal Flash
AREA   STARTUPCODE, CODE, AT CODE_BASE   // READONLY, ALIGN=4
       PUBLIC  __startup
       EXTERN  CODE32 (?C?INIT)
__startup       PROC    CODE32
EXTERN CODE32 (Undef_Handler?A)
EXTERN CODE32 (SWI_Handler?A)
EXTERN CODE32 (PAbt_Handler?A)
EXTERN CODE32 (DAbt_Handler?A)
EXTERN CODE32 (IRQ_Handler?A)
EXTERN CODE32 (FIQ_Handler?A)
Vectors:        LDR     PC,Reset_Addr
                LDR     PC,Undef_Addr
                LDR     PC,SWI_Addr
                LDR     PC,PAbt_Addr
                LDR     PC,DAbt_Addr
                NOP                            /* Reserved Vector */
;               LDR     PC,IRQ_Addr
                LDR     PC,[PC, #-0x0FF0]      /* Vector from
VicVectAddr */
                LDR     PC,FIQ_Addr
Reset_Addr:     DD      Reset_Handler
Undef_Addr:     DD      Undef_Handler?A
SWI_Addr:       DD      SWI_Handler?A
PAbt_Addr:      DD      PAbt_Handler?A
DAbt_Addr:      DD      DAbt_Handler?A
                DD      0                      /* Reserved Address */
IRQ_Addr:       DD      IRQ_Handler?A
FIQ_Addr:       DD      FIQ_Handler?A
//ORG	CODE_BASE + 0x40   		// Interruptvektoren schützen
// Reset Handler
Reset_Handler:
		LDR     R0, =PCONP
                LDR     R1, =PCONP_Val
                STR     R1, [R0]
                LDR     R0, =IO0DIR
                LDR     R1, =IO0DIR_Val
                STR     R1, [R0]
                LDR     R0, =IO1DIR
                LDR     R1, =IO1DIR_Val
                STR     R1, [R0]
                LDR     R0, =IO2DIR
                LDR     R1, =IO2DIR_Val
                STR     R1, [R0]
              	LDR     R0, =IO3DIR
 		LDR     R1, =IO3DIR_Val
                STR     R1, [R0]
		LDR     R0, =PINSEL0
                LDR     R1, =PINSEL0_Val
                STR     R1, [R0]
		LDR     R0, =PINSEL1
                LDR     R1, =PINSEL1_Val
                STR     R1, [R0]
		LDR     R0, =PINSEL2
                LDR     R1, =PINSEL2_Val
                STR     R1, [R0]
                LDR     R0, =VPBDIV
                LDR     R1, =VPBDIV_Val
                STR     R1, [R0]
                LDR     R0, =EMC_BASE
                LDR     R1, =BCFG0_Val
                STR     R1, [R0, #BCFG0_OFS]
                LDR     R1, =BCFG1_Val
                STR     R1, [R0, #BCFG1_OFS]
                LDR     R1, =BCFG2_Val
                STR     R1, [R0, #BCFG2_OFS]
                LDR     R1, =BCFG3_Val
                STR     R1, [R0, #BCFG3_OFS]
                LDR     R0, =PLL_BASE
                MOV     R1, #0xAA
                MOV     R2, #0x55
// Configure and Enable PLL
                MOV     R3, #PLLCFG_Val
                STR     R3, [R0, #PLLCFG_OFS]
                MOV     R3, #PLLCON_PLLE
                STR     R3, [R0, #PLLCON_OFS]
                STR     R1, [R0, #PLLFEED_OFS]
                STR     R2, [R0, #PLLFEED_OFS]
// Wait until PLL Locked
PLL_Loop:       LDR     R3, [R0, #PLLSTAT_OFS]
                ANDS    R3, R3, #PLLSTAT_PLOCK
                BEQ     PLL_Loop
// Switch to PLL Clock
                MOV     R3, #(PLLCON_PLLE | PLLCON_PLLC)
                LDR     R0, =MAM_BASE
                MOV     R1, #MAMTIM_Val
                STR     R1, [R0, #MAMTIM_OFS]
                MOV     R1, #MAMCR_Val
                STR     R1, [R0, #MAMCR_OFS]
// Memory Mapping (when Interrupt Vectors are in RAM)
                MEMMAP  EQU  0xE01FC040  /* Memory Mapping Control */
                LDR     R0, =MEMMAP
                MOV     R1, #1
                STR     R1, [R0]
// Setup Stack for each mode
                LDR     R0, =Top_Stack
// Enter Undefined Instruction Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_UND|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #UND_Stack_Size
// Enter Abort Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_ABT|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #ABT_Stack_Size
// Enter FIQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_FIQ|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #FIQ_Stack_Size
// Enter IRQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_IRQ|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #IRQ_Stack_Size
// Enter Supervisor Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_SVC|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #SVC_Stack_Size
// Enter User Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_USR
                MOV     SP, R0
// Enter the C code
                LDR     R0,=?C?INIT
                TST     R0,#1       ; Bit-0 set: main is Thumb
                LDREQ   LR,=exit?A  ; ARM Mode
                LDRNE   LR,=exit?T  ; Thumb Mode
                BX      R0
                ENDP
PUBLIC exit?A
exit?A          PROC    CODE32
                B       exit?A
                ENDP
PUBLIC exit?T
exit?T          PROC    CODE16
exit:           B       exit?T
                ENDP
                END
